voltage reg
Cap'n Nemo
Posted 2011-08-24 5:39 PM (#94546)
Subject: voltage reg
New Bohemia, Va
everything was normal when I started up to leave work. When I roll on the throttle it shoots up to 18v, the check engine lite comes on as well as the battery lite. At idle everything returns to normal. Any other ideas?
glighto11
Posted 2011-08-24 5:47 PM (#94547 - in reply to #94546)
Subject: Re: voltage reg
Central New York
That would be my first guess. In any case, I would use all the high draw things you can to try to burn off excess juice till you get home. Seat heat, grips, etc.
Cap'n Nemo
Posted 2011-08-24 7:29 PM (#94553 - in reply to #94546)
New Bohemia, Va
I thought about that but didn't want to destroy anything else so it's sitting at work all by its lonesome. Going to call and see if it is worthy of warranty persuit, if not, I guess I'll be ordering a regulator.
MaddMAx2u
Posted 2011-08-24 7:51 PM (#94561 - in reply to #94546)
Orlando, FL
Yup. Happened to me right after my 500 mile check up. hit the throttle and voltage spike, check engine light, etc. etcv. Then all returns tp normal. And as long as I dd not rev above 4000 all was ok. It was the Voltage Regulator. Check it. Covered under my warranty.
glighto11
Posted 2011-08-24 9:07 PM (#94573 - in reply to #94546)
Central New York
Well Cap, I think Polaris should cover everything for you, just to see how far a Vision can really go.
Travelin Man
Posted 2011-08-24 9:37 PM (#94576 - in reply to #94546)
If you have the extended warranty then it should be a non issues since it is obviously a critical engine related part.
Oh, and yes, I would also agree that it would be the voltage regulator and I agree with you not taking the chance on riding it home even with everything switched on, the last thing you would need is a voltage spike that takes out the ecm or your stereo unit.
Cap'n Nemo
Posted 2011-08-25 9:27 AM (#94611 - in reply to #94546)
New Bohemia, Va
getting a trailer and taking it home today. tomorrow, off to the dealer two 1/2 hours away. I look forward to the ride home. Sad, sad, day for the Bentley, but I'm not complaining. If they won't warranty it, I guess I'll change it myself, we'll see...anticipation and caging is making me crazy.
Posted 2011-08-25 9:50 AM (#94616 - in reply to #94546)
Subject: RE: voltage reg
edited:
Edited by Thomas 2011-08-25 9:57 AM
Posted 2011-08-25 9:56 AM (#94617 - in reply to #94546)
Cap'n Nemo - 2011-08-24 5:39 PM...Any other ideas?
Might be a good time to look at the stator windings for any dark/burn coloring.
Just curious do you happen to know if the voltage regulator is a series or shunt style?
Cap'n Nemo
Posted 2011-08-25 10:47 AM (#94623 - in reply to #94546)
New Bohemia, Va
i ain't a messin' any further than having the regulator changed out, that's external, the stator is internal. I don't know if it is series or shunt (I hope we're allowed to say that), I do know it has fins and mounted under and in front of the bike frame for all the front tire debris to hit...
Travelin Man
Posted 2011-08-25 10:57 AM (#94626 - in reply to #94546)
Cap, how many miles do you have on your totally unreliable, too far between crappy dealers Vision now?  Last I saw you had broken the 90K mark.
Oh, please forgive the excess sarcasm!
Cap'n Nemo
Posted 2011-08-25 11:21 AM (#94630 - in reply to #94546)
New Bohemia, Va
90,000+ is good enough. I decided that the only way that I'll disclose the mileage is if we meet. I was posting my mileage to keep the encouragement going for those that think they bought junk. However, folks felt I was "showing off" or bragging. But as Will would say "no brag, just fact"*. I've certified the Vision Cap'n Nemo proof and if you ever met me you would understand that statement as well. The fact I don't have a dealer right out side my front door further enhances the eliteness of this machine in my mind. Sorry that I didn't answer the question out right, but let's just say it's enough miles...
(*Guns of Will Sonnett)
pollolittle
Posted 2011-08-25 12:50 PM (#94651 - in reply to #94630)
Brighton, TN
I think I was looking for proof that I don't have to trade it in befor 90k+. Now I'll never know. OH, the Travshamockery! I do wonder why the new 2011's just hit my dealer showroom, they are pretty but a little late ain't they.
