PCV Install Help!!!
adirondacks
Posted 2012-04-12 7:20 PM (#112065)
Subject: PCV Install Help!!!
Troy, NY
Hello - I tried to update the firmware of the PCV and had some issues doing so. So I had to take out the PCV and send it to Dynojet. They updated the firmware and sent it back. I am almost done putting the PCV back in the Vision. The hard part is done, reconnecting everything back to engine area. Do the two connectors that are part of the PCV, that is in the back were the ground goes, get connected to the Vision?
Posted 2012-04-12 8:57 PM (#112080 - in reply to #112065)
Subject: Re: PCV Install Help!!!
http://www.powercommander.com/downloads/19-006/install/pcv/eng19-00...
adirondacks
Posted 2012-04-12 9:09 PM (#112081 - in reply to #112065)
Troy, NY
Yeah - I had the install guide. Been reading over and over. It appears section 17 indicates yes. I wanted to double check with someone that has installed the PC V. I am a novice when it comes to this stuff.
rebelce
Posted 2012-04-13 7:57 AM (#112091 - in reply to #112065)
I'm getting ready to install my PCV/Autotune as well. The Autotune has power in/ ground wires but the PCV does not. Where does the PCV get it's juice?
bolt62
Posted 2012-05-17 5:55 PM (#114490 - in reply to #112065)
Subject: RE: PCV Install Help!!!
Just got a PC-V and auto tune for my 08, going to install this weekend. Question is how much of the front did everyone take apart to get to the injector wiring, book says it can be done without but my big mitts can hardly get to the back one let alone the front?
Posted 2012-05-17 6:20 PM (#114495 - in reply to #114490)
bolt62 - 2012-05-17 5:55 PM
NONE.. i removed nothing from my vision(s) other than the seat and the part in front of the seat and the 2 little panels under the seat.. Nothing from the front was removed...
