drive line issue
jimtom
Posted 2016-01-30 6:11 AM (#177485)
Subject: drive line issue
Sand Rock, AL United States
yesterday, leaving work, I got a half mile away , slowed for a turn and going through the gears to get back up to speed, the bike hesitated for a split second then stopped pulling and started a knock down low. Not a motor knock in sync with the motor revolutions but intermittent . I got it to limp back into my work parking lot. The motor is totally fine. I'm thinking my drive pulley is keyed to the output shaft and the key is sheared. What do you guys think. It was late in the evening , cold and dark so I got my wife to come get me and I "drove" to work for the first time in 15 years to address the issue once it's daylight.
jimtom
Posted 2016-01-30 6:45 AM (#177486 - in reply to #177485)
Subject: RE: drive line issue
I have learned the pulley is spline mated not keyed. Thanks to Kevin Cross. I will check it later today.
Posted 2016-01-30 6:27 PM (#177496 - in reply to #177485)
Subject: Re: drive line issue
check the wear of your belt.
jimtom
Posted 2016-02-01 5:23 AM (#178523 - in reply to #177496)
belt was fine. Tech thinks it's the clutch (original also) will know more today.
jimtom
Posted 2016-02-01 8:06 AM (#178526 - in reply to #177496)
tech just called. it's the countershaft bearing. Parts won't be bad, labor will be! What to do?
new bike ? fix old bike? I don't know
Edited by jimtom 2016-02-01 8:07 AM
Posted 2016-02-01 8:22 AM (#178527 - in reply to #177485)
Yikes. If it's paid for, new bike, part out. Still owe, fix! In the scheme of things, you may be able to get the parts and fix it yourself. Chances are though, the dealer has it torn down to the point of replacing, so he's already accomplished a lot of labor, so you'll still owe something.
jimtom
Posted 2016-02-01 8:42 AM (#178528 - in reply to #178527)
It pays off in June. I still have a feeling it's time to start looking for a replacement. local independent tech (ex-Victory service manager struck out on his own) has it but he hasn't gone too deep. I can pay him for the roadside assistance and what labor he has done and start shopping. store it until the day I can repair it.
Posted 2016-02-01 5:52 PM (#178533 - in reply to #177485)
wonder what they have to do to replace countershaft bearing
jimtom
Posted 2016-02-01 7:35 PM (#178534 - in reply to #178533)
pull the motor and split the cases.
Posted 2016-02-02 5:59 PM (#178565 - in reply to #177485)
<p>yup used motor will be cheaper</p><p> </p><p>http://pinwallcycle.com/product_info.php?products_id=144117&osCsid=lg34ebdb7949jhd5n6a8qs4an6</p>
Edited by johnnyvision 2016-02-02 6:01 PM
Posted 2016-02-02 6:02 PM (#178566 - in reply to #177485)
http://pinwallcycle.com/product_info.php?products_id=144117&osCsid=...
Posted 2016-02-02 8:03 PM (#178568 - in reply to #177485)
ouch
jimtom
Posted 2016-02-03 5:08 AM (#178569 - in reply to #178566)
I ordered an engine yesterday off ebay out of an 09 . It has diamond cut fins. Coming from Indiana . Estimated to be at my local shop on or before Tuesday.
Posted 2016-02-03 5:47 PM (#178583 - in reply to #177485)
gee if it has diamond cut fins I would guess it has cams. You might need a PCV
jimtom
Posted 2016-02-03 9:12 PM (#178586 - in reply to #178583)
that would be a nice surprise.
wingit3611
Posted 2016-02-04 12:04 PM (#178596 - in reply to #177485)
Diamond cuts were Arlen Ness stuff. Does that mean that the Arlen Ness engines all have cams in them.
jimtom
Posted 2016-02-04 12:11 PM (#178597 - in reply to #178596)
wingit3611 - 2016-02-04 12:04 PM
no they Ness models didn't come with cams. The thinking is that if someone went to the trouble to remove the motor for diamond cut fins they might go ahead and install cams. Not absolute just a possibility that it might have cams.
