stock seat vs low or custom
Jump to page : 1 2 3
marcparnes
Posted 2013-02-25 6:42 PM (#131365 - in reply to #131202)
Subject: Re: stock seat vs low or custom
Could someone with the OE low or Ness seat do me a favor and measure the height of the back of the rider's seat? That would be from the seating surface up to where the passenger seating surface starts. I want to compare it to my stock seat which is 7.5".
Thanks,
Marc
biermark
Posted 2013-02-25 7:57 PM (#131371 - in reply to #131202)
South Carolina
My OE 2011 seat is 7.25
2009 Ness Leather is 8
marcparnes
Posted 2013-02-25 8:16 PM (#131373 - in reply to #131202)
Thank you!
Marc
opas ride
Posted 2013-02-25 9:35 PM (#131375 - in reply to #131202)
Marc.....The 8-ball seat on my Vision is about 8 & 3/8 inches from bottom to top.....Hope this helps.
marcparnes
Posted 2013-02-25 9:41 PM (#131377 - in reply to #131202)
Thank you. It looks like the back portion of the seat is about 3/4" to 1" taller. You mentioned before that it gives you better support. That's what I'm looking for as well. I have a backrest but I don't like it so this might be a good compromise.
Marc
Monkeyman
Posted 2013-02-26 2:59 AM (#131385 - in reply to #131202)
Peru, IN
1" difference doesn't seem like much. Is the pillion lowered as well as the driver section? Or is the drivers section only 1" lower? Either way, I'd still need my Utopia backrest.
marcparnes
Posted 2013-02-26 10:41 AM (#131403 - in reply to #131202)
Just ordered one from Surdyke. Polaris has the 8-Ball part# 2684351 for 2010 and later in stock. Retail is now $377.99 and Surdyke charged $302.39.
Marc
Monkeyman
Posted 2013-02-26 12:24 PM (#131413 - in reply to #131202)
Peru, IN
What's the difference between the Ness and 8 Ball seats? And I noticed the stock heated seat is over $700!!!! I guess I could conceivably trade my 2500 mile heated seat straight up for a Ness or 8 Ball seat, eh?
marcparnes
Posted 2013-02-26 12:26 PM (#131415 - in reply to #131413)
Monkeyman - 2013-02-26 10:24 AM
The Ness has flames embossed in the seating surface while the 8 Ball is plain like the standard seat. They also make a Ness leather seat but its $864 retail.
Marc
Edited by marcparnes 2013-02-26 12:30 PM
Monkeyman
Posted 2013-02-26 1:15 PM (#131419 - in reply to #131202)
Peru, IN
I'm good with plain. Not much of a flame kind of guy. Are the 8 Ball/Ness seats comfortable for the long days or, because of less padding, are they a bit stiffer and more uncomfortable? I'm about 6'+ but weigh about 275 so I'm no lightweight.
marcparnes
Posted 2013-02-26 1:19 PM (#131420 - in reply to #131202)
I asked Nozzledog that when he was here with his Ness to install cams and said it was great. And he is BIG!
Marc
opas ride
Posted 2013-02-26 1:59 PM (#131422 - in reply to #131202)
I weight about 195lbs and have never noticed much difference on rides less than 400 miles...The stock seat has a little more butt/crotch/ padding for really long hauls but I would not go back to the stock seat at all....I really like the lower seat that lets me have better control of the bike at stops, etc. but, If my inseam were more 30" or more, I personally would keep the stock seat for that reason only...I do like the higher back support on the 8-ball and for me it works great.....BTW...to answer Monkeyman, yes IMHO the stock seat is more comfortable for taller people on long rides...And I said earlier I was able to sell my stock seat for $350 and cover the cost of the 8-ball seat......
jimtom
Posted 2013-02-26 5:19 PM (#131437 - in reply to #131202)
Subject: RE: stock seat vs low or custom
Sand Rock, AL United States
I wish you could get a heated 8 ball seat.
marcparnes
Posted 2013-02-26 5:24 PM (#131440 - in reply to #131437)
jimtom - 2013-02-26 3:19 PM
I was just doing a Google search for:
motorcycle seat heater kit
and a bunch of them popped up. Looks like it would be pretty easy and cheap. You could take it to the upholstery guy and have him install it. All he has to do is remove the cover and drill a couple of holes for the switches and put it back together again. Shouldn't be a big deal. If I run the low seat all year long I'll have to heat the back seat for my wife. She's gotten spoiled!
