Thrust Exhaust Mod detail w/video
Jump to page : 1 2 3 4 5 6
Now viewing page 5 [25 messages per page]
Posted 2011-01-26 4:32 PM (#78204 - in reply to #74017)
Subject: Re: Thrust Exhaust Mod detail w/video
Tom, is your bike a California model? I am curious how much it makes a difference in volume. Maybe we can compare tomorrow. PM me and will get some lunch.
Posted 2011-01-27 3:10 PM (#78253 - in reply to #74017)
Well took it for a ride up to Hell's Kitchen today just to break in the new pipes and I'm even more impressed! I don't think the Screaming Eagles I had on my Harley sounded this good. Yes, they are louder, but it's only noticable when laying it on. Otherwise it's just a nice deep tone. I think I'll ride Mt. Baldy tomorrow to see how they sound in a tunnel.
bchickness
Posted 2011-01-30 11:46 AM (#78408 - in reply to #74017)
Subject: RE: Thrust Exhaust Mod detail w/video
Trenton,Nova Scotia,Canada
Can The Gatlin Tips Be Used?
Posted 2011-01-30 1:51 PM (#78412 - in reply to #74017)
Only if you weld the stock brackets back on to the Thrush mufflers.
lennyb
Posted 2011-01-30 4:01 PM (#78417 - in reply to #78408)
Perry Hall, MD
bchickness - 2011-01-30 12:46 PM
I did the cherry bomb mod and use Gatlin Tips. The set up should be the same. Hope that the photos help to clarify the description.
For strength and friction I used threaded galvanized plumbing pipe that fit into the extensions off of the back of the muffler. Use a Dremel type tool to grind out a little material from the back of the Gatlins to permit the pipe to recess into it about 1/2 ". Use stainless bolts nuts and lock washers (sorry I don't remember the sizes). Run the center of the three mounting bolts up to the pipe and tighten enough to mark where it makes contact - drill a hole to allow the bolt to pass through - (the pipe is heavy enough that you could probably use a smaller drill bit and tap it). As you screw the bolt in thread on a nut and then put on a lock washer before it goes into the pipe. When it goes into the pipe place another lock washer and nut on it. You will want this second nut to start as soon as it can as there isn't much room to tighten it from inside the pipe - finish screwing it in and tighten both nuts towards each other to lock it on. The other two bolts will be shorter so that they just tighten up against the outside of the pipe - use a lock washer on each of these.
One issue I need to go back and take care of is sealing up the back of the tips around the pipe. At the right angle you can see the mounting set up through them. This should have been done before I mounted the tips, but live and learn.
Anyway it can be done. Excuse the ugly photos as I was out riding in some snowy slush this morning.
Edited by lennyb 2011-01-30 4:05 PM
(IMG_1500-small.gif)
(IMG_1513-small.gif)
(IMG_1517-small.gif)
Attachments IMG_1500-small.gif (97KB - 7 downloads)
Attachments IMG_1513-small.gif (92KB - 1 downloads)
Attachments IMG_1517-small.gif (93KB - 3 downloads)
team5150
Posted 2011-01-30 4:11 PM (#78418 - in reply to #74017)
Corona, CA
<<Tom, is your bike a California model?>>
No it is not. I bought it from a guy in Michigan.
I wish I has seen your posts earlier, I would have liked to meet up with you. I was busy Friday with a Patriot Guard mission from Garden Grove to Riverside Cemetery.
I took a long ride yesterday and just had fun playing with my Go Pro camera.
I sent you a PM - give me a call and we'll compare notes on the stuff we've done. I work from home so anytime is good for me.
Posted 2011-02-01 8:04 PM (#78554 - in reply to #74017)
Is this normal? It's only on the right side.
(2011-02-01 15.31.06.jpg)
Attachments 2011-02-01 15.31.06.jpg (93KB - 5 downloads)
Victorywldr
Posted 2011-02-06 11:11 PM (#78845 - in reply to #74017)
I would say it is, as most of your heat and air volume exits the right pipe.
bchickness
Posted 2011-02-19 2:39 PM (#79797 - in reply to #74017)
Just Removed My Exhaust To,Noticed In My Pipe There Is A Baffle Or Something In One Side Only,Took This Pic Of it.Is That The Way Its Should Be?
(exhaust_320x240.jpg)
Attachments exhaust_320x240.jpg (54KB - 8 downloads)
MARK
Posted 2011-02-19 4:40 PM (#79805 - in reply to #74017)
PINELLAS PARK, FL.
BCHICKNESS, I WAS TOLD THAT THAT IS THE CAT CONVERTRER.
Posted 2011-02-19 5:02 PM (#79807 - in reply to #74017)
Mine has it too. Is yours a Cali model?
bchickness
Posted 2011-02-19 9:04 PM (#79823 - in reply to #74017)
Not Sure On The Model,But Why Only On 1 Side?
