Amsoil Oil Change Intervals
kxb44
Posted 2010-05-20 9:15 AM (#60241)
Subject: Amsoil Oil Change Intervals
One of the selling points of Amsoil is supposed to be a decrease in oil change intervals. Do any of you go 5,000 between changes using the Amsoil or do you just stick with the 2500 recommendation?
Posted 2010-05-20 10:18 AM (#60247 - in reply to #60241)
Subject: Re: Amsoil Oil Change Intervals
I go with the rattling the motor does when it gets close to an oil change. I've only used Vic and AMSOIL and currently I'm running AMSOIL. Around the 2,200 mile mark with Vic oil the motor starts ticking, or rattling more and it quiet downs considerable changing it at the 2,500 mark for me. On AMSOIL that ticking doesn't start until after the 3,000 mile mark and yes I've taken it to 4,000. I have gone as far as 6,000 on Vic oil but it was sounding like it was coming apart by the time I changed. The oil was still above the add mark too, just not doing the cushioning job it should have been. That's all I've got to say about that....
Posted 2010-05-20 10:25 AM (#60248 - in reply to #60241)
you can do 5000 if you like onmy last bike which was a 2053cc (125ci) i did 7500 miles oil change intervals but i did this with PROOF the oil was still good. if you go to a website called blackstonelabs.com they will send you a oil testing kit. and if you the type of person that needs Proof your not hurting your engine, then send 4oz samples of your Used oil to their lab and for $22.50 (unless the price changed) they will do a test on your oil and let you know hows its doing.. http://www.blackstone-labs.com/free-test-kits.php
so if you do a 5000 mile test on your oil they will give you the results of the test and say. there is still alot of oil life left you can do 5000 mile OCI's or you can go further,. or they can say try 4000 mile OCI's.. when i did my tests i started at 3000 miles using amsoil i was at 7500 miles by the time i traded in the bike. and at 7500 miles they were saying the amsoil was still able to go longer! but i used facts to prove this. im doing the 2500 mile oci right now because im under waranty.. as soon as this warranty is up, im doing longer Oci's !!
nightvision
Posted 2010-05-20 1:39 PM (#60255 - in reply to #60241)
dinwiddie, va
we use royal purple in our bikes, we change oil every 5000 and oil filter after 2500. to keep oil clean. it still looks pretty good after 5000
victoryvisiontour
Posted 2010-05-20 2:20 PM (#60259 - in reply to #60241)
I use SuperTech so I only have to change once per year, unlimited mileage.
Posted 2010-05-20 2:36 PM (#60262 - in reply to #60259)
victoryvisiontour - 2010-05-20 3:20 PM
I'm switching. I use the ST7317 already so that should be a good combo... I get 10% at wal-mart as well so that would be a super saver where I could buy more leather for the VV.
Biscuit
Posted 2010-05-20 3:45 PM (#60267 - in reply to #60241)
Midlothian, Va.
Been a fan of Amsoil for many years also the Mobil 1-110 filter and see no need for changing. 5 to 6k or more between changes is no problem with Amsoil.
Posted 2010-05-20 9:18 PM (#60284 - in reply to #60241)
Subject: RE: Amsoil Oil Change Intervals
I've been going 5000 miles between oil and filter changes on my Victorys since the year 2000. My 2000 SC is still going strong on the original motor and tranny. I'm now also using Amsoil in my 2008 Vision and trying to go 5000 miles per change, but I'm up to 6000 miles this time.
My buddy has been running Amsoil in his 2001 Goldwing and goes 8000 to 10,000 miles per change. He's got 90,000 miles on it now. Runs like new.
Amsoil costs twice as much as other brands, and goes 2 -3 times longer per change. Works for me.
-Dirk-
Posted 2010-05-20 9:33 PM (#60287 - in reply to #60241)
Central Kentucky
I used Amsoil in a 2002 Victory 92" at 5000 mile intervals. After a 10 day, 5800 mile ride through the southwest in mid summer, the oil still looked a felt good when I changed it. So I continue to use Amsoil in my 2009 Vision at 5000 mile changes.
Bluto
Posted 2010-05-21 7:34 AM (#60314 - in reply to #60241)
McHenry, IL
Are you Amsoil guys running 10-40 or 20-50?
Posted 2010-05-21 7:40 AM (#60317 - in reply to #60241)
10w40
Biscuit
Posted 2010-05-21 7:45 AM (#60319 - in reply to #60241)
Midlothian, Va.
10w40 also
iluvink
Posted 2010-05-21 12:05 PM (#60364 - in reply to #60241)
Dallas, Texas
I am thinking of using the new Castrol V-Twin Semi 20/50W at my next change. Full Synths seem to cause clutch slip issues later down the road.
Posted 2010-05-21 3:13 PM (#60388 - in reply to #60364)
iluvink - 2010-05-21 12:05 PM
which brand of synth are cauing these clutchs to slip?
