Fork Seal - Warranty?
wilsondude
Posted 2011-05-09 9:24 PM (#85872)
Subject: Fork Seal - Warranty?
Salt Lake City
Just noticed I've got a rt. front leak-I'm guessing it's a seal. Is this a warranty(16.5K mi. on the bike) item?
repeateruser
Posted 2011-05-09 9:33 PM (#85873 - in reply to #85872)
Subject: RE: Fork Seal - Warranty?
I don't think so,I asked the dealer what is done on the 15,000 mile service. He told me the fork seals are replaced and that service charge was 750.00. But great if your dealer will get it done under warrenty,good luck.
Posted 2011-05-09 10:13 PM (#85874 - in reply to #85872)
Subject: Re: Fork Seal - Warranty?
$750 to replace fork seals? How Much does NEW forks cost?
Cap'n Nemo
Posted 2011-05-10 5:13 AM (#85886 - in reply to #85872)
New Bohemia, Va
maybe I've missed something - got 91,500 on the clock and never have had to replace the fork seals yet. You change the fluid every 15,000 miles, however, if the entire assembly is taken apart then yes, the seals are replaced. Seals normally wouldn't be a warranty issue, but maybe in this case if they were leaking when you rolled out the door unnoticed, I'd have to go for it.
Trekwolf164
Posted 2011-05-10 9:58 AM (#85906 - in reply to #85872)
New York State
Deer Crusher had a leak in the front forks was repaired under extended warrenty about 3 weeks ago
Posted 2011-05-10 1:55 PM (#85940 - in reply to #85872)
Don't have to take forks a part for fluid change. Not even to replace seal if your good at your job. But at the bottom of the forks inside are bushings that do wear. At 91 thousand miles maybe you might need them. Just saying
Edited by john frey 2011-05-10 1:57 PM
Cap'n Nemo
Posted 2011-05-10 2:19 PM (#85944 - in reply to #85872)
New Bohemia, Va
The bike is still fairly solid, but do notice some "looseness" in the suspension. I need to do a complete shake down and replace all of the bushings and probably a few other things as well. The book says if you pull the forks apart then the seals need to be replaced, that is, the cartridge. Doing a drain, purge, clean, fill, and bleed, no, seals are fine. I show no signs of leakage at this time.
Posted 2011-05-10 6:39 PM (#85959 - in reply to #85872)
I didn't understand Cap'n your not replacing the cartridges right? Take a old bushing to the realer and mike a new one and then compare. A few thousands would be no big deal.
See if you can sweat talk them and find out what weight the fluid is.
Besides bushing and seals i wouldn't think you would have to replace any thing.
Cap'n Nemo
Posted 2011-05-10 9:16 PM (#85970 - in reply to #85959)
New Bohemia, Va
john frey - 2011-05-10 6:39 PM
I think the swing arm bushings are a little worn and that is what causes the loosness that I feel. But I do need to do a complete shakedown and replace all of it. I have a tendency to push things a little longer than recommended to see where the limit is.