Victorywldr
Posted 2011-02-19 9:37 PM (#79826 - in reply to #74017)
They are in the crossover also, They are honeycomb diffusers that help your mid range HP and torque don't mess with them. They also allow heat to be maintained in the head pipe long enough to avoid tweeking a valve. They are not cats, that would be an additional component mounted externally.
bchickness
Posted 2011-02-20 7:31 AM (#79840 - in reply to #74017)
Thanks Good To Know.
bchickness
Posted 2011-03-08 7:02 PM (#81006 - in reply to #74017)
I Had S!L1,Just Installed The Thrush,Will I Have To Get Remapped ?
PhilC64
Posted 2011-03-08 9:27 PM (#81022 - in reply to #81006)
I bought my Cross Roads with a Stage 1 set up and like it enough. I don't love it but I like it. Following this thread I decided to take a plunge and attempt to do the thrush mod on my XR. The issue I'm running into is the glass pack is too close for my liking to the saddle bags. On the stock exhaust and the stage 1 exhaust the exhaust drops approximately 1.5 inches from the head pipe then back. The stock pipe has an odd hickey to it. A buddy of mine and I have a couple of idea on resolving this but I'd like to keep this in the spirit of the original mod. Cheap, easy, and off the shelf if possible.
I've attached links to my pics. I'll post them once I figure out how to do that on this forum.
http://i201.photobucket.com/albums/aa167/PhilC64/IMAG0058.jpg
http://i201.photobucket.com/albums/aa167/PhilC64/IMAG0034.jpg
http://i201.photobucket.com/albums/aa167/PhilC64/IMAG0033.jpg
Edited by PhilC64 2011-03-08 9:30 PM
Posted 2011-03-08 10:03 PM (#81024 - in reply to #74017)
I went from S1L1 to thrush without any remap nor any popping. I still have a heat issue, don't know if a remap would do anything for that though.
PhilC64
Posted 2011-03-12 8:10 PM (#81264 - in reply to #74017)
I've pretty much figured out everything to get this thrush mod done on a Cross bike. It's not as simple due to the stock exhaust design. Still though I'm keeping this as an off the shelf mod as possible. Some fabricating or competent exhaust shop work will be required I'm afraid. I'll post on the Cross bike forum here later with a complete how to. Thanks to the originators of this mod! Your experimentation inspired me!
BillyJoe
Posted 2011-03-13 10:40 PM (#81319 - in reply to #74017)
, AR United States
Here is a video of my 09 Vision with the Thrush mod
http://www.youtube.com/watch?v=Y3hJzADkS6A
Biscuit
Posted 2011-03-13 10:57 PM (#81320 - in reply to #81319)
Midlothian, Va.
BillyJoe - 2011-03-13 11:40 PM Here is a video of my 09 Vision with the Thrush mod http://www.youtube.com/watch?v=Y3hJzADkS6AOn a deserted road a guy pulls out in front of you. What is it with these clowns in a cage? Had a guy do that to me the other day with nobody in site behind me and then go one block and hang a right.
PhilC64
Posted 2011-03-19 10:28 PM (#81748 - in reply to #74017)
I finished the glass pack install on my Crossroads. Consider yourselves lucky to have a direct fit/bolt on mod. It took a bit of fabrication to get the glass pack to fit but it's well worth it.
http://www.youtube.com/watch?v=wvWBVjtf9e8
Edited by PhilC64 2011-03-19 10:35 PM
cook06vegas
Posted 2011-04-27 10:21 AM (#84955 - in reply to #74017)
Lansing, MI
DAMN! Those sound bad ass on your CR!!!
bugmasai
Posted 2011-06-14 7:33 PM (#88873 - in reply to #81319)
DeRidder, LA
Installed glasspacks today, love the sound. Fabbing some brackets on Thursday and tacking the tips to make it rock solid. Got a compliment on the sound on my test ride. What to change now?????? Still need to finish my brushed aliminum to carbon fiber vinyl transformation.
extremeps
Posted 2012-06-19 11:38 PM (#117112 - in reply to #74017)
Love the exhaust mod! I have a question for you. Your signature talks about a custom passenger backrest. What is that about. I have been looking for something for when I take my trunk off but haven't been able to come up with anything yet.
Udnudn1968
Posted 2012-06-24 12:51 PM (#117469 - in reply to #74017)
I have a Stage 2 exhaust that is on the Vision I just bought. Can I still do the Thrush mod with these style of pipes? I havent picked up the bike yet and dont know if the chrome heat shields are like the stock ones or not. Really want to do this mod when I get the bike. Hope I am not disappointed!
Thanks
Steve