Posted 2011-08-25 2:26 PM (#94663 - in reply to #94546)
Did you loose your regulator during the earthquake?
It could fall under the "Act of God" clause on the extended warranty.
Edited by radioteacher 2011-08-25 2:28 PM
Cap'n Nemo
Posted 2011-08-25 4:38 PM (#94678 - in reply to #94663)
New Bohemia, Va
radioteacher - 2011-08-25 2:26 PM
the day after the earthquake.
As I said, everything was normal that morning. When I started the bike, I checked the lights out, all of them, turn-signals, high-beams, etc. I don't do that leaving work. When I rolled out of the parking spot and around to the upper deck, I basically idled it up to the upper part of the deck, so the R's never got to 2,000, but I don't normally do that either. Then when I got up the ramp I rolled on the throttle and I noticed the red engine check light so I rolled off and noticed the battery light. I figured it was just fluking on me so I shut the bike off and sat and waited for a moment. Started up, rolled on the throttle and it was the same all over again. I disconnected the battery, waited, reconnected, disconnected the ECM, reconnected, disconnected the regulator, ran it without the regulator connected, all the same results.
It just seems odd I did the light check, as I do at home, and idled the bike on take-off as I do out of my drive-way, then this happens. I'm curious what triggered it other than it was just old with it having 90,000+ plus miles on it.
Tomorrow will be a heart breaker because I'll be trailering the bike - I'm sick and will have to take something to keep me from getting too upset. I recently had an MRI done and that was tough, but I believe this will be tougher. The only other time she's seen a trailer was when the fuel pump went, but the dealer came and got it when I wasn't home, so I didn't see it.
Oh, well.....
pollolittle
Posted 2011-08-26 10:40 AM (#94759 - in reply to #94546)
Brighton, TN
Just think of it as giving the Bentley a much needed rest, and valet service to its favorite dealer for a little one on one time from some close relatives.
Did you happen to have the regulator done under the recall? I see where they would replace the regulator, might ask?
Cap'n Nemo
Posted 2011-08-26 10:58 AM (#94760 - in reply to #94546)
New Bohemia, Va
yep - regulator - waiting verdict for recall or warranty or o-o-p.
update: no recalls Po. Where did you get that info?
Edited by Cap'n Nemo 2011-08-26 11:11 AM
Posted 2011-08-26 11:13 AM (#94762 - in reply to #94546)
I can picture the new Victory bikes at the dealer saying to "Bentley", "Hey old man, where you been?"
Ride Safe
Cap'n Nemo
Posted 2011-08-26 11:38 AM (#94764 - in reply to #94546)
New Bohemia, Va
WARRANTY!!!!!!!! YES!!!!!!!!!!!!!!!
dan camarco
Posted 2011-08-26 11:55 AM (#94765 - in reply to #94546)
Lumber Bridge, NC United States
nice.
Posted 2011-08-26 1:07 PM (#94770 - in reply to #94546)
ChaChing! How long will it take to get one in?
Travelin Man
Posted 2011-08-26 1:12 PM (#94771 - in reply to #94546)
Cap, glad to hear things are being fixed to your satisfaction and under warranty!
You MUST be on good terms with your dealer!
glighto11
Posted 2011-08-26 2:13 PM (#94773 - in reply to #94546)
Central New York
Ain't life grand!
pollolittle
Posted 2011-08-26 2:54 PM (#94779 - in reply to #94546)
Brighton, TN
Capn (aka unknow alias VaI'verodeover100kmilesonthisherabikeRyder) - I got the info right off of this website. I can't believe a seasoned veteran of this site and don't know about the Tech link where you can look up recalls, bulletins, etc. Oh the travshamockery of it all!
If you can get it covered under the recall no money out of your pocket hopefully.
Top right corner of Home page! They made it pretty simple for a guy that's just rode hard!
Edited by pollolittle 2011-08-26 2:57 PM
Cap'n Nemo
Posted 2011-08-26 5:54 PM (#94799 - in reply to #94546)
New Bohemia, Va
Done! The Bentley is in the shed. Takin' the tire to get the rear E3 mounted tomorrow during the her-a-cane.
