Front Fender Extender
The_Visionary
Posted 2011-04-26 10:09 AM (#84898)
Subject: Front Fender Extender
lakes region, NH
Hello All, I am wondering if anyone has manufactured a fender extender for the VV or knows of a Co. selling them?
Cap'n Nemo
Posted 2011-04-26 10:50 AM (#84899 - in reply to #84898)
Subject: Re: Front Fender Extender
New Bohemia, Va
mudflap. But yes, I think it was HMD that did.
Lotzafun
Posted 2011-04-26 12:54 PM (#84904 - in reply to #84898)
Rockford, IL
Fender extender? As in mudflap? To keep debris off the lower front of the bike?
If you are talking about some type of mudflap setup there are some aftermarket options that a few folks have adapted to the Vision. However there have also been a few folks that have done this and ended up cracking the rear fender at the mounting bolts.
btw........welcome to the site !!
texasgrumpy
Posted 2011-04-26 3:22 PM (#84909 - in reply to #84898)
HMD sells a extended replacement for the rear of the front fender and a re-shaped front section also.I have the rear on my VV and it really does the trick for keeping the crud & crap out of the front end.
kinggodzilla
Posted 2011-04-26 4:58 PM (#84915 - in reply to #84909)
Dublin, Ohio
Can you use the extended rear with the stock front? The pic kind of made it look like you needed to buy both pieces.
The_Visionary
Posted 2011-04-28 12:01 PM (#85053 - in reply to #84898)
lakes region, NH
Thanks everyone, I'll look into HMD? I was wanting an extension of the front fender that will continue the contour of the tire. Maybe in CF?
rebelce
Posted 2011-09-15 10:17 AM (#96672 - in reply to #84898)
Pardon my ignorance but what does HMD stand for? To many letters. Who knew ATF had anything to do with guns and booze!
Posted 2011-09-15 10:56 AM (#96677 - in reply to #84898)
here is there web site they don't say but it looks like it would bolt up to the stock front  http://www.hmd520.com/category/HMD-PARTS-1
Edited by john frey 2011-09-15 10:58 AM
Lotzafun
Posted 2011-09-15 10:58 AM (#96678 - in reply to #84898)
Rockford, IL
HMD is Heavy Metal Designz http://www.hmd520.com/
A well respected aftermarket Victory parts manufacturer and supllier
rebelce
Posted 2011-09-16 9:04 AM (#96777 - in reply to #84898)
Thank you. Gotta keep her clean.
glighto11
Posted 2011-09-16 11:05 AM (#96789 - in reply to #84898)
Central New York
I believe their fender is for 21 inch wheel, could make 18 inch wheel look weird.
HLUSN8
Posted 2011-09-16 12:38 PM (#96793 - in reply to #84898)
Quad Cities, IL
There is this thing. I found this a while ago, have thought about it...but don't have it yet. Low cost item that will extend protection another 2" but requires some drilling into the rear part of the front fender. Would like to know if anyone ever went this route.
http://www.roadhorsemotorcycleaccessories.com/mud-flap-for-victory-...
The_Visionary
Posted 2011-09-20 10:28 AM (#97151 - in reply to #84898)
lakes region, NH
Well I ended up using a piece of aluminum flashing. Cut it and rolled it by hand then used an industrial strength silicone to clamp it to the inside of the fender. It matches up with the silver paint pretty good. cheap fix!
Posted 2011-09-20 12:16 PM (#97162 - in reply to #97151)
The_Visionary - 2011-09-20 11:28 AM
"Necessity is the mother of invention". Picture please?
Posted 2011-09-20 12:59 PM (#97165 - in reply to #84898)
I just drilled the holes and put on a front mudflap, from hot leathers I believe.
southjerseyrider
Posted 2011-09-20 6:55 PM (#97212 - in reply to #96793)
Vineland, NJ United States
I use the roadhorse one, works fine but requires you to drill two holes.
The_Visionary
Posted 2011-09-22 7:52 AM (#97350 - in reply to #84898)
Subject: RE: Front Fender Extender
lakes region, NH
here is the finished product.
(fender_(3)_(3).jpg)
Attachments fender_(3)_(3).jpg (66KB - 1 downloads)
The_Visionary
Posted 2011-09-22 10:21 AM (#97357 - in reply to #84898)
lakes region, NH
And this is the Rear
(rear mudflap.jpg)
Attachments rear mudflap.jpg (30KB - 0 downloads)
The_Visionary
Posted 2011-09-22 10:23 AM (#97359 - in reply to #84898)
lakes region, NH
Gotta keep her clean! 'Cause there Ain't No Mudd in SPAAAAACE.
(Cruizin'.jpg)
Attachments Cruizin'.jpg (65KB - 0 downloads)
Posted 2011-09-22 1:57 PM (#97377 - in reply to #97350)
The_Visionary - 2011-09-22 8:52 AM
Very professional looking!
rebelce
Posted 2011-09-23 6:34 PM (#97501 - in reply to #84898)
Looks great! where do you find this magic glue? "industrial strength silicone " I think I need to do this.
bikerdave48
Posted 2011-09-23 7:42 PM (#97505 - in reply to #96793)
New Castle Delaware
HLUSN8 - 2011-09-16 1:38 PM
HLUSN8, I bought this about 2 years ago still on and does help. It was very easy to install. I think I was able to install without removing the fender.
dfarrington
Posted 2011-09-25 5:18 PM (#97636 - in reply to #84898)
Galt California
I have a new fender from HDM. Photo Attached?
dfarrington
Posted 2011-09-25 5:21 PM (#97638 - in reply to #84898)
Galt California
HDM fender
dfarrington
Posted 2011-09-25 5:23 PM (#97639 - in reply to #97638)
Galt California
3rd times a charm
(fender 3.jpg)
Attachments fender 3.jpg (83KB - 2 downloads)
