Throttle Body Synchronization
TommyGun
Posted 2018-12-17 10:51 AM (#192762)
Subject: Throttle Body Synchronization
Mossyrock, WA
How come there is no mention of proforming any adjustments? They can?t stay perfectly synced forever. Don?t even recall seeing a routine time in the service manual.
blackpearl
Posted 2018-12-22 12:51 PM (#192767 - in reply to #192762)
Subject: Re: Throttle Body Synchronization
Aww. What are you trying to sync? There are no carbs, it's fuel injected.
TommyGun
Posted 2018-12-30 8:11 AM (#192770 - in reply to #192762)
Mossyrock, WA
Fuel injection doesn?t have anything to do with it. You have 2 independent throttle bodies with their butterflies linked together. Somewhere there has to be a idle air bleed opening on each body. The fuel injector computer (ecu) meters the time the injector is open, throttle position and a few other things. All other bikes that I have worked on that had carbs or fuel injection that had independent throttle butterflies linked together had somewhere to check the vacuum on each cylinder and some type of adjustment.
So if you could, explain your answer in a little more detail so I can understand how the system works.
Posted 2018-12-30 10:34 AM (#192771 - in reply to #192770)
I don't think the Victory has any individual adjustment. The two throttle bodies are housed in a common body, with the two throttle butterflies linked together with a non-adjustable link. A single Idle Air Valve meters idle air to both equally.
There are no adjustment instructions in the Victory manual because there is no adjustment needed. This is not a four cylinder bike with four individual throttle bodies. It is a V-twin with one throttle body containing two butterflies linked together with a non-adjustable link.
You are chasing a non-existent problem.
TommyGun
Posted 2019-01-03 11:52 PM (#192773 - in reply to #192762)
Mossyrock, WA
Thank you Ronnie, that was the answer I was looking for. I was just doing winter maintence and just wanted to make sure I wasn't missing something
