remove rear tire
jbrad
Posted 2013-07-25 7:10 PM (#142091)
Subject: remove rear tire
Vandalia, mo.
How high does vision have to be to remove wheel
Posted 2013-07-25 7:40 PM (#142092 - in reply to #142091)
Subject: Re: remove rear tire
I put mine on the 2nd notch on the sears motorcycle jack. To pull the swing arm push rod bolt and the axle the wheel is on the ground where there is no stress, then raise it to pull the wheel out.
Posted 2013-07-25 7:41 PM (#142093 - in reply to #142091)
not that high maybe 8" make sure you loose axle first. Do you have a jack
ByteN2it
Posted 2013-07-25 8:09 PM (#142096 - in reply to #142091)
Taking 'em off is pretty easy, I usually go about a foot. The trick to putting them back on easily is to have a second small scissor jack to support & lift the rear wheel into position so you can slip the axle through.
Edited by ByteN2it 2013-07-25 8:09 PM
jbrad
Posted 2013-07-25 8:57 PM (#142099 - in reply to #142096)
Vandalia, mo.
I do have a jack, just don't want to get it apart and not be high enough to get the wheel out. It seems from these answers that it doesn't need to be very high
Eric
Posted 2013-07-25 9:27 PM (#142105 - in reply to #142091)
Duanesburg N.Y.
I hung mine from my engine hoist about a foot give or take, losen the lower shock bolt and take it out which helps. the tire and wheel will pretty much fall out one the axel bolt is removed. i set the new tire in my floor jack to help hold it in to position when i had to allign every thing back up
LA Victory Rider
Posted 2013-07-26 1:48 PM (#142118 - in reply to #142091)
Monrovia, Ca
Once I am set up with the right tools and jack, I can have the old one off, max 10 minutes using a impact wrench.
On the re-install, I push a 18"x 1/2" extension in from the right side after getting everything lined up. Then take a rubber mallet and tap it out with the axle. Piece of cake.
Edited by LA Victory Rider 2013-07-26 1:51 PM
LRojas
Posted 2013-08-05 6:23 AM (#142551 - in reply to #142091)
Gulfport, MS
so the bags don't have to come off? Anyone ever do a video for changing the tire?
marcparnes
Posted 2013-08-05 9:01 PM (#142597 - in reply to #142551)
LRojas - 2013-08-05 4:23 AM
It's much better with the bags off. You can get at the lug bolts much easier!
Marc
