Garmin Zumo 665
cryptodogg
Posted 2011-11-03 3:48 PM (#100624)
Subject: Garmin Zumo 665
Georgia
Where is the best place to mount the antenna???
Pics if you have any to share.....thanx in advance.
Posted 2011-11-03 4:02 PM (#100625 - in reply to #100624)
Subject: Re: Garmin Zumo 665
I had it under the front 'batwing' but it's metal on the 2010 and was getting lousy reception. Now it is velcro'd to the dash below the windscreen. It will eventually go into the 'dash bag' whenever that gets made.
ScoreBo
Posted 2011-11-03 4:12 PM (#100629 - in reply to #100624)
Northeast Ohio
I velcro'd mine to the top of the front brake fluid reservoir and velcro tie-wrapped the cable to the existing cables and ran it down under the center console. I want to be able to easily take it off and use it in my truck. Having weather radar and traffic in anything you drive is great. Mounting it more permanent would require ANOTHER XM subscription (the XM ID is tied to the antenna / puck).
cryptodogg
Posted 2011-11-03 4:34 PM (#100631 - in reply to #100624)
Subject: RE: Garmin Zumo 665
Georgia
I'm thinking that my front windshield access panel is plastic (haven't removed it to verify)....if it is then would it be OK to put it under that area? The new ant is better looking than the old one but still quite large.
Turk
Posted 2011-11-04 8:24 AM (#100663 - in reply to #100631)
I plan to pick up my 665 today directly from Garmin's HQ for $800. Unless someone has a source significantly cheaper ?
I'll be selling my 660 and my separate Victory XM radio.....
marcparnes
Posted 2011-11-04 9:01 AM (#100669 - in reply to #100663)
Turk - 2011-11-04 5:24 AM
$800 is full retail. AMA members get a 20% discount. You might want to check and see if that program is still in effect. That's how I bought mine.
Marc
Posted 2011-11-04 9:46 AM (#100677 - in reply to #100624)
http://g.factoryoutletstore.com/details/36428/Zumo-665.html?chid=10...
marcparnes
Posted 2011-11-04 9:56 AM (#100678 - in reply to #100677)
Nozzledog - 2011-11-04 6:46 AM
http://g.factoryoutletstore.com/details/36428/Zumo-665.html?chid=1000&cid=5662
Be careful, that's not a new unit but an "overhauled" one if you care.
Marc
Edited by marcparnes 2011-11-04 9:58 AM
Turk
Posted 2011-11-04 10:05 AM (#100680 - in reply to #100669)
marcparnes - 2011-11-04 9:01 AM
Marc
20% off directly from Garmin?
marcparnes
Posted 2011-11-04 10:09 AM (#100681 - in reply to #100624)
Yep, that's how I bought the last two of them. It's an AMA benefit. If you aren't an AMA member this would be a good reason to sign up today and then buy it. But first check and make sure it is still in effect.
Marc
marcparnes
Posted 2011-11-04 10:16 AM (#100682 - in reply to #100624)
Here is a link to the Garmin AMA page . I'm still not sure if its still effective.
Marc
ScoreBo
Posted 2011-11-04 10:36 AM (#100683 - in reply to #100624)
Northeast Ohio
I couldn't get it to take my AMA number. It tells me Invalid member number when I am 100% positive it is correct.
Turk
Posted 2011-11-04 10:45 AM (#100684 - in reply to #100683)
ScoreBo - 2011-11-04 10:36 AM
Same thing happened to me.
I called the AMA.. they say that Garmin dropped their affliliation with the AMA a couple months ago.
Edited by Turk 2011-11-04 10:49 AM
marcparnes
Posted 2011-11-04 10:48 AM (#100685 - in reply to #100624)
Maybe its not a valid program anymore. That would be a bummer :-(
Marc
ScoreBo
Posted 2011-11-04 12:19 PM (#100691 - in reply to #100624)
Northeast Ohio
I got my Zumo 665 from Amazon for $745 (new).
http://www.amazon.com/Garmin-zumo-Widescreen-Motorcyle-Navigator/dp...
g1nomad
Posted 2011-11-06 8:21 AM (#100797 - in reply to #100624)
SC, Bluffton
cryptodogg - 2011-11-03 3:48 PM
You don't have to have an antenna unless you want the XM function.
If you just want the GPS and MP3 functions, you need not worry about
mounting an antenna.
Herb
Posted 2011-11-07 12:57 AM (#100855 - in reply to #100797)
g1nomad - 2011-11-06 6:21 AM
Herb
No sense wasting all that money on the 665 then, get a 660.
I velcro'd the puck to center of the dash below the winsheild. The wire runs to the side and behind the instrument bezel, then pops back out and plugs into the connector which I ran up thru the blank switch panel next to the HID switch.
When I want to move it to another vehicle, the only thing that has to come off is the instument bezel, and it pops off easy.
It will look much better inside a 'Dash Bag'.
Edited by Nozzledog 2011-11-07 1:21 AM
(2011-11-069523.04.12.jpg)
(2011-11-06_23.03.23.jpg)
Attachments 2011-11-069523.04.12.jpg (52KB - 2 downloads)
Attachments 2011-11-06_23.03.23.jpg (45KB - 0 downloads)
