Strange noise
Mr Sug
Posted 2011-05-19 9:22 PM (#86681)
Subject: Strange noise
Kansas City, MO
After I turn the key off - a few seconds later, I have a funny noise from the right side of the fairing - is that where the fuel pump is? Sounds like it is coming from the same place that I hear the fuel pump when I turn the key on ( and I do let it run and stop before starting) I have read about fuel pump problems - is this what anyone heard before things went south?
kmt27
Posted 2011-05-19 10:01 PM (#86685 - in reply to #86681)
Subject: RE: Strange noise
Davenport, IA
After a few seconds after turning the key off, the fuel pump will make a noise depressurizing. This sound is just a little bit louder than when turning the key on when the fuel pump is pressurizing. Normal, unless it gets outrageously loud.
SYNSTR
Posted 2011-05-19 10:23 PM (#86687 - in reply to #86681)
Subject: Re: Strange noise
Mt. Vernon, WASH.
If it's a sort of low buzzing, it's probably the fuel pump releasing pressure back to the input line, mine does the same and that's what I figured it to be since everything now runs on pretty high fuel pump pressures, your FI car does the same thing but it's under an insulateed hood so you don't hear it.
Cap'n Nemo
Posted 2011-05-20 4:05 AM (#86694 - in reply to #86681)
New Bohemia, Va
it's the flux capacitor releasing the used up ions...
Liandra
Posted 2011-05-20 5:54 AM (#86699 - in reply to #86681)
Tifton, GA
That's odd I thought it was the warp core returning to idle.
dan camarco
Posted 2011-05-20 7:57 AM (#86703 - in reply to #86681)
Lumber Bridge, NC United States
I thought it was the transporter shutting down.
Edited by dan camarco 2011-05-20 7:58 AM
Lojak
Posted 2011-05-20 10:22 AM (#86719 - in reply to #86681)
New Brunswick , Canada
Nop...Plasma relay releasing...
Cometman
Posted 2011-05-20 10:32 AM (#86721 - in reply to #86681)
Simi Valley, CA
Dilithium Crystals being automatically set into safe mode.... another thing that HDs don't have Ah!
Edited by Cometman 2011-05-20 10:33 AM
Posted 2011-05-20 11:25 AM (#86724 - in reply to #86681)
Supper Ears are here. WOW
savage
Posted 2011-05-20 1:12 PM (#86732 - in reply to #86681)
FYI...it is the idle air control re-homeing. Does it every time you shut it off<
Trekwolf164
Posted 2011-05-20 3:26 PM (#86733 - in reply to #86732)
New York State
It is the discharge of the plasma injectors ,very normal prevents a breach of the warp reactor on start up.
Ride safe
Mr Sug
Posted 2011-05-22 12:11 AM (#86843 - in reply to #86681)
Kansas City, MO
the top sounded like the dealer - as it went down, sounded more like the guys I ride with
lennyb
Posted 2011-05-22 6:48 AM (#86848 - in reply to #86681)
Perry Hall, MD
It is probably the fuel pump, but if you have the optional air conditioning a similar noise will come from the compressor. Either is normal. ;-)
uknessie
Posted 2011-05-22 8:50 AM (#86860 - in reply to #86681)
Henlow, Bedfordshire, England
Mr Sug, looks like it is normal. Unlike most of the answers.
As everyone should know, the transporter, plasma relay, dilithium crystals, flux capacitor etc all shut down or stand by silently - it is one of the features of the Vision although I understand some were so troubled by this they have an alarm fitted that emits a few beeps seconds after shutdown.
