Center Stand Review, Observations ?
wjoel
Posted 2009-08-22 7:36 AM (#42178)
Subject: Center Stand Review, Observations ?
Northeastern Penna.
Just being inquisitive. Anyone heard, had installed, or seen the new center stand option on a Vision ? It would be a plus if everything is right. Now, before this became an option, don't you think
it would have been tested by some Engineer or R&D guy, so it should work out in our favor, right?
VaParadox
Posted 2009-08-23 8:30 PM (#42252 - in reply to #42178)
Subject: Re: Center Stand Review, Observations ?
Richmond, Virginia
I said this earlier, and will say it again. WHO can stand beside their Vision grip the high handlebar and the left passenger grab rail and lift and pull back on this bike????????? I think the weight and egos of the bike are going to make this bike especially difficult to lift onto a center stand. While i love the idea, im gonna sit back and watch what happens and just shake my head once all the postings come in from people who either cant get it up or dropped it over on the right side......... trust me, its gonna happen.
Posted 2009-08-23 8:50 PM (#42253 - in reply to #42178)
there is a certain amount of schooling needed for centerstanding, but it is easily done when mastered. There are two actions going on with leverage, it is pull back on bars with a push down on lever on stand, and on a level plain would not take much effort. -- we'll see how it goes with the Vision....
personally, I won't know as I don't plan on getting one... well, maybe for a road trip, but you know, you can't the rear tire out anyway without some additional jacking....
ElroyJ
Posted 2009-08-24 2:28 PM (#42282 - in reply to #42178)
Subject: RE: Center Stand Review, Observations ?
Centennial, CO
I am still trying to figure out why you need a center stand???
Teach
Posted 2009-08-24 4:33 PM (#42292 - in reply to #42178)
Yep as VA stated there is a technique for getting a bike on the center stand easily. I would assume Victory wouldn't put one out if you were likely to hurt yourself given the liability climate we have.
EJ, there are several situations in which a center stand is very handy; cleaning rear wheel, checking and airing rear tire, long term storage such as winter, chcking and changing oil when you need the bike upright, fixing a rear flat on the side of the road, etc.... They are HANDY but not necessary since you can't get the tire out from under the bike while on it. But back in the day of hinged fenders, lol...
Edited by Teach 2009-08-24 4:34 PM
Miles
Posted 2009-08-24 4:55 PM (#42293 - in reply to #42282)
ElroyJ - 2009-08-24 2:28 PM
I think "need" might be a strong word... but certainly handy. I use my chock anytime I'm loading the bike for a trip. Makes balancing the load and general access a lot easier. Of course cleaning and maintenance is much easier as well. I had to add some oil while at the AVR... what a pain in the arse... put in a little... lift the bike up.... wait.... remove dipstick, check level... put it back on the side stand... run around and unscrew the dip-stick.... add oil... replace dipstick... wash rinse repeat... doable.. just annoying. Even adding or checking air is so much easier on the chock or on bikes with a centerstand.. Again.. not necessary... just easier.
ElroyJ
Posted 2009-08-24 6:58 PM (#42299 - in reply to #42293)
Centennial, CO
Miles - 2009-08-24 2:55 PM
Hmm...well, this was my thought as well. Why not just utilize a jack stand and prop it up on both sides? No "NEED" for a center stand. I can't see the use other than that as while I am on the road, I would have ZERO need for it.
Posted 2009-08-24 7:09 PM (#42301 - in reply to #42178)
If I had a centerstand I wouldn't "NEED" a jackstand and props, plus I would always have it on the road.  Had one on my last three bikes (including two dual-sports) and even though I didn't use it all the time, it was really nice to have.
Miles
Posted 2009-08-24 7:11 PM (#42303 - in reply to #42299)
ElroyJ - 2009-08-24 6:58 PM
Well as example... on my trip to the AVR... I unloaded the bike when I got there... did three partial unloads at hotels along the way to and from... had to check the oil...
Again it was all obviously "doable" without a center stand or chock... would have been real nice to have one. And for this trip... the most use would have been at Gas stations to be able to actually "fill" the tank. I'm pretty cheap.. but if there was a center stand available for a V92C for less than about $300.... I'd have one.
chesshiretuna
Posted 2009-08-24 7:16 PM (#42304 - in reply to #42178)
I have limited room in my shop, so the center stand would let me pull in, put the center stand down on a turntable and spin the bike around for departure. I have been backing the bike in or out as required, but the driveway is not paved. A 890 lb. bike is not always user friendly on rough surfaces and tight radius. I currently use my floor jack to do this but the shop floor is not as smooth as some garage floors.so this is a little less than ideal for me. I'm 6'2" and 260lbs. so its not a lack of power issue. I have had oter bikes with and without centerstands and the center stand is always handy.
wjoel
Posted 2009-08-24 7:58 PM (#42309 - in reply to #42178)
Northeastern Penna.
