Left over wire!!
Yuma48
Posted 2008-11-15 9:00 PM (#23360)
Subject: Left over wire!!
San Diego, California
I installed the Garmin Tourtech today and have a wire left over. It's a single blue wire on the left side while sitting on the bike. I checked out the components and I think it's for the HID light. Anyone have a wire manual?
wjoel
Posted 2008-11-15 10:03 PM (#23364 - in reply to #23360)
Subject: RE: Left over wire!!
Northeastern Penna.
Looking in the service manual, I don't see a blue wire for the wiring /lighting circuit.As a matter of fact,there is no color blue wire in the diagram.
wjoel
Posted 2008-11-15 10:06 PM (#23366 - in reply to #23360)
Northeastern Penna.
Maybe the left turn signal ?
Yuma48
Posted 2008-11-15 10:25 PM (#23374 - in reply to #23364)
It's attached to the two big bundles attached to the switches receptor. It's the only single wire in the whole setup
clubford00
Posted 2008-11-16 1:26 AM (#23384 - in reply to #23360)
Subject: Re: Left over wire!!
Buffalo Grove,Ill
It might be a wire for a remote relay.
jama
Posted 2008-11-16 1:44 AM (#23386 - in reply to #23360)
Arkansas
One of the grip heater switch wires is blue. I think brown goes to the front, and blue to the rear. The power wire with the white plug goes to the third terminal at 90deg angle to the others. The first two wires have black plugs if I recall correctly.
rmclarty
Posted 2008-11-16 12:35 PM (#23399 - in reply to #23360)
Agree it could be the Grip Heater. I draw a color code of the wire placements everytime i remove the console, because Alzheimers seems to be setting in and I am a visual person.
Also - You sure it is not the Aux connector for an IPod cable or Aux plug?
Yuma48
Posted 2008-11-16 6:39 PM (#23418 - in reply to #23386)
Thanks, that's it!! From San Diego to Arkansas, I'm grateful.
