lloydz timing won't start
RichZ
Posted 2013-07-13 5:41 PM (#141564)
Subject: lloydz timing won't start
San Francisco
Before I put back original wheel.Any suggestion what went wrong with install.
The bike won't start.
I have a 09 with ness big honkers and ness big shot.
Thanks in advance for any help
Rammurry
Posted 2013-07-13 5:52 PM (#141565 - in reply to #141564)
Subject: RE: lloydz timing won't start
Rich
Did you pinch the wires to the pick up? Did you get the wheel lined up to the key way and seated all the way on?
Does it turn over?
Did you disable the kill switch?
RichZ
Posted 2013-07-13 6:07 PM (#141566 - in reply to #141564)
San Francisco
It was pinched wires.Hope it didn't kill the sensor.
Thanks
Rammurry
Posted 2013-07-13 6:16 PM (#141567 - in reply to #141564)
Rich
Glad you found it. Hope it doesn't cause you any problems. If the sensor is not shorted out and the insulation is broken make sure you keep the wires from shorting or it will fail in the future. Good luck!
Rick
Posted 2013-07-13 6:49 PM (#141568 - in reply to #141564)
Subject: Re: lloydz timing won't start
check red switch on bars
Pinched wires on cover
pull cover look every thing over
gear should make no difference if thats all you did.
what ells did you do does the fuel pump run do you have lights
Posted 2013-07-13 6:50 PM (#141569 - in reply to #141564)
Did you lock tight all the bolts
RichZ
Posted 2013-07-13 7:47 PM (#141572 - in reply to #141569)
San Francisco
Wires on crank sensor frayed new one on order.
Thanks for the help everyone.
baadawg
Posted 2013-07-14 9:47 AM (#141593 - in reply to #141564)
Chattanooga, TN
Glad you got it sorted out, too bad about the sensor cause they can get expensive.
XRsteve
Posted 2013-07-14 2:00 PM (#141605 - in reply to #141564)
Georgia, west of Atlanta
Lets us know how the re install goes. Wire looks like it goes behind the front wheel drive sprocket and along the right side of case.............
RichZ
Posted 2013-07-21 3:11 PM (#141929 - in reply to #141564)
San Francisco
New sensor in and she is alive again.Took about four hours for the whole job.Was not fun getting the front sprocket cover bolts out.Did not want to remove or loosen the exhaust.
Thanks again for the advice.
baadawg
Posted 2013-07-21 9:02 PM (#141939 - in reply to #141564)
Chattanooga, TN
Glad you didn't have to remove the exhaust, since that requires the right side of the fairing to be removed. Glad to hear its all good now.
