Front turn signal issue
lstayner
Posted 2013-08-15 1:20 PM (#143011)
Subject: Front turn signal issue
I have an intermittent issue with the right front turn signal switch. For some reason when I hit the turn signal it won"t flash but will stay solid lit sometimes for a couple minutes and other times for quite a while. I tried spraying contact electrical cleaner in the switch area thinking it might just be dirty. Didn't seem to help much. I also sprayed a silicone spray on the switch because it was a bit stiff.
Anybody have this problem and how did you fix it?
Oldman47
Posted 2013-08-16 7:50 PM (#143065 - in reply to #143011)
Subject: Re: Front turn signal issue
Central Illinois
It sounds like you have a flasher that is not working.
