Microphone windsock suggestion
candubrain
Posted 2010-07-01 2:13 PM (#63516)
Subject: Microphone windsock suggestion
Kincardine, Ontario, Canada
I find the black foam windsock that comes standard with the Nolan Ncom system useless.
Can someone recommend a better cover that will reduce the wind noise?
rebel715
Posted 2010-07-01 2:16 PM (#63518 - in reply to #63516)
Subject: Re: Microphone windsock suggestion
Winchester, Virginia
If you are using a full faced helmet put the microphone directly in the center of the chinbar and close the vent if you have one. As far as a 1/2 faced helmet, I haven't seen much that will block out a 60-70MPH windblast.
Posted 2010-07-07 10:24 AM (#63968 - in reply to #63516)
Subject: RE: Microphone windsock suggestion
http://www.cyclegadgets.com/Products/product.asp?Item=WD
CoolHandLuke
Posted 2010-07-07 1:23 PM (#63978 - in reply to #63968)
, FL United States
Ronnie, thanks for the link.
candubrain
Posted 2010-07-07 2:39 PM (#63985 - in reply to #63968)
rdbudd - 2010-07-07 10:24 AM
great link thanks
vic2004-08
Posted 2010-07-07 4:39 PM (#63992 - in reply to #63516)
Lusby,Md
I called cyclegadgets to find out what these things are made of,the guy I talked to really couldn't say.Is it a soft rubber or hard plastic and does it work?
Posted 2010-07-08 11:47 AM (#64050 - in reply to #63992)
vic2004-08 - 2010-07-07 4:39 PM
They are made out of some sort of plastic, fairly hard. They just slip over the foam windsock and the friction keeps them on. We find that they do help, especially with the problem of the wind activating the VOX on the intercom. We don't have to talk as loud now, either, because we can lower the squelch level for the VOX. You don't really notice them when they are installed. They were originally meant for the Goldwing market, but work on any system. Just order the right size for whatever headset you are using.
They are not a perfect solution, but they do help. You are going to get wind noise when riding in crosswinds, no matter what you do.
Most of the wind noise comes from the passenger's headset, whether it's a Goldwing or Vision. When I'm riding solo, the sleeves pretty much eliminate the wind noise from my mic, except when in heavy crosswinds, but they help some even then.
stretch1956
Posted 2010-07-13 2:04 PM (#64449 - in reply to #63516)
Fargo, ND
I have the Scala II bluetooth and I have also experienced the wind problem. When I took off the foam windsock I noticed there was two sides to the mic. Both sides had voice slits on them. I covered the outside mic slits with black electrical tape and put the foam back on. It solved my problem. If yours has the came configuration then this might help.
Stretch
Edited by stretch1956 2010-07-13 2:04 PM
candubrain
Posted 2010-07-13 5:38 PM (#64466 - in reply to #64449)
stretch1956 - 2010-07-13 2:04 PM
Stretch
thanks I'll look into that
