Full LED Conversion
Jump to page : 1 2 3
Posted 2009-12-07 12:31 PM (#49265 - in reply to #47730)
Subject: RE: Full LED Conversion
Hey Tim,
Itchin to pull the trigger on the amber 92s and get the reds later.  How's the fit?
TimS
Posted 2009-12-07 12:37 PM (#49266 - in reply to #49265)
You and me both.
I called my wrench to pick up my bike on Saturday (new Barnett Scoripion Clutch) and he wanted to keep it over the weekend and follow up with Barnett on Monday.  Being such, I still do not have my Vision back yet.  I should get it back tomorrow if the meeting with Barnett pans out OK.
Sincerely,
Tim
TimS
Posted 2009-12-09 10:36 PM (#49460 - in reply to #49265)
Hi Tom,
I just got the bike home from the wrench.  I just installed a new  7-JuRock Vision windshield for the winter.  My old stock one is scratched up so I will try to polish it out by time spring comes.  The new one is 1.5-2" taller and 4 inches wider at the top.  It does not appear to have any distortions around the edges while driving in the dark.  The wider top will be good for the colder winter months and for the Mrs. on the back.  I have to use it in the daytime to see how it is in the sun.
As for the amber 92 LED bulbs.  The easily fit in the front turn signals.  The trick to get them to fit is to get the harness lower than the lens, start feeding the font edge of the bulb into the lens hole and then lift the back of the harness while inserting.  There is not enough clearance to put them straight in or top down, but there is by tilting bottom up.
The center bulbs fit as well for me since I have removed the speaker shrouds.  I used the same tilt up method of insertion.  If you have the speaker shrouds in, you may have to pull part of the lens to make enough clearance to fit the front running lights in.
As for brightness.  The 92LED bulbs have really tiny LEDs in them, thus their balls of light are smaller than the stock bulbs. They cast a more yellow light than stock which are more amber.  The stock bulbs tend to make wider lines of light in the reflector creases where the 92 LED bulbs make a bunch of narrower lines and dots depending on the viewing angle.  As far as brightness is concerned, I would give the edge to the stock bulbs over these amber 92 LED bulbs, but not by much.  I am going to keep them to regain some of the drain on the charging system.
They make the turn indicator blink twice as fast, which I don't mind.  Funny thing, if you put the turn signal on when the key is in the ACC position, the turn signals flash at their normal speed.  If you have the key in the running position, they flash twice as fast, go figure ???
The stock incandescent bulbs appear to have a little more separation between low and high, but not much.  Again, I think I am going to keep them for the charging system savings.  If I want to make a more dramatic difference on the turn signals, I can rewire my bike's signals to switch from DIM/BRIGHT to OFF/BRIGHT.  This is what I am doing in the tour pack.
These are my initial observations.  I will post more when I have some more time to work on it.  I will also measure the amperage draw of each of the bulbs compared to the stock bulbs to validate the publish specs and amperage draw savings.
HTH,
Tim
Edited by TimS 2009-12-09 10:42 PM
Posted 2009-12-09 11:08 PM (#49462 - in reply to #47730)
Thanks for the update Tim.
I'm glad they fit ok.  I had a feeling about the install from below the opening.  I'll probably make the switch to save the amps and the longlife of LEDs in general.  I notice an obvious difference between how quickly my new 99 LED brake light comes on compared to the stock bulbs in the "V" taillight.  I'll probably hold off until after the the holiday crunch to make the switch, especially since the reds are taking forever to come in.
I've thought long and hard about the flash rate and will probably go with a load equalizer.  Even though I give up the amp savings, it will only be when the turn signals are on.  99% of the time I'll still save amps.  Even though the faster flash rate may be more eye catching, it just makes me think something's not right.  It bugs me when I see a car or motorcycle going down the road with fast blinker.  I think "I'm glad I'm not on the other end of that guy with a burned out turn signal."  I really like the stock flash rate on the new cars equipped with LEDs.  I think your plan to change from DIM/BRIGHT to OFF/BRIGHT is definitely the way to go with max contrast.  I'll be picking your brain on how to do that later.
Man314
Posted 2009-12-12 10:43 AM (#49580 - in reply to #47730)
Subject: Re: Full LED Conversion
TimS or SongFan,
Have you tried these 92's in the tail lamps? Want to make sure clearance/heigth of unit will work. They are a little taller than 3157's. Can't believe the reds are still backordered . . . they say again (for the 3rd week in a row) one more week. Evidently there are production delays. Have you guys found another source for these same 92's?
