Vision Windshield Removal
Speterson1
Posted 2015-01-24 9:00 AM (#169560)
Subject: Vision Windshield Removal
Broomfield, CO
Any tips on removing a Vision windshield? I've removed all the bolts but it seems like it's glued on.
mokintner
Posted 2015-01-24 10:37 AM (#169562 - in reply to #169560)
Subject: Re: Vision Windshield Removal
Austin, IN United States
Give it a little bump. Not to much of a bump.
trshooter
Posted 2015-01-24 12:16 PM (#169564 - in reply to #169560)
Tumbler Ridge, BC Canada
It shouldn?t be glued if wiggling back and forth doesn?t work. Then use a nylon bar for windshields or dash removal .
ByteN2it
Posted 2015-01-24 6:52 PM (#169565 - in reply to #169560)
To late for this tip-put masking tape over the nuts to hold them in place and also there are small O Rings on either side of the windshield that are easy to loose if your not careful.
Speterson1
Posted 2015-01-25 9:11 AM (#169567 - in reply to #169560)
Broomfield, CO
I figured it out so I thought I'd share what I learned. Turns out there is a rubber gasket/washer at each bolt hole between the windshield and the mounting bracket. This gasket has a small amount of adhesive on both sides. Once I heated each bolt hole using my wifes hair dryer I was able to get the windshield off with a small amount of prying just using my fingers.
The new Ness windshield looks awesome; hope to get her out on the road today!
Turk
Posted 2015-01-26 9:02 AM (#169578 - in reply to #169567)
Speterson1 - 2015-01-25 9:11 AM
Did they change the design?
