bike quit going down hiway
sonicbluerider
Posted 2019-05-25 5:46 PM (#192839)
Subject: bike quit going down hiway
, IA
what would cause the R coming on the screen when driving!! it flashes while driving!!! #2 where is the fuse for the reverse an what does it look like. battery ok fuel pump charges. thanks though if I disconnect the fuse reverse would become disconnected an maybe bike would run!!!
sonicbluerider
Posted 2019-05-26 6:56 AM (#192840 - in reply to #192839)
Subject: Re: bike quit going down hiway
, IA
anyone know if I unplug that 6/8 wire connector plug on my reverse if that will take it out an allow me to run bike without reverse!!! asking first cause it's a @#$%& to get at!!!
sonicbluerider
Posted 2019-05-26 4:26 PM (#192841 - in reply to #192839)
, IA
books says there's 25 amp fuze!! darn CAN'T find it!!going nuts
Posted 2019-05-28 1:28 PM (#192842 - in reply to #192839)
have you looked in the 2 fuse boxes. Might be under seat on right hand side
BumbleDB
Posted 2019-05-29 12:01 AM (#192844 - in reply to #192839)
Reverse is an add-on so the fuse isn't in the boxes. Hmmm... don't know how to add a pic from the shop manual,
but the text is:
Reverse module is located between the left inner
saddlebag and the frame. Fuse (A) is attached.
Shows to be right around the abs valve block.
sonicbluerider
Posted 2019-05-29 7:14 AM (#192845 - in reply to #192839)
, IA
I gave up ! hiring tow truck to take to shop!! oh an shop said they never heard of such a problem!! so ill let you all know!!!
sonicbluerider
Posted 2019-06-05 8:57 PM (#192848 - in reply to #192839)
, IA
how they are saying may be ecu
Edited by sonicbluerider 2019-06-05 8:59 PM
lennyb
Posted 2019-06-08 7:51 AM (#192849 - in reply to #192839)
Perry Hall, MD
Electronic problems are the worst! Sorry
Copyright © 2007-2023 Victory Riders Network™
