new owner question about the ' big honkers"
speedboy
Posted 2010-05-08 12:27 AM (#59351)
Subject: new owner question about the ' big honkers"
i know, this question seems to have already been asked, and i've read alot of the threads, but it seems often the discussion breaks down to numbers comparing.
i was wondering, with the arlen ness big honkers, is it require to install the larger air intake, or the tuner? can the pipes just be installed onto a stock bike, with the prospect of eventually adding these (or something comparable) items in the near future. is there any chance of causing damage to the engine as a result of running just the pipes? is a re-mapping required, and if so can my dealer do it, will he have the mapping i need?
i'll appreciate any imput or direction, thanks.
mkultra
Posted 2010-05-08 5:59 AM (#59358 - in reply to #59351)
Subject: Re: new owner question about the ' big honkers"
Tucson, AZ
I had the Honkers installed at purchase on my 08. They put the performance air filter on and did a stage one re-map that i had for awhile. Now have the Andrews cams and power commander but your dealer will have everything necessary for the Honkers.
mike
speedboy
Posted 2010-05-08 1:25 PM (#59390 - in reply to #59351)
i called the dealer, you were right, thanks.
Posted 2010-05-08 1:32 PM (#59391 - in reply to #59351)
keep in mind the air flows through the engine, if you open up one, it is best to open up all, and of course comes the remap. Just a general statement to keep as a rule of thumb, change the exhaust will need a change in intake.
