Wheel Chock/Tie Downs for transporting Vision
MassiveMassis
Posted 2013-01-12 11:07 AM (#129444)
Subject: Wheel Chock/Tie Downs for transporting Vision
Southern California
I plan on transporting my 2011 Vision in the garage of my 5th wheel for a 300 mile trip next weekend.
I'd like some input on wheel chocks and tiedowns.
I remember seeing a thread somewhere that mentioned the tiedown procedure is critical, and I don't want to regret not asking how to do it properly.
I also need a good wheel chock, but because I do not want it permanently installed in the floor of the trailer, I'd like one that is secured by ratcheting straps to some anchor points in front and behind where the bike will be.
Any advice would be appreciated!
Monkeyman
Posted 2013-01-12 11:15 AM (#129446 - in reply to #129444)
Subject: Re: Wheel Chock/Tie Downs for transporting Vision
Peru, IN
Depends how much you want to spend. Condor makes a nice chock. You don't have to bolt it down although I would. There's a tie down point on the frame behind the headlight area.
MassiveMassis
Posted 2013-01-12 11:23 AM (#129447 - in reply to #129446)
Southern California
Thanks Monkeyman, I assume tying down to the left and right is a good idea from that point? I'll look up under there today and work it out.
I see lots of Condor chocks online, any one in particular you know would be best for the 925# beast?
CoolHandLuke
Posted 2013-01-12 12:50 PM (#129451 - in reply to #129444)
, FL United States
I have both the stand-alone and the bolt-down Condor chocks. I use the stand-alone in trailers that don't have a notch for the front tire. The bolt-down is in my Toy-hauler and I have aprox 25 k miles traveling with my '08 Vision and have never had a problem with either one. They are pricey but worth it.
MassiveMassis
Posted 2013-01-12 12:53 PM (#129453 - in reply to #129451)
Southern California
Thanks Iron Butt, I'll check them out today.
Any tie down advice?
ByteN2it
Posted 2013-01-12 1:51 PM (#129455 - in reply to #129444)
Subject: RE: Wheel Chock/Tie Downs for transporting Vision
I use a Harbor Freight version of the Condor that's mounted in the bed of my truck-that & a Big Boy ramp have worked great for me the times I've had to piggyback my bikes.
http://www.harborfreight.com/motorcycle-stand-wheel-chock-97841.htm...
http://www.discountramps.com/motorcycle_ramps.htm
Posted 2013-01-12 2:53 PM (#129459 - in reply to #129444)
What about tying it down using those holes in the front tipovers, with eye rings installed? It is rumored that Ma Vic ships these bikes and ties them down with an eye ring threaded into each front tip over.
taz456
Posted 2013-01-12 3:06 PM (#129461 - in reply to #129444)
I have never had my vision in my toy hauler. I have had a v92c and my hammer in there. I would use the bolt down model as said earlier. THey make them were you bolt down a base plate that gets bolted with carriage bolts to the floor. the chock slides over the base and locks into place but can be removed leaving only the base plate. I have one that came highly recommended but I do not remember the name and my trailer is put away in winter storage. sorry. You also do not mention how long you toy hauler is but there is a lot of movement inside a trailer, the longer the trailer the more chance for movement. If you do go with the boltless version, make sure you stop often and check you tiedowns early in the trip. Best of luck
MassiveMassis
Posted 2013-01-12 6:18 PM (#129469 - in reply to #129459)
Southern California
willtill - 2013-01-12 12:53 PM
Yes, I saw a new 2012 at the dealer with those eyelets in the front tipover guards, I did not even realize they were threaded for that, great idea.
MassiveMassis
Posted 2013-01-12 6:30 PM (#129470 - in reply to #129455)
Southern California
ByteN2it - 2013-01-12 11:51 AM
This looks like a great plan, along with strapping the bike down from frame tiedown spot and rear tipover anchors.
I just called the local Harbor Freight and they have it in stock, I'll pick it up tomorrow.
I'll place a wager I won't get out of there without a half dozen things I didn't know I needed til tomorrow though, thanks Byte!
MassiveMassis
Posted 2013-01-12 6:32 PM (#129471 - in reply to #129461)
Southern California
taz456 - 2013-01-12 1:06 PM
Thanks Taz, I think I may blend both technologies and bolt the one from harbor Freight to a large plate to eliminate any movement.
I appreciate the help!
1951vbs
Posted 2013-01-12 8:22 PM (#129476 - in reply to #129444)
The tie down under the headlight works very well. It metions it in the owners manual. Just run two soft ties through the slot and ratchet strap it down. I also used the tipover eyebolts (got some from the dealer) as an extra prcaution and tied down the back from the rear tipovers. I think if I flipped my trailer the Vision would still be tied to the floor but upside down.
baadawg
Posted 2013-01-12 8:24 PM (#129477 - in reply to #129444)
Chattanooga, TN
Don't rely on the handle bar tie downs! I've heard it will mess up your steering. Make sure you use the eyelets, I'd pick up a pair from your local dealer. He should have plenty from the new bikes.
savage
Posted 2013-01-13 8:04 AM (#129488 - in reply to #129444)
I use a removable chock made by Moose Racing. The mounting plate bolts to the floor with carriage bolts and the actual chock slide into the base and can be removed in about 30 seconds. I have used this chock with my '01 Royal Star Venture, my '08 Vision and my '12 Cross Country Tour. I have it mounted in a 38 Ft. Victory Lane fifth wheel toyhauler. DO NOT use cheap tiedowns as I have had the Wally World set that I have come loose on some long triips.
