Connector under Seat??
Boots
Posted 2011-01-25 10:09 PM (#78156)
Subject: Connector under Seat??
New Mexico
Just took the seat off to inspect shock and found grey connector that is not attached to anything. Any idea what this is?
(IMAGE_130a.jpg)
(IMAGE_131a.jpg)
Attachments IMAGE_130a.jpg (86KB - 1 downloads)
Attachments IMAGE_131a.jpg (85KB - 0 downloads)
wjoel
Posted 2011-01-26 6:09 AM (#78160 - in reply to #78156)
Subject: RE: Connector under Seat??
Northeastern Penna.
There was an earlier post on this. Check for earlier posts. I can't recall what this part is for.It's on the tip of my tongue, sorry.
Travelin Man
Posted 2011-01-26 6:29 AM (#78163 - in reply to #78156)
Subject: Re: Connector under Seat??
That is probably the connector for the optional console mounted powerlet, it mounts in the center console just about where the "front of bike" caption is in the bottom picture.
hoosiervic
Posted 2011-01-26 8:22 AM (#78169 - in reply to #78163)
Indianapolis, IN
Travelin Man - 2011-01-26 7:29 AM That is probably the connector for the optional console mounted powerlet, it mounts in the center console just about where the "front of bike" caption is in the bottom picture.
You are correct. This plug matches the plug on the powerlet optional plug. There is also one at the rear under the right side rear speaker (usually tied up on the wire harness). This one is for the optional passenger powerlet plug. The front one is controlled by the ignition switch and the rear one is always live, directly to the battery. They are both on 15 amp fuses. The rear one can be used as an alternate connection to a battery tender through the powerlet plug rather than having to get down on the floor to connect to the factory installed pigtail at the battery box.
SYNSTR
Posted 2011-01-26 9:52 AM (#78172 - in reply to #78156)
Mt. Vernon, WASH.
So, being an old, fat guy with a bad knee and back, does the factory (or anyone) make a moldex plug that goes into that lead and has a battery tender style plug on the other end? This subject is EXACTLY what I was asking about a few days ago-If no, where can I get just the male plug portion of that harness and I'll make my own.
ScoreBo
Posted 2011-01-26 10:30 AM (#78176 - in reply to #78156)
Northeast Ohio
SYNSTR, someone here routed their battery connector (the one that is already on the battery) to around the area under the seat. I just spent a few minutes looking for the post, but can't find it.
Boots
Posted 2011-01-26 10:46 AM (#78177 - in reply to #78156)
New Mexico
Thanks everyone.
I do find about 49 out of 50 questions I have by searching through the archives, but this one stumped me.
SYNSTR
Posted 2011-01-26 10:51 AM (#78179 - in reply to #78156)
Mt. Vernon, WASH.
I didn't thgink the stock pig tail was long enough. When I asked my dealers service guys about re-routing the plug to somewhere higher on the bike than the drain plug for the engine the answer was, the 'front pipe will melt it'.
Edited by SYNSTR 2011-01-26 10:52 AM
Webhair
Posted 2011-01-27 10:25 AM (#78236 - in reply to #78163)
Peachtree City, GA
Bingo
Russe63
Posted 2011-01-27 10:50 AM (#78239 - in reply to #78172)
Hanover, Md
SYNSTR - Try www.powerlet.com Look for cables. Part # PAC-008-06 for $15.95. They make them in lengths up to 30 inches (P/N PAC-008-30 for $19.95). Hope this helps
KansasGuardsman
Posted 2011-01-27 11:45 AM (#78241 - in reply to #78156)
Wichita, Kansas
You can tap the battery tender or any accessories into the grey plug using male flag terminals. Be sure to wrap it with self sealing electrical tape if you do (not the cheap vinyl crap). Or get a 25' extension here for $11.60. I took a plastic tie and tied up my battery connector to a frame point at the top of the left swoosh. Easy to get to even when hot and keeps the charger cable safe.
http://www.amazon.com/Battery-Tender-081-0148-25-Disconnect-Extensi...
SYNSTR
Posted 2011-01-27 12:18 PM (#78246 - in reply to #78156)
Mt. Vernon, WASH.
Cool! Thanks to all, I have just the aviation proven waterproofing wrap item for the connector.
Edited by SYNSTR 2011-01-27 12:19 PM
