HID headlight
tylerdang
Posted 2009-10-19 9:08 PM (#46236)
Subject: HID headlight
Has anyone had the HID headlight quit working? Is it covered by original warranty or the extended. 30K on it & have had to replace the infamous high beam headlights. By the way my wrench did the headlights in 45 minutes & cost $140 for the bulbs & installation. Didn't see any blood on him after or didn't hear any foriegn language.
Any feed back is welcome
IndyVision
Posted 2009-10-20 8:24 AM (#46247 - in reply to #46236)
Subject: Re: HID headlight
My HID as hasn't hardly worked in 2 yrs. I bet it's been out over half the time since I've had the bike. The dealer is an hour away and I'd rather ride than have the Vision in the shop.
Crawford
Posted 2009-10-20 9:28 AM (#46248 - in reply to #46236)
Regina Saskatchewan Canada
I run my HID all the time and haven't had any problems.
Posted 2009-10-20 11:35 AM (#46258 - in reply to #46236)
Subject: RE: HID headlight
Same here.  Two years, 34K, on 100% of the time.
Mudge
Posted 2009-10-20 11:37 AM (#46259 - in reply to #46236)
20 miles west of Chicago.
Easiest things first.First, look into the headlight housing and check that the tubular reflector which wraps around the HID bulb hasn't fallen off and is not laying in the bottom of the housing. Second, remove the aluminum bridge panel on the top of the tank area in which the HID switch is located, (Look for the additional small screw on the left side of the panel, in addition to the 4 obvious ones.) Check that the HID wire which snaps on to the bottom of the HID switch has not worked loose or fallen off entirely. If so, plug it back in to the bottom of the switch. Third, pull the air filter and reach up behind the HID light, pull the rubber boot, and make sure the wire/plug is fully seated. Fourth, check the fuse and or relay.
Lotzafun
Posted 2009-10-20 2:42 PM (#46279 - in reply to #46236)
Rockford, IL
Since the HID bulb is on the bottom it is pretty easy to get at, especially if the air filter is removed.
candubrain
Posted 2009-10-20 3:47 PM (#46284 - in reply to #46279)
Kincardine, Ontario, Canada
Lotzafun - 2009-10-20 2:42 PM
You require to remove the entire headlight assembly as the HID bulb is held in place by 2 screws.
Major undertaking
Lotzafun
Posted 2009-10-20 5:26 PM (#46295 - in reply to #46284)
Rockford, IL
candubrain - 2009-10-20 2:47 PM You require to remove the entire headlight assembly as the HID bulb is held in place by 2 screws. Major undertaking
Oh CRAP....you are 100% CORRECT !!!
Completely forgot about that stupid strap thingie.
Yup...a MAJOR PITA job.