TimS
Posted 2009-12-12 12:02 PM (#49581 - in reply to #49580)
Man314,
I see you are from Spirit Lake, IA.  Can you do us all favor and drive over to the Victory Plant and ask them to make a BRIGHT OEM Strop/Turn/Hazard/Running Light LED Trunk Lens replacement kit tfor the Vision hat is illuminated the entire width of the replacement lens?  It is really hard to get in contact with anyone over there.
I see the 2010 Cross Roads and Croos Country are now using LEDs versus incondescent bulbs.  They should make a retro-fit kit for the Vision.
I have not pulled the back apart yet to see if they fit and I do not have the red 92 bulbs yet either.
Sincerely,
Tim
Man314
Posted 2009-12-12 1:13 PM (#49583 - in reply to #47730)
Don't think the key decision makers are located on site in the plant, though next time I run across one of their guys in a bar, we'll have a long chat. Many of the execs / engineers / marketing folk do watch the boards. I'd like to see VICTORY light up red as a stop lamp!
Posted 2009-12-12 1:49 PM (#49585 - in reply to #47730)
I haven't bought any 92's yet.  I'm going to wait until they are all in so I can do it all at once.  Most likely after the holiday madness subsides.
I've bought some nice stuff off of a couple of guys on the forum over the last couple of weeks.  Also have the Clearwaters on my short term radar.  Two years of living with a fairly stock looking bike and now I'm making up for lost time.
KansasGuardsman
Posted 2009-12-15 12:08 PM (#49734 - in reply to #47730)
Wichita, Kansas
Tim,
The next time you have the rear lights apart, try reversing the turn signal LED. On the ones I got (older units, not 92's) I put one in reversed and it went OFF/BRIGHT on turn signal but was on LOW for running lights. Made it much more noticeable. The other one worked regularly, i.e. LOW/HIGH on turn signal. I turned it around so they both go OFF/HIGH now.
I left mine flashing fast since the Vision has auto off on the turn signals, so you won't be driving with them on all the time, and it flashes sooner to alert the cagers about my intent.
Posted 2009-12-15 12:47 PM (#49735 - in reply to #47730)
KG,
Thanks for the advice on just flipping the bulbs.  I was wondering how Tim was going to re-wire the turn signals to go OFF/HIGH instead of LOW/HIGH.  All of the high end cars/suv's that have LED's are much more noticable with the OFF/HIGH turn signals.
Edited by SongFan 2009-12-15 12:48 PM
KansasGuardsman
Posted 2009-12-15 10:18 PM (#49762 - in reply to #47730)
Wichita, Kansas
SongFan,
The way I thought the LEDs had to be in the lamp, I expected they would work or not if reversed.  I wasn't expecting the OFF/HIGH thing and just found it by accident.  I hope it works for Tim.
Tim - Let us know if it works for yours. That would a great thing if it did.  They are much more noticeable.
I had a chance to do some research at lunch last week.  The SAE spec J590 calls for flashers to work at 60 to 120 flashes per minute.  The slow rate is 60.  When it senses a burned out bulb (or LED lights), it goes to 120 per minute, which is faster, but still legal.  So it's all in personal preference.  I still don't grok why a few have the flashers quit with LEDs.  It's no worse than losing all but one of your turn signals.  It should work.  But then, given that I'm handsome and smart, I should be rich. Go Figure.
TimS
Posted 2009-12-16 8:15 AM (#49769 - in reply to #49762)
When I put the 92LEDs in backwards, they do not work at all.  I believe LEDs are polar by nature.  If you reverse the leads, they don't light up.  This has been the experience I have had will all of my other LED bulbs, strips and individual LEDs that I have played with so far.
Sincerely,
Tim
KansasGuardsman
Posted 2009-12-16 12:01 PM (#49780 - in reply to #47730)
Wichita, Kansas
Thanks Tim. Apparently it makes a difference which LEDs you have, but it was worth a try. You got the result I expected since the light pins are cross wired and the diodes require polarity. Someday I'll pull mine and try to figure out their wiring, but, it was only 15 when I got home last night so it may have to wait a while!!
Man314
Posted 2010-01-25 7:59 PM (#52064 - in reply to #48871)
Hey guys! The Red 92's are NOW IN STOCK! Ordered by reds and ambers tonight. Damn, they are expensive, but I'm hoping they really light up the back end of my bike!
http://www.v-leds.com/Exterior-LED/Brake-Light-LED/Red-LED/V-LEDS-R...
Posted 2010-01-25 8:21 PM (#52065 - in reply to #47730)
Thanks for the update.  I got tired of waiting and am ordering Clearwaters tomorrow.  Take pics/videos of the difference if you can!
Man314
Posted 2010-01-27 3:48 PM (#52169 - in reply to #47730)
Maybe they wouldn't be so expensive if I didn't order double what I need. Remember boys and girls that these units are sold in pairs, not single bulbs. Good thing I can return them, unfortunately I'll need to pay a 15% restocking fee. Maybe one of these days I'll learn to pay attention before hitting the "Purchase" button. I'll post side-by-side pics when I get installed.
