Arlen ness big honkers
92cmark
Posted 2017-08-23 12:54 PM (#192183)
Subject: Arlen ness big honkers
Is anyone running these Big Honkers on your Vision?
Posted 2017-08-23 6:18 PM (#192184 - in reply to #192183)
Subject: Re: Arlen ness big honkers
yes if you can find them
92cmark
Posted 2017-08-23 7:57 PM (#192187 - in reply to #192183)
Just wondered what they sound like? The damn dyno tune cost as much as the pipes. pipes on order .I had Lloyd put a supercharger on wanted stock pipes. now it is time to change
BumbleDB
Posted 2017-08-23 9:00 PM (#192188 - in reply to #192183)
I put a set on to replace my rotted S1 mufflers. They're pretty loud. Basically just a megaphone, I can look into the end and see the cat-converter.
kin52
Posted 2017-08-24 4:44 PM (#192192 - in reply to #192183)
Subject: RE: Arlen ness big honkers
Louisville, KY
I have them on mine and like them a lot. The baffle perforations are only about one third as long as the stock mufflers. Loud but not too loud. if you baby the bike you can keep it pretty quiet.
92cmark
Posted 2017-08-26 10:55 AM (#192195 - in reply to #192183)
well they are here now so I will wait for the tuner. I'm hoping he gets the same results as before 186.95 hp and 164.94 tq.
kin52
Posted 2017-08-27 7:24 AM (#192196 - in reply to #192195)
Louisville, KY
those are great dyno results! What all have you done to your motor?
I went to the Variable pressure plate from Lloyds to stop the clutch slipping. You might need the same with those numbers.
92cmark
Posted 2017-08-27 7:33 AM (#192197 - in reply to #192183)
Lloyd put a supercharger with all that i needed. He will take care of you.
cw1115
Posted 2017-08-31 12:00 PM (#192206 - in reply to #192183)
Ruskin, Fl
I had Big Honkers on my 2008. Loved them!!
92cmark
Posted 2017-09-02 10:30 AM (#192209 - in reply to #192183)
well waiting on tuner to get a hold of Lloyd for some info.Man i can not wait,to make some noise!!!!!
lova
Posted 2017-09-25 3:23 PM (#192272 - in reply to #192183)
Big honkers on my Vision 8 ball - also running the Maximus, camz air both air intake
I really like the sound - it has great low sounds
twocell
Posted 2017-09-25 7:31 PM (#192274 - in reply to #192183)
Lackawaxen PA United States
how is the Maximus working out ... as simple as it's advertised??
lova
Posted 2017-10-02 3:10 PM (#192284 - in reply to #192274)
i wish i had the maximus installed long time ago - it really makes a BIG difference. BlackMamba is running very smooth, nice idle and it's pulling hard throughout the RPMs. It will lift front wheel on 1st gear.
twocell
Posted 2017-10-04 7:36 AM (#192286 - in reply to #192183)
maximus & cams here I come
Hoagy
Posted 2018-02-28 11:16 PM (#192445 - in reply to #192183)
I bought my 2014 vision from Arlen and had the big honkers,filters and super tuner installed at 500 miles.The honkers are loud and I recently made it sound alot deeper and not as rasspy by taking 2 aftermarket harley mufflers trumpet tapered style cut off about a foot slid them into the wide open end of the honkers and used the stock muffler mount on the pipe and attached it to a 10mm bolt on the bottom that holds the stock tip.Sounds amazing.Sort of like the glasspack retro some guys do but no taking apart the whole exhaust to do.
Edited by Hoagy 2018-02-28 11:19 PM
