Original first year Vision owners
Jump to page : 1 2 3
docvtx
Posted 2013-11-06 8:27 PM (#148621 - in reply to #147212)
Subject: RE: Original first year Vision owners
Santa Maria CA
march 2008 over 83,000 with no problem with the battery, In September I did a coast to coast ride so just to be on the safe side I but a new battery In for the trip,
buddahead
Posted 2013-11-13 8:40 PM (#148834 - in reply to #147212)
Subject: Re: Original first year Vision owners
SF Bay Area
Still have my original battery from 2008, works great. Being in California, my bike gets ridden all winter, there is no reason to put it on a Tender.
victoryvisiontour
Posted 2013-11-13 9:21 PM (#148837 - in reply to #147212)
Purchased July 2008. Over 5 yrs later and 50,000 miles (80,000 km) the original battery is going strong. I do not own a tender. I charged it a couple of times with a regular quick charger when I ran the battery down while installing stereo equipment in 2008. I will definately buy the same battery when this one finally fails.
I wonder if the early failures were due to the loose battery terminal on 2008's. ???
Edited by victoryvisiontour 2013-11-13 9:23 PM
amessen
Posted 2013-12-03 1:55 PM (#149312 - in reply to #147212)
Belding Michigan
I have a 2008 it had the original battery on board. Then the dealer in Ohio could not start it so he threw a new battery in it but it was way to small for the bike. I kept having weird things happen lights on the dash coming on misfires and other things so I went to my local dealer to have the computer reflashed. They looked at it and said where did you get that battery. It was out of a garden tractor according to them. They replaced it and smooth sailing ever since. I am willing to bet the first battery was still good and the seller took the cheap way out. Archie
baadawg
Posted 2013-12-03 7:55 PM (#149331 - in reply to #147212)
Chattanooga, TN
47k sMiles and original battery
Posted 2013-12-04 5:51 PM (#149345 - in reply to #147212)
my 08 battery had on the side of it sticker May 2008 come spring new one for sure
Dain
Posted 2013-12-05 10:47 AM (#149365 - in reply to #147212)
My 2008 Vision still has the orig battery in it. I have it on Battery Tender from when I first got the bike. It is getting scary how long this has lasted. I left the BT off for about a month this summer and seems to still hold a great charge. Its now like driving a car thats on empty, how long can this sucker go before it quits. Lol
Dain
pete a
Posted 2013-12-05 9:17 PM (#149382 - in reply to #147212)
elgin mn
Replaced mine last spring had to jump it, it held a charge but mama said if you want me to ride with you will replace had my dealer do it.
firemedic2143
Posted 2013-12-08 10:04 PM (#149487 - in reply to #147212)
Fort Myers, FL United States
Mine Is a 2008 and the OEM battery is starting to falter now in December 2013. have to get a new one, any ideas?
Posted 2013-12-09 6:06 PM (#149515 - in reply to #149487)
firemedic2143 - 2013-12-08 10:04 PM
It's pretty hard to beat the OEM Yuasa. Stick with the high CCA ones as specified for the Vision and Cross bikes and bikes such as the Goldwing. They will be rated 300 CCA or more. There are good aftermarket replacements. I've had good luck with the Westco batteries.
The GL1800 Goldwing uses the same battery, so you can shop accordingly.
The cheaper batteries sold by some parts stores and places like Walmart are cheaper for a reason--they are only 250 to 270 CCA and likely won't last but a year or two. Buying those is false economy.
loren2
Posted 2013-12-12 10:11 PM (#149627 - in reply to #147212)
Bullhead City, AZ
mine never mad it the first year new one under warranty, replaced the second one this last spring but the heat here eats batteries
Allen_B
Posted 2013-12-20 9:42 PM (#149862 - in reply to #147212)
Clinton, CT
Slightly off-topic...
Wondering if the accessory plug in the dash works for a tender? I noted from another post the one in the trunk stays hot and would work but I run without it installed most of the time.
