High & Low Beams At The Same Tme?
Lotzafun
Posted 2009-03-17 1:26 PM (#30378)
Subject: High & Low Beams At The Same Tme?
Rockford, IL
Was wondering if it was possible to wire our bulbs up so that when the high beams are activated the low beams also stay on?
I know there are some possible drawbacks to doing this. Such as....
Overloading the alternator
Overloading the headlamp wiring harness
Overloading the headlamp switch
Heat build up causing issues with the headlamp lens
And I might be missing a few drawbacks.
But...are these actually drawbacks or not? I mean...can this modification be done without needing to worry about these drawbacks?
Use a relay or two? Seperate circuit?
Need an electrical guru to jump in and figure the numbers here. If the numbers all work I'm willing to be a guinea pig and take the risk...with a bit of guidance.
Posted 2009-03-17 3:23 PM (#30379 - in reply to #30378)
Subject: RE: High & Low Beams At The Same Tme?
If you look at the warnings in the riders manual it says
WARNING!
DO NOT WIRE THE HEADLIGHT HIGHBEAM AND LOW BEAM TO TURN ON TOGETHER!
THIS WILL ACTIVATE THE DEATHSTAR RELAY!
DEATHRAY WILL DESTROY ANYTHING IN ITS PATH!
WARNING! DO NOT ATTEMPT!
I'm just saying, saying.....
donetracey
Posted 2009-03-17 4:37 PM (#30382 - in reply to #30379)
Subject: Re: High & Low Beams At The Same Tme?
Pitt Meadows, BC Canada
Yah Chris! That's pretty much what happened the first time I drove my Vision at night! I was on low beam with the Driving Light on when I turned onto a darkened highway. The oncomming cars immediately started flashing their lights at me - so I fumbled with the High Beam switch - turned on high beam - and nearly fricken melted the poor bastards.
I turned low back on - but still freaked out cars coming at me. I then turned off Driving Light - which helped - but still got occasional flicker at me. I suspect my low beam is pointed a touch high....
Posted 2009-03-17 5:04 PM (#30384 - in reply to #30382)
I reckon Lotza will get his answer eventually. I don't know what will happen if you wire the two together and I'm just curious as to why, as the highbeam is the brightest I know.
But while we are on the subject, I used to get flashed many times on the low beam and I thought it was the HID. But I adjusted the low beam down a turn or two and run the HID all the time. I've not been flashed since. My only problem I have is on low beam and taking sharp turns like exit ramps I always out run my light, I think I need to install the PIA and turn them out a little.
Wow! The thought just came to me is if you wire the Hi and low together and concentrate the PIA and HID with the headlight on Hi Beam that could destroy a whole city. I think when we were issued the Vision we were instructed to use the powers for good and not for evil.
af goalie
Posted 2009-03-17 5:10 PM (#30386 - in reply to #30379)
Rapid City, SD
varyder - 2009-03-17 3:23 PM
WARNING!
I began reading this thinking there was a valid warning in the manual. Much to my amusement I realized it was all in fun. Thanks for the laugh.
Digby
Posted 2009-03-17 7:24 PM (#30387 - in reply to #30386)
Just imagine vision lights on a truck............... Hit the high beam and leave barbequed critters all the home. Don't forget the sauce.
KansasGuardsman
Posted 2009-03-17 11:07 PM (#30408 - in reply to #30378)
Wichita, Kansas
Had me going for a second there too. I was amazed they would put something like that in the manual!!
On a serious note, however, there doesn't appear to be an electrical safety issue, but it made me look at the wiring diagram and realize that Victory took a novel approach to the light switches. The handlebar switch only controls the left light. The right light is powered off of the "headlight switching relay." So, the wiring should take it. But, the bulb is designed to dissipate the heat generated at either 55 or 60 watts. Jumped together, it would have to handle 115 watts, which is well over the design rating. That would also increase alternator load by about 10 Amps and push total headlight load to near the 20 Amp breaker rating. BUT, if you have driving/fog lights, all bets are off. The driving/fog lights also run off the right side low beam power, so now you have enough to blow the breaker. An interesting note to those with, or considering, the driving/fog lights, the driving lights go off when you switch to high beams, or shut off the HID light.
My guess is that if you jumper high and low together, you get a very short bulb life with probable heat damage to the connector and/or housing. If those parts are priced like other parts on the bike, that would be very ugly.
