Timing wheel
JustBob
Posted 2013-09-24 7:39 PM (#145865)
Subject: Timing wheel
 I got my timing wheel from Lloyds and it came with nothing other than the gasket, no literature or install guide.  anyone have the aforementioned items?
Oldman47
Posted 2013-09-24 7:42 PM (#145866 - in reply to #145865)
Subject: Re: Timing wheel
Central Illinois
Open the plastic package that contains the wheel. That tiny bit of paper inside is the instruction sheet.
JustBob
Posted 2013-09-24 8:05 PM (#145868 - in reply to #145865)
there is no paper with the wheel.
Rammurry
Posted 2013-09-24 8:36 PM (#145869 - in reply to #145865)
Subject: RE: Timing wheel
Bob
Do you need some help? There are other posts that go through the install. Do a search. If you cant find it let me know and I will run you through it.
Posted 2013-09-25 7:12 PM (#145914 - in reply to #145865)
you need to unbolt floor boards two bolts 5/16 size.
put rag over pipes so you don't scratch chrome
Take out oil dip stick and plug with rag 5mm tee handle take out all 6 allens very gently pull cover off and carefully of pick up on cover
If gaskets falls a part clean off with razor blade 17mm socket un do center bolt and wiggle gear off with hands.
If need to use pry bar do a little on each side place new wheel in place and torque bolt to 17 foot pounds. use screw drive between teeth and catch motor bolt.
Drop of blue loctite is good put on new gasket if needed wipe oil off timing cover gasket area slid on and tighten bolts in x pateren. Hand tight is good put floor board back on clean up and ride
Posted 2013-09-25 7:13 PM (#145915 - in reply to #145865)
here are photos
(005.JPG)
(005.JPG)
(006.JPG)
(009.JPG)
Attachments 005.JPG (39KB - 0 downloads)
Attachments 006.JPG (177KB - 0 downloads)
Attachments 009.JPG (55KB - 3 downloads)
JustBob
Posted 2013-09-25 7:47 PM (#145919 - in reply to #145865)
Thanks for the offer, Isearched the forum found a coupla pic, and managed to get'er done.  will let yall know tmorrow what it does for the bike.   Hardest part of install was getting the floorboard back on while fighting swarms of skeeters.
Rammurry
Posted 2013-09-25 8:19 PM (#145923 - in reply to #145865)
Bob
Good to hear. Have fun.
Oldman47
Posted 2013-09-26 6:22 AM (#145941 - in reply to #145865)
Central Illinois
I have had mine for about 2 weeks and am considering pulling the cover and advancing the timing some more. Since I have the reusable gasket I will only need to pull the floorboard and cover then loosen the adjustment screws and make my changes. After that it is a simple reassemble and be done. I started with an uber conservative 3 degrees and am thinking I need to go to 5 or 6 degrees and see how things work. Worst case, I get a ping and need to revert to 3 or 4 degrees.
wfsdno
Posted 2013-09-26 10:30 PM (#145977 - in reply to #145865)
What kind of improvement are you guys seeing with the timing wheel? Low end power? Top end? More Grunt? MPG?
Thanks, Roger
Posted 2013-09-27 6:48 PM (#145990 - in reply to #145977)
wfsdno - 2013-09-26 10:30 PM What kind of improvement are you guys seeing with the timing wheel? Low end power? Top end? More Grunt? MPG? Thanks, Roger
you'll find out you spent your money the right way. You go to 65mph in no time very smooth and it works past that to. You will pick up a little mileage cause the motor is not working as hard. Great help for two up riding to. Less to none popping. Make sure you buy the gasket cause you never know if the old one will stay in place.
You will not be disappointed
Only read one complaint were he was getting to good of gas mileage and that was cause of the air filter.
Oldman47
Posted 2013-09-27 9:35 PM (#145998 - in reply to #145865)
Central Illinois
I got low end grunt to be sure and I have some minor gas mileage improvement too. If you can stay off the throttle you will find better all around performance but that can be hard to do. The engine just wants to run well for you.
JustBob
Posted 2013-09-28 12:49 AM (#146003 - in reply to #145865)
Well after a coupla days, and I have to say it was money well spent. I willbe having the bike dyno-tuned sometime in the next week or so, but o a seat of the pants dyno it woke the bike up.....a lot!
wfsdno
Posted 2013-09-29 8:07 PM (#146045 - in reply to #145865)
Darn it guys!! Now I HAVE to buy one! Guess I'm in.
Thanks for the responses.
Roger
Oldman47
Posted 2013-09-29 9:30 PM (#146047 - in reply to #145865)
Central Illinois
If you get the wheel, don't forget to buy a gasket. When I did mine the gasket came off in several pieces, including the pieces that I had to scrape off the cover and the pieces that I had to scrape off the casting.
steve76t
Posted 2013-09-29 11:17 PM (#146049 - in reply to #145865)
Thanks to threads like this one, I've just order my Timing Wheel along with a top filter and the VFC3. Can't wait to get the parts and get 'em installed.
wfsdno
Posted 2013-09-30 9:48 PM (#146071 - in reply to #145865)
Got mine ordered today! Went whole hog and got the gasket too!
rldr12
Posted 2013-10-08 10:28 AM (#146396 - in reply to #145865)
Citrus Heights, CA United States
Installed timing wheel and vfcIII a few weeks ago and all I can say is WOW The motor comes alive. Put bike on Dyno this past weekend and the numbers are beyond impressive.
Posted 2013-10-08 7:25 PM (#146404 - in reply to #145865)
So you going to tell us the numbers?
