airbox baffles???
steve76t
Posted 2013-10-05 10:17 PM (#146264)
Subject: airbox baffles???
I'm getting ready to install one of Lloydz Top Filter's, along with other goodies, in my 2013 Vision. I should have my parts here on Monday & I'm just getting a jump a couple days early.
Anyway, I talked with a tuner in California a couple weeks ago & he said he typically removes the rubber baffles from inside the frames of Vision's that he sets up and tunes. Anyone else do this? I've taken the top plate off & took the baffle out, but before I get my parts and install them, I wanted to see what others do. Once the top filter is installed is there even a need to remove this baffle?
Oldman47
Posted 2013-10-05 11:37 PM (#146265 - in reply to #146264)
Subject: Re: airbox baffles???
Central Illinois
Lots of folks pull that rubber strip. It gives a bit more air flow but at the expense of being noisy.
steve76t
Posted 2013-10-05 11:45 PM (#146266 - in reply to #146264)
Hi Oldman, on the Vision it's not a rubber strip like they have on the Cross bikes. There are two rubber cone baffles inside the frame on Vision's. One is accessed from under the top plate and the other is directly behind the front filter.
Boots
Posted 2013-10-06 12:07 AM (#146268 - in reply to #146264)
New Mexico
I think this is what you are talking about
http://www.Vision-riders.com/bb/forums/thread-view.asp?tid=9411&pos...
Posted 2013-10-06 1:46 PM (#146287 - in reply to #146264)
in 2010 they put a air directional rubber above the throttle body's to force more air into the throttle body's and cut down on air noise.
yes pull it
Turk
Posted 2013-10-07 9:20 AM (#146347 - in reply to #146287)
On my 2011, there are TWO rubber/plastic air restrictors, one accessible from the front as pictured above, and one accessible (so I'm told) from the throttle body access plate. The front one seems to allow about 4 times more air flow than the one accessible in front of the TB's. The latter has a single hole in it's center, and there doesn't appear to be any funnel affect to it. Next time I have occasion to pull the console, I'm going to see how difficult it is to pull that rear plug out.
Posted 2013-10-07 6:47 PM (#146363 - in reply to #146264)
The front one really helps to direct air back leave it alone. Pull the top one will get more air to the throttle body
steve76t
Posted 2013-10-07 11:07 PM (#146380 - in reply to #146264)
Thanks Johnny! I've got the rear baffle removed but am leaving the front one alone.
steve76t
Posted 2013-10-07 11:10 PM (#146381 - in reply to #146347)
Turk - 2013-10-07 7:20 AM
Yes the rear baffle is accessed through the top plate & is super easy to remove. It just pulls right out with very little effort. Might take a whole 15 seconds once you have the top plate off.
Turk
Posted 2013-10-08 7:42 AM (#146389 - in reply to #146363)
johnnyvision - 2013-10-07 6:47 PM
I'm wondering if I pull that rear baffle, that it will provide enough additional airflow that I won't need to put the filter back, and instead, put the oem cover back on ?
Anyone running without the rear baffle, and the stock cover plate instead of a filter?
kevinx
Posted 2013-10-08 2:59 PM (#146401 - in reply to #146389)
Turk - 2013-10-08 8:42 AM
The 08s with the front baffle removed, and no re baffle to start with. Benefited from having a top filter. Just need more air then available through the front filter
