Do you need extra lighting for a lay-down license plate on a Vision?
bek
Posted 2015-04-10 10:52 AM (#171750)
Subject: Do you need extra lighting for a lay-down license plate on a Vision?
, KY United States
Was just wondering if I can use the stock light with a lay-down plate. Would love to get the cheap one from Noemtz, screw it in, and just go. But someone online said the plate would not be visible with only the factory plate lighting.
Has anyone done this? If so, was your plate visible?
nailer
Posted 2015-04-10 11:26 AM (#171752 - in reply to #171750)
Subject: RE: Do you need extra lighting for a lay-down license plate on a Vision?
Albuquerque, NM
I bought a similar lay down plate from HMD and since the both use the stock mounting screws, mine lays directly over the light. I had to remove the light lens and tie the license led wiring into the light wiring harness. No easy way of routing the wiring other than between the V-panel or the light lenses. Use heat shrink tubing to protect the wires.
bek
Posted 2015-04-10 11:37 AM (#171753 - in reply to #171752)
, KY United States
Ah, thanks nailer. Was afraid that's how it would work.
Posted 2015-04-10 12:21 PM (#171755 - in reply to #171750)
Subject: Re: Do you need extra lighting for a lay-down license plate on a Vision?
Yep; I have the same issue. I've bought the LED light put just haven't made a bracket to install it yet; over the license plate:
Edited by willtill 2015-04-10 12:21 PM
Posted 2015-04-10 7:00 PM (#171761 - in reply to #171750)
this is what I used. I did file a little slot in clear lens and wired into light wire. The LED is bright
https://www.denniskirk.com/custom-dynamics/chrome-led-license-plate-...
JustBob
Posted 2015-04-10 8:57 PM (#171764 - in reply to #171750)
-This is what I have used on ther bike, http://www.amazon.com/silver-license-plate-light-bolts/dp/b004v4eng...
These are LED bolts which shine out the side, and they look very good.
icemann
Posted 2015-04-10 11:31 PM (#171766 - in reply to #171750)
, OH
Making it too difficult. Get a $9.99 strip of ribbon led and put it on the face of the plate itself around the outer edges.
Then take your plastic chrome looking lic plate frame cover.
Turn Your license plate frame bracket over and put a drill bit on its side. Make drill sized groves on the back side of the lic plate frame where each led is. (Rears the center removing a bit of plastic lip).
PUT a Teflon washer between the lic plate and the lic plate frame.
Those notches will allow the LED to shine up into the back side of the lic plate frame and out each notch you made towards the center of the plate. Thus a Glowing plate.
Note. Make the notchs towards the inside or middle area not the outer edge. Light will illuminate plate by glow yet now around the outer edge.
A dremmel works too. Run wires to back side. Think ice cream sandwich
Edited by icemann 2015-04-10 11:37 PM
(IMG_20150411_003244.jpg)
Attachments IMG_20150411_003244.jpg (45KB - 0 downloads)
icemann
Posted 2015-04-11 12:16 AM (#171767 - in reply to #171750)
, OH
This is kinda crude photoshop but you get the idea.
(tag2.jpg)
Attachments tag2.jpg (114KB - 0 downloads)
icemann
Posted 2015-04-11 12:27 AM (#171768 - in reply to #171750)
, OH
Or you can pick up this ultra thin type LED panels that are kinda flexible for $3.99. about 5 inch long. 1/16 thick.
Peel and stick, water proof. Ultra-thin 6W COB Chip is what its called
Edited by icemann 2015-04-11 12:29 AM
(led2.JPG)
(led4.JPG)
Attachments led2.JPG (34KB - 0 downloads)
Attachments led4.JPG (28KB - 0 downloads)
bek
Posted 2015-04-17 3:02 PM (#171924 - in reply to #171750)
, KY United States
Wow, many great ideas. Thanks, guys.
JS5Owner
Posted 2015-04-26 3:05 PM (#172124 - in reply to #171750)
Have you seen this? http://www.vision-riders.com/bb/forums/thread-view.asp?tid=10311&st...
