Stage 1 (2)
Gray rider
Posted 2008-12-15 9:40 AM (#25069)
Subject: Stage 1 (2)
Tucson, AZ
Sorry for not being up to speed on this, but I've only had my V for a little over a month and I'm still in the learning process. I have my stock pipes on now, but have installed the factory high flow air cleaner. Is remapping required for this mod?
TIA
Posted 2008-12-16 6:50 PM (#25145 - in reply to #25069)
Subject: Re: Stage 1 (2)
if you increase air you Must increase fuel or you will risk damage to your engine. If ou purchase a stage 1 or stage 2 it will come with the air filter you just purchased..
Posted 2008-12-16 6:51 PM (#25146 - in reply to #25069)
sonicbluerider
Posted 2008-12-18 9:13 AM (#25243 - in reply to #25069)
, IA
i guess its best to ask a dealer cause i asked that same ?? about my vegas and was told no problem i wanted to put a reusage k/n filter and chrome air vent on, stock pipes, was told no remap was needed
kevinx
Posted 2008-12-18 5:54 PM (#25264 - in reply to #25069)
If you just added a filter without any other mods you do NOT need to remap. Without also changing the exhaust; the injection can cope with the small percentage of change in flow
sonicbluerider
Posted 2008-12-19 9:22 AM (#25287 - in reply to #25069)
, IA
thanks i needed to know that and for sure your the MAN
Posted 2009-01-05 9:36 AM (#26107 - in reply to #25069)
if you put a k&n air filter on a stock already lean mixture would you loose a little power since the bike is already lean from the factory and you increase more air. or can the close looped system adjust for the increase in air? i keep forgetting this is a close looped system
Rebel
Posted 2009-01-06 10:57 AM (#26177 - in reply to #26107)
Linwood, MI
Arkainzeye - 2009-01-05 9:36 AM
Yes. Well, yes to a certain extent. With stock, unmodified exhaust you will be fine.
kevinx
Posted 2009-01-06 12:39 PM (#26182 - in reply to #26107)
the clossed loop is good for about a 5% variance, and the filter would not make a change anywhere near that. The bike will only draw as much air as it can use, and with a restricted exhaust you are not increacing demand by that much. Switching to a free flowing exhaust greatly changes the demand for air, and that is where you start running into mixture issues. Most often not mapping a bike with an open exhaust will give you a rich running bottom, and a lean top when looked at with a moniter. With a restricte filter[stock] that condition is somewhat redducedd at the top do to it limiting the available air for the mixture, and subsequentlly making it richer
