Garmin Zumo 550
alberts46
Posted 2011-03-21 10:25 AM (#81842)
Subject: Garmin Zumo 550
Bonita Springs, FL
I am getting a Zumo 550 and it will wired into the bike just as my 2820 was that was factory installed on a 10th Anniversary Vision.
Not that I will use it, but can you receive and make phone calls through the headset. I looked at the Zumo information and it seems like it will only work on Bluetooth not through the wired headset.
joe schmoe
Posted 2011-03-21 12:36 PM (#81850 - in reply to #81842)
Subject: Re: Garmin Zumo 550
East TN
You are correct...You can make and receive calls using a bluetooth head set but NOT the Victory Hard Wired headset...it NO WORKIE!! :>(
southjerseyrider
Posted 2011-03-21 8:43 PM (#81898 - in reply to #81842)
Subject: RE: Garmin Zumo 550
Vineland, NJ United States
I use the Zumo 550 with a bluetooth headset from "Blueant" and make calls thru the zumo all the time, it works great.  I don't use a Victory headset, I just listen to music thru the bike's speakers.  The Blueant is also an intercom with my passenger. http://www.myblueant.com/products/headsets/interphone/f4/index.php