Marc
jimtom
Posted 2013-02-27 5:24 AM (#131464 - in reply to #131440)
My wife too, even though I got her heated pants hahaha. Actually, I'm spoiled to the heated seat. My Vision is my work car. With a few exceptions, my seat has been on since December If it's < 50 , my seat is on.
jimtom
Posted 2013-02-27 10:13 AM (#131465 - in reply to #131464)
jsut curious, if you can modify the stock seat and put an aftermarket heating element in it, why can the stock heating element not be reused?
marcparnes
Posted 2013-02-27 10:36 AM (#131466 - in reply to #131465)
I'm thinking the same thing. Need to see how it looks inside. Only thing is it will ruin the resale value since that's why many guys buy used ones. It might be cheaper and less work to just put in an aftermarket one.
Marc
JS5Owner
Posted 2013-02-27 11:14 AM (#131472 - in reply to #131440)
marcparnes - 2013-02-26 5:24 PM jimtom - 2013-02-26 3:19 PM I wish you could get a heated 8 ball seat.I was just doing a Google search for: motorcycle seat heater kit and a bunch of them popped up. Looks like it would be pretty easy and cheap. You could take it to the upholstery guy and have him install it. All he has to do is remove the cover and drill a couple of holes for the switches and put it back together again. Shouldn't be a big deal. If I run the low seat all year long I'll have to heat the back seat for my wife. She's gotten spoiled! Marc
Here are a few pictures of when I took off my 2009 Ness seat cover and did a refoam and heater.  Here is the new foam and heating element.
Here is the switch installed in the same hole that the factory switch fits in.  I did have to enlarge it a bit:
Finished project!  If you look on Youtube there are vids on how to redo motorcycle seats.  I learned a lot of tips / tricks.  I've had my cover off 3x now and I think I want to do one more bit of adjustment...
marcparnes
Posted 2013-02-27 11:20 AM (#131473 - in reply to #131202)
Two questions:
1. Where did you find the heater and are you happy with it?
2. Do you have any idea if the stock heater sits on top of the foam like you did yours or is it embedded in some way?
Marc
marcparnes
Posted 2013-02-27 11:22 AM (#131474 - in reply to #131202)
This one looks pretty interesting and the price is right.
http://www.calsci.com/motorcycleinfo/Heatedprod.html
Marc
wingit3611
Posted 2013-02-27 1:41 PM (#131480 - in reply to #131202)
JS5Owner: What kind of foam are you using & where did you get it.
Monkeyman
Posted 2013-02-27 1:56 PM (#131481 - in reply to #131473)
Peru, IN
marcparnes - 2013-02-27 12:20 PM
Two questions:
Marc
That's 4 questions.
JS5Owner
Posted 2013-02-27 3:00 PM (#131483 - in reply to #131473)
marcparnes - 2013-02-27 11:20 AM Two questions: 1. Where did you find the heater and are you happy with it? 2. Do you have any idea if the stock heater sits on top of the foam like you did yours or is it embedded in some way? Marc
I got the heating pad on eBay, less tha $50.  I have no idea about how the stock heated seat is placed.  I LOVE my seat being heated and have used it down to 37 degrees so far.
JS5Owner
Posted 2013-02-27 3:12 PM (#131484 - in reply to #131480)
wingit3611 - 2013-02-27 1:41 PM Here are a few pictures of when I took off my 2009 Ness seat cover and did a refoam and heater. Here is the new foam and heating element. JS5Owner: What kind of foam are you using & where did you get it.
What you see in the picture was a 1/2" memory foam with 1/2" gel... It sounded good but in actuality it didn't work for me.  I ended up with 1" of stiff foam.  BTW the 2009 Ness seat has really hard foam and this is why I changed it out.  So while I was doing the work I thought I'd add a heating element.
Here is a seat heater pad on eBay like mine. http://www.ebay.com/itm/UNIVERSAL-MOTORCYCLE-ATV-UTV-E-BIKE-SNOWMOBILE-CARBON-FIBER-SEAT-HEATER-WARMER-/220903183479?pt=Motorcycles_Parts_Accessories&hash=item336edb1477&vxp=mtr
marcparnes
Posted 2013-02-27 3:18 PM (#131485 - in reply to #131483)
JS5Owner - 2013-02-27 1:00 PM
I got the heating pad on eBay, less tha $50. ?I have no idea about how the stock heated seat is placed. ?I LOVE my seat being heated and have used it down to 37 degrees so far.
I was just looking at the same unit. Do you have two heat ranges or just on and off? In case it isn't dual wired I thought I might get a Heattroller for it so she can regulate the temperature. What kind of switch are you using?
Marc
