Oil changing thoughts
pollolittle
Posted 2007-11-02 8:18 AM (#1477)
Subject: Oil changing thoughts
Brighton, TN
Not looking for a debate per se or looking to rile things up (maybe) but here are my thoughts on oil changes:
I changed my own oil at 500 based on book. The first one early on, I agree with for the break in portion of it all. But I am really starting to wonder about the whole break in thing anyway. I am not so sure that most of this is just cut and paste and the mind numbing drone is doing it that way just because, "THATS THE WAY WE HAVE ALWAYS DONE IT." I don't really see the point of changing it that often. When I talked to the Polaris Engineer I had asked him about how many miles they figure a person puts on a bike, he said their rule of thumb is around 2000 I think. This would then give them about an extra 500 miles to play with and make a generalized statement to change oil at 2500 for the masses. This would put a "normal riding person changing their oil within a one year time span and only 2500 miles. So, to me personally, they did a good job of getting the owner to change their oil at least once a year if not twice. Since I am over 1800 miles on mine in 1 month and 5 days. I will be like tralphaz and go probably further than 5000 between oil changes and try around 7k to 8k. I used to be of the mind set at 3500 miles between auto changes and the more I read, I found out that a lot of it is marketing and generalizations. The "normal person" only puts about 12,000 or less miles on a vehicle per year. I however, put more like 30,000 per year. So, I am outside the norm, naw really, following the own manufacturers recommendations I can go 7500 miles between changes in my car, which once again is for the "norm". If my GMC dually 1 ton can go 10,000 to 13,000 plus between oil changes based on the oil meter and their book recommendations, and big rigs can go 20,000 to 30,000 between oil changes, I don't think I am that far off. Just trying to use a little common sense to all of this.
I have seen quite a few quys that use AMSOIL or MOBIL 1 Synthetics or other brands, and I see where they send off samples to a some place that will analyze their oil for them. Once it hits certain numbers I don't remember which, then they will change it, until then, they keep right on going. If memory serves me right, they are getting way over 20,000 on most of them.
For all you Harley riders, it seems that Buckeye is claiming that 2,500 is far outside the reach of the Harley's. He seems happy to go 2500 miles and get it changed. What is the recommended range for Harley's? My buddy rides his 2001 Harley Heritage Classic Softail about 1500 miles a year and changes his own oil. What a pain especially the way he describes it. Pull the oil filter and oil runs all over the front of his motor case. He has to tip the bike straight up or tilt it away from the kickstand to get it to drain. I love changing mine.
Posted 2007-11-02 8:58 AM (#1482 - in reply to #1477)
Subject: RE: Oil changing thoughts
I'd be real interested to know how often the Vision guy changed his oil during the 11 day/11,000 mile Iron Butt Rally.  Also would like to know if the original tires made the whole trip.
g1nomad
Posted 2007-11-02 1:37 PM (#1489 - in reply to #1477)
Subject: Re: Oil changing thoughts
SC, Bluffton
It is all about warranty, not about how often we feel it should be changed.
Bearcat
Posted 2007-11-02 5:56 PM (#1494 - in reply to #1477)
Prescott Valley, AZ
I also am a bit outside the "norm". For the past 8.5 years I have had a 65mile round trip to work and back six days a week, year round. If it wasn't below freezing or wet when I left the house I was on two wheels. My current ride is an 05 Nomad (traded an 03 Nomad to get it), call me anal but I have changed the oil (and filter of course) at 1500 miles religously. Primary reason is that most all of the miles I rack up are at 65-75 mph and it does in fact look dirty by that time. As good as the oils are these days they are still designed to lubricate and pick up impurities that live in their house. A mere $20.00 bucks every four weeks or so seems like well spent insurance to me. Once I get the Tour Premium I've orderd I may relook this as my comute is now only 14 miles round trip but I still think you can't go wrong by changing your engine's life blood a little more often than the recommended intervals.
Miles
Posted 2007-11-03 12:55 AM (#1499 - in reply to #1477)
During the warranty, at least the first part of it, I do the oil changes at the recommended interval, at least up to 10,000 miles.
After 10K I tend to do 5000-6000 mile intervals. I check everything at these intervals. For my habits, this seems to work just fine. Never had a problem on any vehicle car or bike doing this.
BUCKEYE
Posted 2007-11-05 7:34 AM (#1513 - in reply to #1477)
29 Palms California
with the break in, whats with the 500 miles going no faster than 55? doesn't the factory put these things thru the paces first?
pollolittle
Posted 2007-11-05 7:53 AM (#1515 - in reply to #1477)
Brighton, TN
I sincerely doubt they crank every machine and let it run at varying speeds. Like any good company they probably take a "Sample" and run them through their paces. Most everything is CNC made or machine cut or stamped, with very close tolerances. I can't imagine that any of these bikes wouldn't be race ready right out of the box. Unsure what you are talking about the 55 mph. Book doesn't reference any speed limit. What it references is 1/3 throttle input, 1/2 and 3/4 throttle input for extended timeframes. It doesn't say anything about not revving it to full throttle, just not for extended timeframes and vary speed and throttle input.
