Check Engine Light
PhantomX
Posted 2018-04-20 6:31 PM (#192500)
Subject: Check Engine Light
Land O Lakes, FL
Does anyone know how to get the code when the check engine light comes on? I?ve got a 2017 Vision and the light just popped on today but when i scroll through the menu i don?t get any codes. Not sure if I need to do some special combo to get the code to show up?
Posted 2018-04-21 2:13 PM (#192503 - in reply to #192500)
Subject: Re: Check Engine Light
The code should shot up on radio screen. Don't remember but if you start it more then 5 times the code will disappear.
Some time the light will come on with loose battery bolt. Put lock washers on each bolt 1/4 inch size. Use 10mm wrench to check them your
hand will lie to you
PhantomX
Posted 2018-04-21 4:34 PM (#192504 - in reply to #192500)
Land O Lakes, FL
No code showed up anywhere. Just got a bright red engine light on. I think I?ve probably started it at least that many times and it?s still on. I did tighten the battery cables down for sure though. Do you know how to clear it without the Victory software and computer?
lennyb
Posted 2018-04-21 8:35 PM (#192505 - in reply to #192500)
Bel Air, MD
Looks like the Victory software is probably the only way to get the code and know specifically where to look. Without it I would follow the basic guide found in the manual that poor or corroded connections are the most common cause of system faults. It suggest checking the integrity of the male pins and female receptacles of the connectors in the affected circuit. With no code it just means checking and cleaning every connector. Hope it is that simple and that you pick the right one early.
PhantomX
Posted 2018-04-22 12:35 PM (#192506 - in reply to #192500)
Land O Lakes, FL
So no way to clear them out?
lennyb
Posted 2018-04-24 12:11 PM (#192509 - in reply to #192500)
Bel Air, MD
not sure if someone with the right tech savvy can suggest a work-around, but it looks like the code will clear when the problem it senses has been resolved
feel your pain - I have to admit to refusing to pay dealer to clear a warning on a car once and I removed the idiot light bulb instead
Copyright © 2007-2018 Victory Riders Network™
