Starter removal
boatsrfun
Posted 2018-04-15 4:56 PM (#192478)
Subject: Starter removal
I Need to repair or replace my starter on my 08 vision. Do I have to remove the front exhaust pipe and/or the lower frame support? If I remove the starter bolts will I be able to drop down it enough to remove it?
Edited by boatsrfun 2018-04-15 4:59 PM
(VIC-BIKES.jpg)
Attachments VIC-BIKES.jpg (41KB - 0 downloads)
Rainmans 09
Posted 2018-04-15 8:19 PM (#192479 - in reply to #192478)
Subject: RE: Starter removal
This is the starter removal instructions in the maintenance manual.
(Starter Motor.jpg)
Attachments Starter Motor.jpg (56KB - 0 downloads)
Posted 2018-04-16 1:53 PM (#192480 - in reply to #192478)
Subject: Re: Starter removal
just the exhaust I believe. You might have to smack the starter with a rubber hammer to get it to come loose.
Say there are some videos on youtube generations are the same. Take old bearings to a bearing store they'll have some good one.
Automobile electric repair shop can rebuild the starter better then new they might have brushes too.
boatsrfun
Posted 2018-04-17 7:07 PM (#192481 - in reply to #192478)
Having a b... of a time getting that front pipe off. I'm thinking of cutting the clamps that hold the chrome cover on then I can hit it with a soft mallet.It does wiggle a small amount. The starter works but has been making a howling sound. If I ever get it out I plan to take it to a local shop that does specializes in starters etc.
Snow is almost gone so gotta get this and a rear tire done!
Edited by boatsrfun 2018-04-17 7:10 PM
Posted 2018-04-18 7:19 PM (#192492 - in reply to #192478)
hardware stores sells stainless hose clamps cut it
boatsrfun
Posted 2018-04-18 7:24 PM (#192493 - in reply to #192478)
finally got the exhaust pipe off with a lot of fighting and wiggling. Starter is out, now to take it to a shop for rebuild.
Thanks for advice.
Posted 2018-04-19 1:14 PM (#192499 - in reply to #192478)
Hope you tell us what they found. Photos would be great
boatsrfun
Posted 2018-04-20 8:10 PM (#192501 - in reply to #192478)
Picked up the starter today. $76. Replaced brushes bearings and cleaned. Now that the snow is almost gone gotta get it back in.
Posted 2018-04-21 2:08 PM (#192502 - in reply to #192478)
Hope it spins over twice as fast for you