Posted 2007-11-05 8:58 AM (#1517 - in reply to #1477)
I was told that every motor is bench tested after assembly and every bike was dyno'd when completed.
pollolittle
Posted 2007-11-05 9:42 AM (#1518 - in reply to #1477)
Brighton, TN
I am sure they crank every motor just to be sure they work. Who wants to send a bike that doesn't run? I am not sure about the dyno part unless there is a bench location before it gets stuck in the bike, where they can just drop it and see. Otherwise, to time consuming and cost prohibitive. I didn't see a spec sheet for a dyno run when I got my bike.
RedRider
Posted 2007-11-05 11:25 AM (#1521 - in reply to #1477)
Now you are forgetting some of most important info for your oil changes. What are your driving conditions. Dusty wind blown dust and air filter not properly maintained? I would be real careful how far you go.
The company states a number that will cover all the bases of different drivers within given parameters. I change my Amsoil every 5,000 miles and check it often for level and condition. I will not go way over because to me the oil is th blood of my bike and I don't treat my blood like crap.
A simple question(s)? Are you doing this to save money? To save our dependency on foreign oil? To save our environment?
tralphaz
Posted 2007-11-05 12:07 PM (#1523 - in reply to #1521)
Lemme stir the pot one more time, I think the 2500 mile interval is overkill, my wife's VTX 1300 manual places the interval for her bike at 8k, the Vic on the other hand has a larger oil capacity and semi-synthetic oil, the VTX recommends regular M/C oil.
pollolittle
Posted 2007-11-05 12:44 PM (#1524 - in reply to #1477)
Brighton, TN
I am basing my thought pattern on just Good Old Fashioned Common Sense. This is something I think that is highly overlooked on our part, as being consumers. How many miles have you driven or put on a vehicle, whether you have driven it or not? Then, what has been your own personal oil change regimen. Mine own personal driving common sense, puts my oil change meter in this range. Just like tralphaz, what's the point if it is all marketing and money anyway.
Let me look at this from a marketing business point of view. The business, Polaris/Victory, would like at a minimum to have the oil changed approximately once every year. Knowing that most "normal people" quit riding when it starts to get cold. They have their winter storage procedures you should follow. Which includes changing the oil before storage, and then changing it again when you pull it out, if it was possible humidity got to it. I would say to the last part, take it on a ride, let it get to operating temperature for 10 minutes which should have gotten rid of just about any condensation at all inside the crankcase. The change schedule I just quoted for the Normal person puts the miles on the bike around 2000 per year, and gets the oil changed, before they put it into storage. I can agree with that. I don't think mine will go into storage. Tralphaz, probably won't put his into storage either. Then if I can get you to buy more oil with my name on it that is money for my bottom line, business thinking again. If I also get you to change it more often, my dealer makes more money, which also brings you back into the dealer for other items/products.
So, in answer to your question. I am doing this and saving money, this idea alone is not to skimp on the almighty dollar. It is just common sense. To save our dependency on foreign oil, I think not, oil helps our economy go round'. I have bought synthetic for the first time, just for my bike, just to see if I can make even more common sense. To save our environment, I do pretty good at recycling used motor oil, but if I don't REALLY need to change it so often, then yes, I am saving the environment.
Tralphaz, if memory serves me well, there is only one spot on that bike to change oil, right? The crankcase and primary etc. are all in the one case, right? Which would mimic the current Victory Vision.
tralphaz
Posted 2007-11-05 1:10 PM (#1528 - in reply to #1524)
pollolittle - 2007-11-05 9:44 AM
Correct, the tranny and engine share oil.
VisionTex
Posted 2007-11-05 1:30 PM (#1533 - in reply to #1524)
LaPorte,Tx.
Your right common sense goes a long way in everything. My Kingpin has 30,000 plus miles on it, I change oil around 5000 miles, not one issue. The one thing I don't do and that is short trips, like under five miles. If I was doing that, I would probably change more often. I use a fully synthetic 20w-50 oil. I was just on the AmsOil website looking at their oil and see they have a new 10w40 that is recommended by Victory. I may use that oil in my new Vision and continue with the 5000 mile changes.
Posted 2007-11-05 1:34 PM (#1534 - in reply to #1477)
Here's a picture of the dyno lady at Spirit Lake.
http://www.motorcycle-usa.com/Galleries_IndividualPhoto.aspx?Gallery=1098&Main=12&Sub=22&Image=33063&PostBack=1&Media=1
pollolittle
Posted 2007-11-05 2:42 PM (#1536 - in reply to #1477)
Brighton, TN
Well, I guess you are right! I would have never thought she could do that. They must have more than one person doing this job, because the next photo or so down states the facility puts out a vehicle every other minute. Which would put her way behind. If she cranks it up to 80 and leaves it there for four minutes, I am considering my machine broke in when I get it. My statement is for naught, since I now have over 2000 miles on it.
Miles
Posted 2007-11-05 4:49 PM (#1541 - in reply to #1477)
As someone pointed out, the Victory's share the engine oil with the Transmission so the "type" of driving should really be considered too and probably the reason for the closer intervals. On my other bikes as example that have a dry clutch, the result is the recommended service intervals are 6000 miles.