Posted 2010-05-21 3:49 PM (#60394 - in reply to #60241)
I'm testing that right now using Amsoil and still no slip at 68,000. I'll give my next update at 70,000 miles.
ingle51
Posted 2010-05-21 4:08 PM (#60398 - in reply to #60241)
NE Florida Jacksonville
I used Amsoil in my 2002 TCD for over 45,000 miles. I changed the filter every 2500 and topped it off. At 5000 oil and filter. No issues with the clutch whatsoever. Most of the riding was two up and loaded so she got a good workout. The first year I used Victory oil to satisfy the warranty with the dealer, I did my own changes after the first 500 mile service. Once the first year was over I went to Amsoil, it did quiet down the engine quite a bit.
kevinx
Posted 2010-05-21 7:15 PM (#60411 - in reply to #60388)
Arkainzeye - 2010-05-21 4:13 PM
All of them........
This is only an issue for aggressive riders. The engagement starts to become "lazy", and then slowly works into a slip. When I say aggressive I do not mean a guy that rolls on the throttle every once in a while. I mean someone that rides hard; be it twisties, or straight line. Also people that really slip their clutches on launch, and shift tend to have problems. Those of you that ride like old ladies are likely to never have a problem
Posted 2010-05-21 7:40 PM (#60413 - in reply to #60241)
lOl, I wonder how that'll pan out if you ride like a little old man....
Posted 2010-05-21 7:58 PM (#60416 - in reply to #60241)
VisionTex has 47k with the cams and Amsoil.  No clutch slip and trust me, he don't ride like a lil' ol' lady.  He keeps trying to talk me into goin over, but I'm just quite there yet.
Posted 2010-05-21 8:03 PM (#60417 - in reply to #60241)
i used synth (amsoil/mobil1) in every bike i ever had. even a CBR600 and never had a clutch go bad to slip to where you could feel it.. CBR600 revs way high than ANY victory! lol Now i do NOT add additives to my oil or anything like that. and i use synth Motorcycle oil.. NOT synth car oil... ive had synth is my smallest bike 600cc to my largest 2053cc. the 600cc was a high revving horsepower bike the 2053cc was mostly all Torque and i mean Torque!
baadawg
Posted 2010-05-21 8:10 PM (#60418 - in reply to #60262)
Chattanooga, TN
varyder - 2010-05-20 3:36 PM victoryvisiontour - 2010-05-20 3:20 PM I use SuperTech so I only have to change once per year, unlimited mileage. I'm switching. I use the ST7317 already so that should be a good combo... I get 10% at wal-mart as well so that would be a super saver where I could buy more leather for the VV.
WTF? (WorldTrampolineFoundation)  Do you really use generic wally world automobile grade dino oil in a Vision? Please, straighten this out for me before I blow a gasket!!
 Baadawg
'08 Vision Blacked Out
I think I'll call her Black Betty
Posted 2010-05-21 8:15 PM (#60419 - in reply to #60241)
I just use the filter....
kevinx
Posted 2010-05-21 8:22 PM (#60421 - in reply to #60417)
Arkainzeye - 2010-05-21 9:03 PM
It is about clutch size, weight of the bike, torque output of the motor, and clamping force on the pack. You can not compare a 300 pound sportbike that makes 65FtLbs peak to an 800 pound bike that makes 100+FtLb. The Suzi 2 liter had a much larger basket with a different engagement system. Again it is apples, and oranges. Like it or not, clutch slippage with full synth oils in Vic motors is a fact
Teach
Posted 2010-05-21 8:46 PM (#60424 - in reply to #60241)
I'd say play it by ear. Like Varyder I base my NEED to change oil on what the bike is telling me. I've noticed over the years that the shifts become notchy as the oil gets close to needing changed, or at least thats what I feel by seat of the pants. I don't care if it is at 2k or 4k if it feels notchy I change it. I change my oil at the 2500 interval when at home but if on a road trip I'll stretch it out running the amsoil (I've run the Mobil1 & Castrol Vtwin as well). I run the 20/50 synthetic rather than the 10/40.
As for slipping with synthetic? My bike did begin to slip ever so slightly running the Amsoil some time bck, and I'm hardly aggressive and definitely don't slip the clutch. HOWEVER, after replacing the oil with the Victory oil for 2500, I returned to the amsoil with no further slipping issues. The oil sample testing advice is good if you don't feel good about seat of the pants observation. JMO
Posted 2010-05-22 11:47 AM (#60465 - in reply to #60241)
yeah what is nice about the oil sample test is, when i had my kawasaki i foundout i was changing my oil (using synth) WAY WAY too soon, and basically wasting most and time.. people told me the amsoil could go the distance but we are so brain washed into the 3000 mile Oil change interval that i couldnt believe anyone. UNLESS i can proof.. and as i said before at 7500 miles on the amsoil in my old kaw the test came back showing the additives and cleaners along with the visocity were ALL still in the grade! and this wasnt for a victory so each application is diffenent.. but doing a synth oil change is not cheap (neither is a victory semi-synth oil change) . So it was nice to get Proof that im causing no harm at all by exteneding my OCI. whem my warranty is up i will surely extened my OCI's.. right now i dont trust victorys warranty dept to have my back, even if i have proof.. ive read too many times on difference forums where they denied claims for things that werent related to the problem, all because someone installed a aftermarket device, fuel controller, leds etc.... give them a chance to deny your claim and they will do it!