Man314
Posted 2010-01-28 8:58 PM (#52249 - in reply to #47730)
Good news! Although the 92's are almost twice as tall as the 3157's in the tail lamp, they do have plenty of clearance. I'll try to get them in tomorrow to see how much brighter thay are.
TimS
Posted 2010-01-28 11:15 PM (#52253 - in reply to #52249)
Man314 - 2010-01-28 5:58 PM Good news! Although the 92's are almost twice as tall as the 3157's in the tail lamp, they do have plenty of clearance. I'll try to get them in tomorrow to see how much brighter thay are.
Try them in just 1 side so you can do an A/B comparison to the stock incandescent and let us know how they work.
When I did the amber fronts, they made the lens a tad bit whiter (less amber) and were not quite as bright as stock.
Glad to see you finally got them.  Also, tell us how much of a pain it is to replace the rear bulbs.  I have yet to try that yet.
Tim
Man314
Posted 2010-02-07 11:17 PM (#52881 - in reply to #52064)
My Amber and Red 92 LED's came in. I've installed them in my clear lens tail lamps. WHAT A DIFFERENCE! I took some side by side pics, but I'm out of town now on a business trip, so I can't post yet. Whole back end really lights up. Since I had two extra ambers, I tried putting in front turn signals. Clearance was too tight without removing entire lamp. Maybe I'll just leave fronts incandescent. Couple of questions:
- Where is a good spot to tap in to turn signal wiring harness with a load equalizer? I understand there can be some heat. It's blinking too fast for me and my cruise control stopped working after installing LEDs. Hoping this will fix this.
- I now notice that the amber stays on at low power in running light mode. Actually looks cool, but does anyone know if it is legal to have amber running lights on rear. I've seen amber running lights on front and sides of many vehicles, but not on rear. Is there any way of clipping one of the three wires into the socket to eliminate running feature on ambers?
I'll post pics when I get back home.
outdoordave48
Posted 2010-02-08 3:55 PM (#52910 - in reply to #47730)
Eau Claire WIS. 09 vision
no you can't have amber running lights in the rear. what i did is put 92's in the bottom two and got a high power 27 led 3156 which is a single filiment so it only comes on with the turn... i checked with the dot before i ordered, i also asked on the forum but nobody knew for sure, have to wait till spring to know if the cruz will work that way...dave
Man314
Posted 2010-02-08 7:47 PM (#52929 - in reply to #47730)
Bummer on the amber running lights . . . looks kinda cool and when the flashers come on, they are bright enough to overcome the amber running lights. I kinda wondered on rearward facing amber.
Any way of disabling the running lamp feature in the 92 bulb or performing a vasectomy on harness to disable? I know when I was hooking up my Muth mirrors, the turn function in front tapped in to black and blue/red wires . . . seemed green powered running lights on front. Can anyone confirm?
TimS
Posted 2010-02-10 10:58 AM (#53019 - in reply to #52881)
Man314 - 2010-02-07 8:17 PM My Amber and Red 92 LED's came in. .
Can you post the before/after A/B pictures of the rear tail-light lens?  Are the red 92-LEDs brighter than the stock incandescent bulbs in the rear tail light?
Thanks,
Tim
gcarroll70
Posted 2010-02-10 11:11 PM (#53068 - in reply to #47730)
Reston, Virginia
Reading this thread got me excited to replace my rear bulbs with the LEDs. I already did the middle brake light mod so I am not afraid of cutting but it looked easy enough and it worked out fine. Everything I read about and viewed on YouTube about the LED conversion said this is the right thing to do however I did not see where it described how the LEDs make the electrical connection. Does each LED bulb fit the existing bulb housing? Is there an adapter harness that you must buy that makes the interface connection? Or is there splicing involved? Please educate this electrical novice.
Man314
Posted 2010-02-11 4:31 PM (#53117 - in reply to #47730)
LED's are designed to fit the standard socket as a direct replacement. Only think is with the reduced electrical load, it will cause turn signals to flash faster. If I remember right, Arizona Victory did send me different turn signal sockets. Don't know why, but they are standard.
gcarroll70
Posted 2010-02-11 4:47 PM (#53121 - in reply to #47730)
Reston, Virginia
OK. Thanks for your input. I am glad to hear that. Now it is a simple matter of getting to the rear brake light housing.
I dont mind the increased flash speed. It should make it more visible. I think I will start with the rear and see how it looks. Of course, with cagers, it's best to be as noticeable as possible from the rear. I drive in lots of traffic everyday so this mod was designed with me in mind.
