Pictures or video of VFC III install on Vision?
meangreen88
Posted 2012-03-17 9:46 PM (#110313)
Subject: Pictures or video of VFC III install on Vision?
Hi all,
I have a 2008 Vision I bought used a few months ago. What an amazing bike! I believe it has the stage 1 treatment on it so I'm adding the VFC III. The problem I have is the instructions. I'm a visual guy and I'm embarrassed to say I'm stopped very early in the process. When I got the top panel and seat off, I could see the first O2 sensor well enough (grey wire with red stripe?). But then it tells me about the left panel and I just couldn't see what it described on how to remove it to find the other sensor. I found a video on youtube but it didn't show the install, just talked about the product.
Is there anything out there visually to help me or can someone describe a little better what I need to do? I would really appreciate the help. I've searched the forums but have not had any luck.
Thanks!
Posted 2012-03-23 3:11 PM (#110700 - in reply to #110313)
Subject: Re: Pictures or video of VFC III install on Vision?
Just to close this out, I forwarded a note about this to lloyd and I understand that he then contacted meangreen.
Posted 2012-03-23 5:25 PM (#110709 - in reply to #110313)
behind the rear cylinder are two push in pins that you prie out the little center pin then prie out the big one. Now you can open the left saddle bag and you can pull the left panel off trace the wire and un plug it. As for the front you have to trace the wire down to the bottom of the left side. It can be a bitch to get at so do what you have to I found the wire and hooked it with a coat hanger and pulled it out and un hooked it. <font size="7">BUy the way I looked and did NOT find a pcv111 for a vision</font>
Edited by john frey 2012-03-23 5:27 PM
RhodeTrip
Posted 2012-03-23 6:56 PM (#110713 - in reply to #110313)
Rhode Island
meangreen88, go into the control panel and fill out your location; you might find someone in your area that can help you out. I know Jeff posted Lloyd had contacted you about this; but for future questions.
Jim
