Upgraded Air Shock on Vision
landscape88
Posted 2015-03-19 7:05 PM (#171338)
Subject: Upgraded Air Shock on Vision
Anyone try an aftermarket air shock on a vision. Can't seem to get rid of the jolt when bike hits what I call a small bump. Either single 200# or with a 100# passenger. Tried different air pressures with not much improvement
Posted 2015-03-20 5:42 PM (#171355 - in reply to #171338)
Subject: Re: Upgraded Air Shock on Vision
<p>so how much air are you using. 70psi maybe</p><p>inside the saddle bag is a chart </p>
Edited by johnnyvision 2015-03-20 5:51 PM
landscape88
Posted 2015-03-20 7:59 PM (#171362 - in reply to #171338)
I'll check on weekend, it's an 8 Ball Vision.
swmckinley54
Posted 2015-05-06 2:37 PM (#172270 - in reply to #171338)
Austin Texas Yaaaalll
Take a look at the top of the shock (you have to take your seat off) and make sure the bolt holding the shock to to the frame isn't sheared off. Mine was and I had that exact same problem.
Posted 2015-05-06 5:15 PM (#172277 - in reply to #171338)
how much air in your tire
Posted 2015-05-07 4:30 PM (#172301 - in reply to #171338)
8ball Visions use a smaller shock than the Vision Tour. It is the same as the Ness and has 1" less travel. One option would be to replace it with a Tour shock. I have been considering this as well. There is a little confusion on the Victory website though, it looks like the newer bikes have all gone to the same size shock and have changed the "dogbone" length to get the different ride height now. You may have to get a shock off an older bike.
Posted 2015-05-07 6:12 PM (#172308 - in reply to #171338)
8 ball shock 2010 p/n 7517988 link rod p/n 2877612
vision tour 2014 p/n 1542903 link rod stayed the same.
in 2010 Vic mid year changed the shock to p/n 1542903.
I'm sure you could find someone willing to trade with you. Maybe even me
landscape88
Posted 2015-05-07 7:57 PM (#172313 - in reply to #171338)
So the current shock on Vision Tour is the same length or longer as I thought the rod lowered the 8 Ball one inch. I will first pull off seat and check for a sheared bolt. If it is longer travel length I am sure that could be an option to soften the ride with more travel.
MaddMAx2u
Posted 2015-05-13 8:51 PM (#172412 - in reply to #171338)
Orlando, FL
Never had an issue with bumps on my 8 Ball. I weigh 200 and ride single 90% of the time.
