Poll PSI Tire Rating
PSI Tire Rating
OptionResults
dunlop Elite 345 Votes - [91.84%]
Avon Cobra4 Votes - [8.16%]
relic123
Posted 2010-07-09 2:57 PM (#64161)
Subject: PSI Tire Rating
Southeast Idaho
so here is the question of the day, it appears that most are using the dunlop elite 3's over the Avon Cobras, mostly for the higher load rating.   What PSI are you running your tires
relic123
Posted 2010-07-09 3:00 PM (#64162 - in reply to #64161)
Subject: RE: PSI Tire Rating
Southeast Idaho
dunlops
41 psi front
43 psi rear
southjerseyrider
Posted 2010-07-09 3:15 PM (#64164 - in reply to #64161)
Vineland, NJ United States
Dunlop
38 & 40
Big Vic
Posted 2010-07-09 3:24 PM (#64167 - in reply to #64161)
Subject: Re: PSI Tire Rating
Southeast Iowa
Dunlop E3's
38 Front
40 Rear
lennyb
Posted 2010-07-09 4:31 PM (#64180 - in reply to #64161)
Perry Hall, MD
38F/40R
scotsvision
Posted 2010-07-09 4:55 PM (#64182 - in reply to #64161)
Coos Bay, Oregon
Avon Cobra
40 Front
42 Rear
RCS
Posted 2010-07-09 5:22 PM (#64183 - in reply to #64161)
AZ
E3's
40F/42R
regards
baadawg
Posted 2010-07-09 7:44 PM (#64191 - in reply to #64161)
Chattanooga, TN
Dunlop E3
38 front
40 rear
K2V2
Posted 2010-07-09 7:49 PM (#64193 - in reply to #64191)
Northern NJ
E3s, 38F 40R
Posted 2010-07-09 8:13 PM (#64194 - in reply to #64161)
E3, 42/42
ScoreBo
Posted 2010-07-09 9:14 PM (#64195 - in reply to #64161)
Northeast Ohio
E3 - 42r/40f mostly 2-up riding
Edited by ScoreBo 2010-07-09 9:20 PM
ScoreBo
Posted 2010-07-09 9:14 PM (#64196 - in reply to #64161)
Northeast Ohio
double post edit
Edited by ScoreBo 2010-07-09 9:15 PM
Tarpits99
Posted 2010-07-09 9:36 PM (#64199 - in reply to #64161)
North Orange County CA
Dunlop E3 38/F - 40/R
Blackjack
Posted 2010-07-09 10:05 PM (#64203 - in reply to #64161)
Cottage Grove, Mn
40/42
Gadget
Posted 2010-07-10 7:28 AM (#64217 - in reply to #64161)
40F/42R
wrr1home
Posted 2010-07-10 8:57 AM (#64219 - in reply to #64217)
Dunlop E3s
41/41
Posted 2010-07-10 11:17 AM (#64230 - in reply to #64161)
I put a lot of pressure in the twisties, not so much on the straights.
Vinner1
Posted 2010-07-11 9:35 PM (#64314 - in reply to #64161)
Hartland, , WI
E III....40F - 42R
Posted 2010-07-11 11:18 PM (#64317 - in reply to #64161)
Dunlop E3. 40/40
Man314
Posted 2010-07-11 11:57 PM (#64318 - in reply to #64161)
Dunlops - 38 F / 42 R (riding 2 up 80% of time . . . interesting observation though . . . I have Doran TPS installed. I have always known that PSI increases when tires heat up, but mine are getting to 46 F / 52 R. Is there a maximum PSI that becomes dangerous?
tonyj
Posted 2010-07-12 9:15 AM (#64352 - in reply to #64161)
Salina, KS
Dunlop E3....38F / 40R
Interesting side note....I check / adjust tire pressure weekly at the very least, usually twice a week. My front tire started cupping at 3600 miles & got to where it felt like I was riding a snake. I've also noticed rear tire has a "heel/toe" wear pattern to it. My H-D buddy says Dunlop is having issues with tires on their bikes as well...he's had a set replaced already. Anybody else had issues? BTW, my suspension is set to Vic spec, riding 2-up most of the time.
sonicbluerider
Posted 2010-07-12 9:31 AM (#64353 - in reply to #64352)
, IA
Metz. 40/40
Posted 2010-07-12 10:11 AM (#64355 - in reply to #64352)
tonyj - 2010-07-12 9:15 AM Dunlop E3....38F / 40R
Tony, I think your front pressure is too low.  I'm getting over 20,000 on my fronts easily.  I run 42/42 just to give me a 2psi fudge into the 40's.  (Just about to put my second replacement on at 42K and it's not at the wear bar yet.)  The E3's are by far the most sensitive to air pressure I have ever been on.  Keep them over 40 and the bike feels like it is on rails.  39 and below and it is a whole different animal.  Great tires when properly inflated.
Breaker
Posted 2010-07-12 5:21 PM (#64378 - in reply to #64161)
Western WA
Dunlop E3s 40/42 mostly two up.
SongFan is right about the pressure. Under 40 and the bike no longer feels like the Vision I bought. I check it before every long ride, and every other ride for short hops. Guess I'm a little OCD when it comes to the tire pressure.
hottierod
Posted 2010-07-13 2:37 PM (#64453 - in reply to #64378)
Sturbridge, Mass
Is anybody using the air suspension pump to check/add tire air ?
I have the Victory/Fox hand pump to check the rear suspension. I like the dial- seems very accuratre. wonder how much effort it is to ad a little air to the tires as needed.
The flexible hose makes it easy to check pressures.
