Posts: 495 Carrollton, TX | Can someone post all the information the on-board computer and dashboard will display? This would include the settings you can click through with the button on the left handlebar. I remember someone posting this earlier but after many search attempts I could not find it.
Many thanks,
Craig
Midnight Cherry Tour Premium on order
Posts: 354 20 miles west of Chicago. | Time, gear position, ambient temperature, milage (either trip or total milage), fuel range, average MPG, current fuel economy, trip time, "and other trip information", as selected by the MODE button.
Can change between English and Metric. Fuel gauge, speedometer, odometer, tachometer. Indicator lamps; Neutral, gear position, high beam, check engine, turn signals, low fuel, low oil pressure.
Edited by Mudge 2007-12-23 9:13 PM
Posts: 495 Carrollton, TX | Thanks Mudge, I appreciate it very much!
Craig
Mudge - 2007-12-23 8:08 PM
Can change between English and Metric. Fuel gauge, speedometer, odometer, tachometer. Indicator lamps; Neutral, gear position, high beam, check engine, turn signals, low fuel, low oil pressure. |
