Rev Limiter With Cams
Bubba
Posted 2009-09-21 9:06 AM (#44403)
Subject: Rev Limiter With Cams
The Lloyd cams and his whole set up is outstanding. The only negative issue is the rev limiter. The power gets you too 5500 so fast it actually needs to be higher. My dyno shows that the power is still climing when it hits the limiter. Is there any way it can be raised? Thanks
af goalie
Posted 2009-09-21 10:05 AM (#44405 - in reply to #44403)
Subject: Re: Rev Limiter With Cams
Rapid City, SD
I thought Lloyd had a set up that would disable the rev limiter all together. Might be something to ask him. I just wouldn't know how dangerous that could be to your motor.
Bubba
Posted 2009-09-21 10:29 AM (#44406 - in reply to #44403)
The engine management system does raise it a tad when you do his stuff, but no his stuff by itself will not change the programing from Vic. He did raise Lobsterhunters, but had the bike for months last winter.
#57
Posted 2009-09-21 10:50 AM (#44411 - in reply to #44403)
As far as I know, he can only beat the rev limiter in 6th with the Visions.
That is what he did with Lobsterhunters.
DAL
Posted 2010-05-26 6:30 PM (#60836 - in reply to #44403)
Subject: RE: Rev Limiter With Cams
Vancouver, B.C. & La Quinta, CA
How many cams does your Vision have? Mine only has only a single overhead cam.
Posted 2010-05-26 6:39 PM (#60837 - in reply to #44403)
My vision has 2 cams
GeekVisionRider
Posted 2010-05-26 6:41 PM (#60838 - in reply to #60837)
Fredonia, WI United States
Arkainzeye - 2010-05-26 6:39 PM
Mine too!
Vicbuilder
Posted 2010-05-26 7:02 PM (#60840 - in reply to #44403)
The Vic Shop - Central Iowa
Lloyd can reprogram your ECM to up the rev limiter. You will have to send in your computer and wait till he reflashes it and sends it back.
BTW I dunno if that was a joke but SOHC X2 cylinders = 2 cams. Thus referring to them as cams (plural)
1atom12
Posted 2010-05-26 7:42 PM (#60841 - in reply to #44403)
Atlanta Area
Lloydz ecm reprogramming is one option. The other is to replace your VFC-3 fuel controller with the new PC-V. The Vic version of the PC-V has Rev-Extend (like the Harley version) which will take you to 6000 rpms in all gears except 6th.
#57
Posted 2010-05-26 7:55 PM (#60844 - in reply to #44403)
Having Lloyd install mine this Saturday in Hooksett, NH. 6,400 rpm's in all gears plus he has changed the base map.
Devilboy posted on thevmc that he went from 104HP to 114HP with the extended revs.
Something about his fuel controller could not push enough fuel at that point.
My fuel controller has been reprogrammed to push more fuel, can't wait to see my numbers on Saturday.
#57
Posted 2010-05-29 9:30 PM (#61055 - in reply to #60844)
Rev limiter is no longer a problem. 6400 is amazing plus he did some other programming.
Bike has never run this strong before plus my MPG went up by 8.
(DSCN1149.JPG)
Attachments DSCN1149.JPG (27KB - 4 downloads)
Posted 2010-05-30 11:20 AM (#61092 - in reply to #44403)
What's the top speed at the 6400 rpm redline?
kevinx
Posted 2010-05-30 11:26 AM (#61093 - in reply to #61092)
SongFan - 2010-05-30 12:20 PM
What's the top speed?at the 6400 rpm redline?
140+ With cams, etc
Posted 2010-05-30 11:32 AM (#61094 - in reply to #44403)
The bikes with the cams and 6400 rpm limiter will be easy to spot.  They'll be the ones with two oval spots on each fairing where the lowers used to be before they got blown off.
#57
Posted 2010-05-30 1:09 PM (#61097 - in reply to #61092)
I was figuring 145-150.
Before in the mid 120's comfortably riding in 6th without hitting rev limiter.
kevinx
Posted 2010-05-30 2:53 PM (#61104 - in reply to #61097)
#57 - 2010-05-30 2:09 PM
You need to double check your speedo. Rev limiter kicked in at 118-121 with stock ECM
#57
Posted 2010-05-30 4:43 PM (#61110 - in reply to #44403)
My GPS had me at 122 once, comfortably riding.
124 another time, was climbing but backed off when the blue lights came on.
Speedo always show higher.
XRsteve
Posted 2010-05-30 10:00 PM (#61148 - in reply to #44403)
Georgia, west of Atlanta
I like it...........................
XRsteve
Posted 2010-05-31 2:54 PM (#61207 - in reply to #44403)
KevinX: How big a deal to install the Lloyds rev extend? Is it an easy add on while you're getting the cams, airbox and pipes done ??? About how much for Thundersticks, airbox, cams and rev extend for a 08 if I ride it down to Gainesville to see you ???
kevinx
Posted 2010-05-31 3:56 PM (#61209 - in reply to #61207)
XRsteve - 2010-05-31 3:54 PM
I'll get back ith you on this later in the week. Adding the extend though is a 5 minute job
XRsteve
Posted 2010-05-31 7:52 PM (#61235 - in reply to #44403)
Thank you Kevin...........................
Gadget
Posted 2010-07-10 2:47 PM (#64234 - in reply to #44403)
KevinX,
Can you quickly explain this rev extender thingy and advise on how big a job it would be for me to install myself??
Gadget
kevinx
Posted 2010-07-10 5:08 PM (#64238 - in reply to #64234)
Gadget - 2010-07-10 3:47 PM
KevinX,
Gadget
Rev extend is a replacement ECM that has code written out to 6200RPM in all gears. This allows you to hold your shift for max power. Replacement is as simple as removing the seat, and removing 4 bolts that hold the ECM
bigwill5150
Posted 2010-07-10 9:35 PM (#64251 - in reply to #44403)
Reno County, KS
I'm trying to follow this but the information is not easily found. Is this something he is offering or going to offer on an exchange basis? If so, does anyone have a current ballpark price? I would email him but he has been extremely busy lately.
kevinx
Posted 2010-07-10 9:42 PM (#64253 - in reply to #64251)
He is selling them now for about $250 with exchange, or add like another $250 core charge. Call and speak to Bre, and she can give you details
