Is there a way to NOT play ipod in alphabetical order?
sfalexi
Posted 2011-02-13 10:14 PM (#79265)
Subject: Is there a way to NOT play ipod in alphabetical order?
Columbia, SC
I have an ipod cable, and whenever I switch playlists, it plays that playlist in alphabetical order by name of song. Also, when I press 1 to play ALL songs on the ipod, there are (again) in alphabetical order. Is there a way to have them play randomly or on shuffle? I'm not happy with taking off the ipod, plugging it back in, and having it start at the top of order every time. I just want it on random or something. Thanks.
Alexi
texasgrumpy
Posted 2011-02-13 10:24 PM (#79266 - in reply to #79265)
Subject: Re: Is there a way to NOT play ipod in alphabetical order?
If your ipod is in random mode before you plug it into the bike it will continue to play random through the audio system.
tralphaz
Posted 2011-02-14 3:52 AM (#79274 - in reply to #79266)
texasgrumpy - 2011-02-13 7:24 PM
What he said. Set to random and then plugged in it stays at random, Do any button pushing, it will go in the order of however you have your playlists setup, button 1 is reserved for the entire iPod library in order, buttons 2-12 is for your custom playlists that you setup in itunes.
Cap'n Nemo
Posted 2011-02-14 4:43 AM (#79275 - in reply to #79265)
New Bohemia, Va
you have to set up Playlists in iTunes and then move then synch them to your iPod. Unless in random mode they will play in order that is in your playlist. You can have up to 11 seperate playlist, the first one on your Vision will be the alphabetical list, that's been my experience.
picard
Posted 2011-02-16 1:36 PM (#79488 - in reply to #79265)
Prairie Dog Heaven, CO
iPod touch here. txgrumpy and tralphaz said it. Any change of playlist by pushing a button on the console will turn the shuffle off and play the songs in order. I would completely agree with you if you found that really annoying.
Edited by picard 2011-02-16 1:38 PM
Cap'n Nemo
Posted 2011-02-16 2:14 PM (#79492 - in reply to #79265)
New Bohemia, Va
hmmmm, okay, I see, never had that problem on my Touch. You might do a search on the iPod forum for an answer.
Posted 2011-02-16 4:59 PM (#79515 - in reply to #79265)
If you already have multiple playlists.....Try the different radio buttons (2 through 12) on the radio. Also set the playlists for Random play.
Have fun and Ride Safe!
picard
Posted 2011-02-16 11:23 PM (#79553 - in reply to #79265)
I think sfalexi has the same problem that I have. I have multiple playlists on my touch. On the touch you can only set the playback to random by selecting "shuffle" after selecting which playlist to play. So you do that for one playlist and ride off. Then, when you change playlists using one of the radio buttons on the dash the ipod seems to default to playing that newly selected playlist in order.
I have not found a way to permanently "set" my touch to random (like you can with a classic ipod).
Edited by picard 2011-02-16 11:24 PM
Posted 2011-02-17 11:31 AM (#79588 - in reply to #79265)
I set my playlists to random before Sync'ing to the iPod. Will this work for hte iTouch?
Ride Safe
picard
Posted 2011-02-17 3:20 PM (#79606 - in reply to #79265)
Don't think so as mine plays everything in alphabetical order (artists) no matter when or how the songs were added to the playlist. Any iPod that has a fixed "shuffle" setting would probably work fine (I have not tried my classic b/c of the warnings about vibes and the HDD) but the itouch lets you only decide to play random at the time you start playing a playlist by either selecting "play" or selecting "shuffle".
Unfortunately the default is "play" and that's what's selected when you chose a playlist via radio button on the dash of the Vision.
