Run-Turn-Brake Kuryakyn style
witchbiker
Posted 2009-08-15 2:24 PM (#41657)
Subject: Run-Turn-Brake Kuryakyn style
Has anyone had any issues with the Run-Turn-Brake kit, after having cut the two wires under the seat that control the brake lights with the turn signals on? The two wires I'm speaking of, are the ones you cut that go to the relay to make the brake lights shut off when you are turning with the directionals on. After you cut the wires to the relay, the second set of brake lights will stay on as you are turning with the directionals on, for better visibility.
In other words, does the Kuryakyn kit affect the way the regular brake lights work if the relay wires have been cut??
Chrome isn't a color, it's the way life should be..........in Maine!!
witchbiker
Posted 2009-08-19 9:03 PM (#42026 - in reply to #41657)
Subject: RE: Run-Turn-Brake Kuryakyn style
Thanks for the responses on my question!!
wrr1home
Posted 2009-08-19 9:36 PM (#42028 - in reply to #42026)
I've had no problem, before or after I cut these wires!
outdoordave48
Posted 2009-08-28 5:04 PM (#42685 - in reply to #41657)
Subject: Re: Run-Turn-Brake Kuryakyn style
Eau Claire WIS. 09 vision
no the kurky kit controls the lights on the trunk only to work with the other lights dave
