Zumo
Author: ROBSMST (Show all albums)
Pictures of my Zumo Install
Zumo in the dark
Switched Powerlet connection (can be used for your switched power needs)
Spliced Zumo into stock GPS switched power
Other view of spliced Zumo into stock GPS switched power
Wiring goes down the side
GXM under front panel shield up
GXM under front panel shield down
Ran GXM extension through hole that leads directly under dash
Ran Zumo ground to BigShot ground (notice Arlen Ness Filter)
Unplugged AUX, removed Grommet, replugged AUX and connected Zumo to AUX all under dash
Lock for cradle and XM, Power and Audio cables
Ram ball is on with industrial strength double sided tape from Walmart >$5. Tested at 130MPH on FJR, the stuff sticks!