Curious since it would make using my tender simpler...
/r
Allen
kmt27
Posted 2013-12-20 11:04 PM (#149863 - in reply to #147212)
Davenport, IA
The plug in the console compartment is not hot all the time, only when key is on. That's how it is on my '09.
Allen_B
Posted 2013-12-21 10:33 AM (#149879 - in reply to #149863)
Clinton, CT
kmt27 - 2013-12-21 12:04 AM
That's what I thought but never really paid attention.
I will need to either pull the battery and put it on the 4-battery tender I already have running or just hit it with a top-off charge every couple of weeks. At least the battery isn't too much of a pain to get to but haven't tried to pull it out just yet...
Thanks again!
/r
Allen
Oldman47
Posted 2013-12-21 4:28 PM (#149881 - in reply to #147212)
Central Illinois
<p>The lighter socket in the trunk is always on. That is a place you could connect. You could also install a tender socket directly to your battery. </p>
Edited by Oldman47 2013-12-21 4:29 PM
Posted 2013-12-21 5:27 PM (#149882 - in reply to #147212)
look by the oil cooler early model had tender cord.
atvtinker
Posted 2013-12-22 3:23 PM (#149902 - in reply to #147212)
Grand Cane, LA
Bought my bike April '09 but it's an '08 that had been on the showroom floor for almost a year. Just replaced the battery this summer as a precautionary measure before my last trip. OEM battery was still good.
lowtone9
Posted 2014-01-03 8:14 AM (#150213 - in reply to #147212)
My '08 still has the original battery, with no hint of failure. I'll probably replace it pretty soon anyway. I put it on the battery tender sometimes when I think about it, which is not often.
PhantomX
Posted 2014-01-05 11:25 PM (#150280 - in reply to #147212)
Land O Lakes, FL
My 2011 Vision battery made it about a year and it was done. Pretty common these days here in Florida because of the heat I believe. I never get more than a year or two on a battery in my bikes.
CowboyVision
Posted 2014-01-06 7:31 AM (#150289 - in reply to #147212)
Meadow, Texas
At around 10k, my battery/alternator took a dump. Warranty took care of it with a great dealer and no problems since. Just one of those things that can happen. Still love the VV and have no plans to trade.
Easttexasrider
Posted 2014-02-03 12:29 PM (#150995 - in reply to #147212)
Lindale, TX
My 2008 still has the origional battery
MaddMAx2u
Posted 2014-02-06 5:43 AM (#151080 - in reply to #147212)
Orlando, FL
Me.
donetracey
Posted 2015-03-10 4:27 PM (#170154 - in reply to #148396)
Pitt Meadows, BC Canada
donetracey - 2013-11-01 12:10 AM March '08 - still on original battery. Never ANY problem. NEVER owned a bike in 54 years that had a battery last longer than THREE years. I consider my Vision Battery just another part of the MIRACLE that is a VISION !!! I ride YEAR-ROUND. Bike never sits for more than 2 weeks. I do use a 'tender' that is plugged in whenever I know the bike might sit for a week or more. My plan is to replace the original battery - AT 6 YEARS (coming spring) - AMAZING !
Well, here I am in March, 2015 - still on original battery - at SEVEN years !!!
Bike starts easily - still use the Tender if sitting for week or more. I'm thinking I should replace it - but IT STILL IS GOOD !!!
Denny Pink
Posted 2015-03-10 8:54 PM (#170157 - in reply to #147212)
My Vision was built April 9, 2008 and I bought it new February 7, 2009 so I'm guessing the battery was not put "into service" until then. March 2015 still original battery with no signs of weakening. I do plug it into a battery tender Jr about once a week. I may replace it this spring just as a precautionary maintenance item.
DP
Easttexasrider
Posted 2015-03-22 9:35 PM (#171408 - in reply to #147212)
Lindale, TX
Replaced my battery in 2014.