Rebel
Posted 2007-11-05 5:56 PM (#1542 - in reply to #1518)
Linwood, MI
Not to hijack the thread, but I work for GM and we run every engine at wide-open throttle for several minutes before it ever goes in a car/truck. This helps spot leaks and any other problems before it ever gets into a vehicle. I would imagine that pretty much every vehicle manufacturer does the same thing. Even with the cost of the test room and personel for testing, it's still cheaper than doing an engine recall for a problem that could have been caught during assembly.
cjnoho
Posted 2007-11-05 8:43 PM (#1549 - in reply to #1477)
So Cal
Im with Rebel, if everything hasnt seated by the time it goes in the box, it never will. used to be, the first oil change was to remove any stray particles left behind from machining and breakin. I would be more inclined to replace the filter early than the oil.
The big thing is the warranty. Untill we find out how Victory will handle warranty claims I plan to follow their rcommendations. If you plan on doing your own. Make sure you save reciepts and doccument milage.
BUCKEYE
Posted 2007-11-05 8:58 PM (#1551 - in reply to #1477)
29 Palms California
machined "particles" is the only reason I can see for the 500 mile change. With the recommended 91 oct, that would have to be one of those "stickers" the oil companies make them put on. How in the heck does 4 points make a difference? Say, you devolope a problem, what the heck are they going to do, void the warrenty because you used 87? SCAM! then again, everyones out to get my money! If i don't get my vision or some kind of info, im un-sheathing the K-Bar and going into stealth mode.
ward
Posted 2008-02-08 10:33 AM (#5066 - in reply to #1477)
cambridge springs pa
All I can say is AMSOIL,AMSOIL,AMSOIL! I have used Amsoil for the past 15 years in every motorized vehicle I'ved owned. I changed my 06 Kingpin to Amsoil at 2500 miles, to make sure the rings were seated. I changed the oil every 8-10 thousand miles after that. No problems. The bike ran 15 to 20 degrees cooler. My other vehicles I own now or in the past, cars & trucks, I change the Amsoil every year or 25,000 miles. The adverage mileage I get from my vehicles are 250,000 to 350,000 of service. Remember, AMSOIL,AMSOIL,AMSOIL! Ward
maddog
Posted 2008-02-08 11:14 AM (#5068 - in reply to #5066)
Nebraska
ward - 2008-02-08 9:33 AM
I used Amsoil in my TC. It had 70K on it when I traded for the Vision. I changed it about every 5K. No problems. It never had any of the cases opened on the tranny or engine. The next oil change on the Vision will be with Amsoil.
mike s
Posted 2008-02-08 2:22 PM (#5076 - in reply to #1477)
Valdosta, GA
My view...If you use conventional or "semi-synthetic" oils AND travel anything other than highway (not just interstate) miles, you should change your oil at least every 3,000 miles in a Vic. With my Vegas and my Jackpot, I could always tell when it was getting close to time to change the oil. Shifting, especially downshifting, would feel different and finding Neutral became for difficult. when the oil needed to be changed. This usually started around 2000 miles. As I average 15,000 miles/year, I needed to find something better/longer lasting. I tried a couple of different synthetics (Mobil 1, Shell Rotella, Havoline V-Twin Synth) and found MY best results were with Amsoil. Once I started using it, I found I could extend the change interval out to 5,000 miles before I would begin to notice those shifting differences. The other synthetics were better than dino oils, but still fell short of what I saw with Amsoil.
As for Octane...91 has been recommended for Vics I think since the beginning. A large part of that was because of the compression rations found in the 92" and 100" motors. With the lower ratios in the Vision motor, I wouldn't think using even 87 octane would cause any problems. However, for only ~$1 more per tank, I'll likely continue to use Premium...
cjnoho
Posted 2008-02-09 1:27 AM (#5104 - in reply to #1477)
So Cal
I bend over fenders 5 days a week, 8 hours a day (+1 Sat. a month). I bought the 5 year extended warr. Giving someone else $300 every 2500 mi. for service is well worth it to me. Plus it keeps the dealer happy and the company happy. If I ever need to use the warr. I know the dealer will extend extra effort to get things covered. Why? because he wants me to keep comming there to spend my money. No matter how well I take care of this bike it will eventually wear out and need major repairs, or replaced. If I take care of my dealer now, he has more incentive to take care of me later.
Posted 2008-02-09 8:37 AM (#5116 - in reply to #1477)
Just to clarify info about Victory's dyno..
They run EVERY bike on their dyno through a warm up cycle and a high speed cycle (at highway speeds). I've personally watched them on several occasions. The bike is run at different speeds for almost 10 minutes, all the while they are also checking electronics, brakes, temps, air/fuel via sensors either plugged into the wiring harness or up the tailpipe.
As for oil, I used the Victory semisynthetic during the first couple oil changes, then switched to Amsoil and have stayed with it for years. When I made the switch the bike had less engine noise. I've had no trouble with with my clutch (some folks believe Amsoil is TOO slippery).