If you go on the Polaris website and check this item, it is out of stock. Based on that, there are people out there in the US of A that have the center stand on their Visions, right ?How else would they be out of stock ?
Crawford
Posted 2009-08-24 8:39 PM (#42315 - in reply to #42178)
Regina Saskatchewan Canada
Either that or they have never been in stock yet! Which is more likely the case.
Teach
Posted 2009-08-25 10:53 AM (#42352 - in reply to #42178)
Yep you're right Crawford. The website has been showing the new 10 accessories "out of stock" since their posting. Probably haven't received the new accessories from suppliers yet. My guess is around October they will be available for order and in stock.
wjoel, no doubt there will be quite a few folks who will install a center stand as they are just handy for those of us who have grown up on bikes that had them as standard equipment. Quite frankly I don't know why manufacturers quit installing them standard other than they could cut some cost and nobody griped too loud. Funny how we now buy them as accessories, lol.....
Cruzin
Posted 2009-08-25 11:36 AM (#42359 - in reply to #42178)
I ordered one in early August. My dealer told me the expected ship date is in November.
Posted 2009-08-25 12:14 PM (#42363 - in reply to #42178)
I'm wondering if the centerstand will make the Vision more stable on a jack? It is round bottom without it, but it would seem to square up the bottom, that alone MIGHT be worth it besides the value on the road. However, there again, you would only be able to pull the front wheel and not the rear on the side of the road.
sledgehammer
Posted 2009-08-25 12:51 PM (#42367 - in reply to #42363)
Corpus Christi Tx.
My 95 Gold Wing Aspencade had the centerstand and it came in handy many times. I had no trouble getting that big bike on it and I'm sure I won't have any trouble with the center stand, on order, for my Vision. I welcome it because of oil changes, checking and airing tires and other maintenance that can be done with the center stand. And if it tips over on the side, well that's when the tipovers come in handy as well. Hopefully not. :-)
Ride safe.
Teach
Posted 2009-08-25 1:28 PM (#42373 - in reply to #42178)
VA, you are correct you wouldn't be able to pull the rear, but it makes installing a plug in a flat rear a LOT easier. I don't run plugs in my bike tires but they'll work until you find a bike shop rather than sitting on the side of the road waiting 2-3 hours for a flatbed to tow it in. If you do trips this is a great accessory to have installed.
Cruzin, thanks for the info.......
buddahead
Posted 2009-08-25 8:04 PM (#42397 - in reply to #42178)
SF Bay Area
and then there is the cornering clearance of the bike, and the added weight...
wjoel
Posted 2009-08-25 9:02 PM (#42402 - in reply to #42178)
Northeastern Penna.
I would get the center stand, would make it much easier to clean rear wheel plus for storage
over the winter. To me, that is worth it. I test rode an 08 GW last year and used it's center stand, which you had to do manually, like the Vision will be.It was relatively easy to put on the center stand.
Posted 2009-08-25 9:18 PM (#42407 - in reply to #42178)
if you're weighing on storage, there is always those little wheel chock thingy's that clamp your bike upright. Also, if I EVER thought of storage for my bike I would want to lift it entirely off the wheels for the duration. Just my preference.
Posted 2009-08-25 10:09 PM (#42417 - in reply to #42397)
buddahead - 2009-08-25 7:04 PM and then there is the cornering clearance of the bike, and the added weight...
I'll be the first to test the cornering issue but I can't imagine the folded legs of the centerstand would drag before the outer edges of the floorboards.  The weight is so low it is basically a non-issue based on other bikes I have added them to.  The only time I knew there was a centerstand onboard while riding was if I hit a nice sized bump I could feel the centerstand thump against its rubber stops underneath.
Teach
Posted 2009-08-25 10:16 PM (#42419 - in reply to #42178)
You guys gotta show me how you're dragging your floorboards.....
VisionTex
Posted 2009-08-25 10:37 PM (#42421 - in reply to #42419)
LaPorte,Tx.
Teach,
http://www.youtube.com/watch?v=7T18KxY_sJc
Posted 2009-08-25 10:41 PM (#42423 - in reply to #42178)
First you buy a sport-touring bike and learn to trust your tires and suspension enough to drag those pegs.  Then you buy a Vision.
Posted 2009-08-26 5:09 AM (#42437 - in reply to #42178)
when i first got my vision i did a lot of floorboard draggin' until i learned to ride better. i lean to the inside on the saddle like you're suppose too and that keeps the bike upright. i can still get it to dip and make some noise when i want to though....
