Checking your radio software and hardware version
Rebel
Posted 2008-12-15 9:26 AM (#25068)
Subject: Checking your radio software and hardware version
Linwood, MI
Several times I've spent a lot of time trying to track down the thread for someone that told how to check what your audio sw/hw version is. Now that it was finally reposted in another thread it reminded me to come post it here for easy reference.
To find your audio hardware and software version you need to get into the Radio System Diagnostic menu on your radio. To do this, follow the instructions below.
1. Turn the ignition switch to ACC and turn the radio off (Victory Motorcycles is shown on display)
2. Turn ignition switch OFF.
3. Turn ignition switch back to ACC.
4. PRESS & HOLD the #1 preset button and MODE button while turning the radio power ON.
5. The diagnostics mode is entered. Press MODE to toggle through the diagnostic funtions. To exit diagnostics press Power button.
NOTE: A "Watchdog Error Cleared" message will occasionally appear as the first thing displayed. This can be ignored, it is an internal software notification.
6. The first screen shows the radio software (SW) & hardware (HW) revision.
7. The second screen is used to check buttons and button wiring circuts related to the radio / com. system. The display contains two lines of "Zeros". Each location corresponds to a radio button on the radio, handlebar switches, or passenger switches. A (0) represents a button not being pressed. A one (1) represents a button being pressed. If a "1" appears at an address in the upper or lower row of the radio display the button and circuit wiring are funtioning correctly.
8. The third screen shows Tuner location, which will always be set to USA.
9. The forth screen list the status of the radio amplifier.
10. The fifth screen displays vehicle speed. This can be used to test if the radio is receiving the vehicle speed CAN message from the PCM. It could also be used to test for a faulty CAN bus connection to the radio. If the speedometer is working but the radio is showing zero speed, it has no CAN connection.
11. If there are no accessories installed on the vehicle, the display will go back to the first screen. If accessories are installed, there are additional diagnostics screens for each accessory, showing the SW & HW revisions, etc.
--- Originally posted by Spock. Thanks, Spock!