Lotzafun
Posted 2009-03-18 2:39 PM (#30437 - in reply to #30378)
Rockford, IL
Thanks for the fun replies !!! I've actually referred to my HID lamp as a Photon Torpedo.
But...on to Guardsman's answer....
The load on the alternator is an additional 10 amps. I think the alternator could handle this increase. But if other high current things like driving lamps or heated clothing or trailer wiring are added then the alternator would be getting into a possible overload. Correct?
As far as the heat build-up issue. Well when it comes to the connectors they are fairly thick plastic, not like the cheap flimsy ones that used to be found on some of the foriegn vehicles. Being in the collision industry I know about headlamp sockets a bit, the sockets on the Vision are good sockets and I think they can easily handle the heat. And if by chance the sockets did melt they would be very easy and cheap to replace. So how about the headlamp housing? Well I've had mine out and apart and become somewhat intimate with the design of it. They use a fairly thick plastic that I really doubt would have any possibility of melting or distorting under the headlamp bulb heat. There are a couple of members here who are running HID headlamp bulbs without any heat issues.
So the "weakest link" here is the headlamp bulb. Correct? A possibility of having a shorter bulb life? I'm willing to take this risk. Especially since I've replaced the crappy stock bulbs with Sylvania Silverstars, which have a 1 year warranty against failure.
So I guess it appears that I'm going to go ahead and be the guniea pig on this. Yea, I guess you could say that my mind was made up prior to my starting this thread. I wanted to get some feedback before I did though.
So what wires would need to be jumped?
Lotzafun
Posted 2009-03-18 2:47 PM (#30438 - in reply to #30378)
Rockford, IL
Edit: Double post
Edited by Lotzafun 2009-03-18 2:48 PM
Posted 2009-03-18 6:12 PM (#30444 - in reply to #30378)
Lotzafun,
What part number Silverstars are you using? How are they holding up?
Ride Safe!
spursmvp
Posted 2009-03-18 8:13 PM (#30449 - in reply to #30384)
O'Neill, Nebraska
varyder - 2009-03-17 4:04 PM
Man this is funny. Just remember...."Luke I am your father!!!"
Lotzafun
Posted 2009-03-18 9:16 PM (#30456 - in reply to #30378)
Rockford, IL
Teach-
I don't think there is a Sylvania "part number" persay. Just simple H4 bulbs, sometimes referred to as 9003 or HB2 bulbs. Should be available at almost any auto parts store like PepBoys, Autozone, O'Riellys, etc...
As far as holding up I've only been running with them in the Vision for a few days now. However I've always used Silverstars for sveral years in all of my vehicles and bikes and I can say that I've never had a single issue with thier performance and I had one issue with durability, had a bulb blow about eight months after installation, popped it out and stopped by the place I purchased it from and they tossed me another one under warranty...no questions asked.
Lotzafun
Posted 2009-09-09 2:02 PM (#43613 - in reply to #30378)
Rockford, IL
I kinda back-burnered and forgot about this idea of mine. Figured I'd bump it and see if anyone figured out or could figure out which wires in the headlamp switch would need to be connected/jumped.
donetracey
Posted 2009-09-09 2:25 PM (#43615 - in reply to #30378)
And again - I will ask "Why?"
You just like melting things? Like your headlight? Wiring? The guy comming toward you?
Dimonback
Posted 2009-09-09 2:47 PM (#43618 - in reply to #43615)
Here is the front end of a Vision, from an oncoming drivers point of view, with the high, low, and drivers beams clearly visible:
Edited by Dimonback 2009-09-09 2:49 PM
(get off my lawn.jpg)
Attachments get off my lawn.jpg (53KB - 1 downloads)
KansasGuardsman
Posted 2009-09-09 7:38 PM (#43634 - in reply to #30378)
Wichita, Kansas
Lotza –I still think this is bad juju, but, I hate it when somebody answers a question I didn’t ask, and you didn’t ask if I thought this was a good idea.  So here goes.