As to using the eyebolts on the tipovers.....why would you want to when a more substantial tiedown point is already provided which is cast into the frame vs. the bolt on tipovers with screw in eyebolts. I always used the tiedown point on my Vision and it was always more solid than my RSV or my CCT.
Posted 2013-01-13 8:16 AM (#129489 - in reply to #129488)
savage - 2013-01-13 9:04 AM
Well.... the tipovers are built into the frame; and the eyebolts are used by Victory to tie it down. So why not use them?
I guess you could augment the tipover tiedowns with where one would utilize the tiedown pint cast into the frame as well.
Edited by willtill 2013-01-13 8:17 AM
norcan
Posted 2013-01-13 9:02 AM (#129491 - in reply to #129444)
Edmonton Alberta, Canada
I have a single axle enclosed motorcycle trailer, which I tow behind my 25 ft 5th wheel, it has a bolet in wheel chock, which 4 bolts with thumb wheels for easy and clear floor when removed.(came with trailer) I use up front 2" ratchet straps( commercial grade not wally world) which have hooks to fit in the eye under headlight. On the rear only to stop back tire from bouncing side to side I use 2 of the 1" ratchet tie downs wrapped around the rear tip overs. I have never had a problem. I thought of using the eye bolt system,however I prefer to tie down as high as possible as there is less stress on anchor points. Remember while shipping the bike is completely empty and a items such as windshield is not installed. Just remember to use good quality straps. 1' straps are rated for approx 800 - 1000# static. Our toy haulers and travel trailers are on springs and tend to bounce a lot more than air ride trailers that deliver from the factory. ( think of positioning a extendable ladder, the higher you grab it the easier it is to handle it)
I trust the cast eye on the frame to the eye bolts which need to be installed and then removed. Also I would not trust a 5/16 bolt which could strip out or break if your anchor point is pulling on an angle and not straight on.
Happy trailering.
Edited by norcan 2013-01-13 9:12 AM
savage
Posted 2013-01-13 9:37 AM (#129494 - in reply to #129444)
norcan......that is exactly the point I was trying to make. You presented it a lot better than I did!
Rainmans 09
Posted 2013-01-13 4:17 PM (#129510 - in reply to #129444)
This is what I use:
http://store.condor-lift.com/products.php?product=Pit%252dStop%7B47...
http://powertye.com/store/index.php?dispatch=products.view&product_...
MassiveMassis
Posted 2013-01-15 11:09 AM (#129594 - in reply to #129510)
Southern California
OK guys, thanks so much for all of your input, I'm locked and loaded, ready to ride this weekend!
I ended up using the Harbor Freight (believe it or not, very stout) chock, which I strapped down to 4 corners of 5th wheel garage using 1200# ratchet straps.
I then tied two more to the tie down point on the frame for the front and 2 more to the rear wheel, pulling diagonally to eliminate any left/right movement. Solid as a rock!
By the way, I went to the Harbor Freight store expecting to pay $90, but my buddy found a coupon for that chock for $50, plus he had a 20% off coupon that resulted in $40 total for the chock, then I spent $60 in good quality straps, $100 total to save my baby from tipping was well-spent.
Thanks again for all your help!
Lone Ranger
Posted 2013-01-15 5:42 PM (#129624 - in reply to #129444)
Cleveland, GA
Just so you know, the eyelets under the floorboards are NOT designed to be primary tiedowns. They are used in the shipping crate to help stabilize the bike. The primary tiedown is the slot under the headlight. Use the eyelets as additional, but I would NOT use them as my main tiedown.
I have trailered mine about 300 miles in a toy hauler RV, and a couple of times on a trailer. Both with chocks and without. No problems.
Monkeyman
Posted 2013-01-15 11:37 PM (#129645 - in reply to #129444)
Peru, IN
MassiveMassis and Lone Ranger --- What toy haulers do you guys have? I'm thinking about buying one (used) if I can convince the bank to loan me the money.
Lone Ranger
Posted 2013-01-16 7:12 PM (#129667 - in reply to #129645)
Cleveland, GA
Monkeyman - 2013-01-16 12:37 AM MassiveMassis and Lone Ranger --- What toy haulers do you guys have? I'm thinking about buying one (used) if I can convince the bank to loan me the money.
Coincidentally enough, it is a Victory Lane. But if I ever get another, I think it will be a Voltage. I think it's the successor to the Victory Lane and is laid out and planned much better: http://voltagehaulers.com/?site=voltagehaulers
MassiveMassis
Posted 2013-01-17 10:08 AM (#129693 - in reply to #129645)
Southern California
MonkeyMan, we have a 2008 Raptor 3812, it is actually 40ft including a 12ft garage. We use it for offroad side-by-side and motorcycle fun primarily, but my wife and I will take the street bikes out as a couple occasionally.
It cost about $50k new, but there are tons of great used ones from folks who do not use them or cannot afford to keep them these days.
One thing to consider, if they are too long (over 32' in my case), most state parks do not allow them, so think it through for some camp needs if you like full-hookup campgrounds.
Have fun!
Monkeyman
Posted 2013-01-18 3:28 AM (#129716 - in reply to #129444)
Peru, IN
Thanks, guys (I'm just assuming you're both guys). I've seen pics of the Victory Lanes, Voltages and Raptors. All VERY nice. I'm not too worried about state parks. I'm planning on living in one (and only need the garage for the Vision) with little traveling (couple trips per year) so, the bigger, the better. Most of my trips would be under 2 weeks so I think I could go long enough (just me and my cat) without a full hookup site to get by. (Or maybe not. I don't know much about trailers.)
Lone Ranger
Posted 2013-01-18 2:40 PM (#129746 - in reply to #129444)
Cleveland, GA
I've been living full-time in mine for right at three years now.
