warm states Az Tx
Posted 2010-10-02 2:20 PM (#70816)
Subject: warm states Az Tx
Sat I just walked away from my vision and was thinking the air deflectors that are up front under the mirrors. What id you swapped sides you know put the left on the right and the right on the left I wounder how much it would change the heat you feel.
I am in minnesota and its 53 today so I can't tell if it would do any good.
Has any body tried this???
Minnow
Posted 2010-10-02 2:35 PM (#70817 - in reply to #70816)
Subject: RE: warm states Az Tx
Sparta, WI
Yep, that works but only if you ride your bike backwards.
Posted 2010-10-02 8:46 PM (#70838 - in reply to #70816)
Subject: Re: warm states Az Tx
cabin fever is already setting in.
hey minnow - I was just in sparta last week, ate breakfast at the stagecoach and hung out at fort mccoy. I'll be making a repeat performance the end of October, but I won't be riding, but I'm open to meet others and talk Vision. I know there are other Vision riders in your neck of the woods also, where is the dealer?
chesshiretuna
Posted 2010-10-03 7:45 AM (#70857 - in reply to #70816)
Down here in the warmer states, we love the heat. For most of us there is no problem.......now when it gets in the low 50's we start talking heated gear.......
hmd520
Posted 2010-10-03 10:03 PM (#70917 - in reply to #70816)
Tucson , AZ
You can add all the deflectors you want. It still is hot air coming off the oil cooler, which is creating all the heat you feel. You need to redirect all the heat from the cooler in order to get rid of the heat on your legs.. working on it now. Still in R&D.. will post as soon as i have the results. I live in AZ so trust me its hot. Plus i like to wear shorts when i ride.....
Posted 2010-10-03 10:25 PM (#70919 - in reply to #70816)
...I must have the "coolest" Vision around...