I’ve looked over the wiring diagram again and tried to give it some real thought, since you seem to be serious about this. There is too much interconnect and not enough working room to get everything jumpered down in the guts of the bike.  Also, the low/high beam switch switches the left light directly so the current will slightly more than double.  Also, when switching light bulb power you have to consider the surge current.  When light bulbs first turn on, they draw more current – a LOT more current.  The filament then heats up fast and starts drawing less until the temperature and current reach a point where they stabilize.  In aircraft we estimate a factor of 6 when selecting switches and relays.  That means a 10 Amp load (both beams of one light since one is on the switch and the other is on a relay) would require a 60 Amp switch.  The switch on the handlebars is nowhere near that.  In fact, thinking about it, it doesn’t even appear big enough to really handle one beam at 5A (30A design).  BUT, the beams aren’t switched that much over the life of a typical bike so the reduced life was obviously judged to be acceptable by Victory.
I’ve had the tupperware off to replace the lights, so I’ve seen the working area once removed.  If I was going to do this I would only do one side first – there’s less to repair that way.  I would cut the high beam wire (green) of the left light near the headlight, leaving enough wire to easily reconnect things, and insulate the hot (bike) end with self-sealing electrical tape, Then I would cut the low beam wire (yellow), again leaving enough room to rework it, and splice all three wires together with a good splice – this thing will have to carry about 10 Amps reliably.  The wiring won’t  have a problem since 10A only requires 18 AWG wire.  I would then remount the headlight and make sure the switch was on low beam, and leave it on low beam.  The relay for the right side light is always switched so that’s why I would use the left light and not switch it low/high – to not put the switching load on it during the experiment., to reduce the switch load.  Then turn on the bike.  You shouldn’t have to wait long.  Starting the bike will make things happen faster since that will push the system voltage up to about 14 VDC upping the current (and heat) a bit more, and not run down the battery.
What will happen?  Thinking about it deeper than last time, I think the weak spot is the size of the bulb – physical size.  A halogen bulb runs so hot already that they have warnings about skin oil weakening the glass on the package.  An aircraft landing light is high intensity and about 10 times the size of our bulbs, and they have a rated life of only about 25 hours – and that’s at rated power, not double.  In home use, a 150 Watt bulb is much bigger than 75 Watt bulb.  That’s because with more waste power, it would get too hot to dissipate all that heat if it was the same size.  I think the same thing will happen to the headlight bulb, only faster since it’s smaller.  It’s not designed to get that hot.  My guess is burn out in about three minutes, tops.  Heat will be intense, so I still think there is a good chance of damage to the connector and housing also.  I would definitely leave everything apart and let it run for at least 30 minutes before I considered it a success.
If it really does work, you will have a dual beam on the left, which will go OFF when you hit the high beams.  The right side should continue to work normally so it’s a safety in a way – you will always have access to a working headlight.  And, adding that second side will only net you about a 30% increase in light (4 filaments instead of 3), which is about a 15% increase in perceived brightness (square law), so it really wouldn’t be worth it.
OK.  I know we’ve got a few guys here that can review this.  What say ye (about the method, not the idea – we’ve already beat that up)?
Oh, yeah.  And have the video camera running when you turn it on.  Either way it should be good viewing.
Edited by KansasGuardsman 2009-09-09 7:39 PM
ElroyJ
Posted 2009-09-11 6:22 PM (#43780 - in reply to #30387)
Centennial, CO
Digby - 2009-03-17 5:24 PM
Ha ha! OMG...you all have me rolling over here! Thanks! I haven't had a good laugh on a forum in a long time!
Lone Ranger
Posted 2009-09-12 10:21 AM (#43820 - in reply to #30378)
Cleveland, GA
Actually I found what seems like a way to see what it looks like with everything lit up - last night when my brights were on, I started to hit my low beams, but changed my mind and only put a very slight pressure on the switch. I noticed that more light came on - the low beams. I released pressure and it went off. So I THINK that this lights up the low beams before the high beams cut off. It didn't make much difference in the light out there, though. If this is what you get, it wouldn't be worth the hassle, IMO. (Of course, the HID was on at the time, too, so the world was pretty bright to begin with).
clubford00
Posted 2009-09-12 11:37 AM (#43822 - in reply to #30378)
Buffalo Grove,Ill
I was talking with the guys that put my amp in at ABT electronics in Glenview , Ill. and for 400 bucks i can convert the high and low beams on my Vision to ALL HID. So i would have the small round HID but also the others as well. SOOO as soon as i have a spare 400 bucks ill be like a locomotive going down the road lighting up the world .
