Clutch lever
PrkChps
Posted 2015-07-08 4:26 PM (#173253)
Subject: Clutch lever
Hi everyone. Loving the new Vision Tour, but there is one thing I am wondering about. I find the clutch squeeze pressure to be a little bit heavier than I like. (Arthritis in the left hand is acting up.) I am wondering if there is an adjustment or other modification to ease the squeeze a bit? I do a lot of riding in the friction zone, and find it hurts after a while. Any fixes? Thanks!
Edited by PrkChps 2015-07-08 4:27 PM
Posted 2015-07-08 5:29 PM (#173254 - in reply to #173253)
Subject: Re: Clutch lever
there is nothing.
If you have arthritis and can't handle the hydraulic clutch go to dealer and try a cable clutch pull that might be easier
Pops
Posted 2015-07-08 8:49 PM (#173257 - in reply to #173253)
Georgia On My Mind.... United States
What about the Doctor's Easy Clutch?
http://buywitchdoctors.com/p/2551/victory-motorcycle-parts-clutch-c...
PrkChps
Posted 2015-07-08 9:06 PM (#173258 - in reply to #173253)
Easy Clutch says permanently out of stock. I will see if they can adjust the friction point to a little closer to the grip. If not, I will work through it. It's just a flare-up, so I am sure I can work through it.
Posted 2015-07-09 5:51 PM (#173279 - in reply to #173253)
eze pull does not work with hydraulic clutch. There is No adjustment
