2008 Vision Performance Advice
hawkeye2633
Posted 2013-01-04 8:12 AM (#129140)
Subject: 2008 Vision Performance Advice
Thanks to everyone on this site that share their experiences with their Victory's. I have a 2008 Premium Tour that I run without the trunk, Big Honkers, intake plate filter, fuel controller and auto tuner. I guess the only thing left is the cams. I also have a 2007 Kingpin with Ross 2 in 1 exhaust, S&S Intake and download. I had it dyno and it's putting out 95 HP with 103 lbs of torque. I had a buddy ride the Vision and I barely pulled him on the Kingpin telling me that the Vision is running pretty good.
I contacted Kevin at the dealership in Gainesville, FL and he would do the cams for about $1200. My question: is it worth it? Any insight is appreciated.
Hawkeye
XRsteve
Posted 2013-01-04 8:44 AM (#129141 - in reply to #129140)
Subject: Re: 2008 Vision Performance Advice
Georgia, west of Atlanta
Oh yes..........Add maybe 20 HP.........
V92SC
Posted 2013-01-04 10:17 AM (#129143 - in reply to #129140)
New Orleans, La,
If that 1200 includes the cams and everything that is a good deal. The cams are 520.00, plus gaskets, cam lube,and of course the labor done by a crack Victory wrench I call that a honey of a deal. Hurry before the price increase. Miles of smiles.
rwilly
Posted 2013-01-04 10:50 AM (#129144 - in reply to #129140)
seattle, wa
KevinX did my 08 and it is definitley worth it.
I have cams, intake, stage1 exhaust, Fuel controller and it dynoed at 106 HP and 106 TQ.
Gray rider
Posted 2013-01-04 12:37 PM (#129149 - in reply to #129144)
Tucson, AZ
Kevin X did mine about 2 1/2 years ago. Well worth the cost. Big difference in mid range performance.
Lotzafun
Posted 2013-01-04 4:53 PM (#129160 - in reply to #129140)
Rockford, IL
Well worth every dollar !
But...where are you located? There other guys besides Kevin who can install the cams.
Digby
Posted 2013-01-04 5:25 PM (#129162 - in reply to #129140)
yes ,yes , yes
Posted 2013-01-04 5:50 PM (#129163 - in reply to #129140)
gee you'll have something like 100 horse is that wort it to you
hawkeye2633
Posted 2013-01-04 8:11 PM (#129168 - in reply to #129140)
Subject: RE: 2008 Vision Performance Advice
I live in Tampa, FL if someone knows other mechanics in the area that can install cams.
Thanks
Rainmans 09
Posted 2013-01-05 12:30 AM (#129178 - in reply to #129140)
There is no question!
kris1956
Posted 2013-01-05 4:20 AM (#129179 - in reply to #129178)
If your fortunate enough to live in an area where one of the big three works, as I like to call Kevin,Lloyd and Ryan, then count your blessings and go for it.
RhodeTrip
Posted 2013-01-05 5:03 AM (#129181 - in reply to #129140)
Rhode Island
Figure out what you want for performance (low end torque or high end) then talk to Kevin or Lloyd about it. Lloyd has an adjustable air intake and adjustable timing that they may suggest also depending on what you are after.
MaddMAx2u
Posted 2013-01-05 12:53 PM (#129197 - in reply to #129140)
Orlando, FL
Here's how to get the BEST performance out of any Vision. Sell it and buy a Busa.
Edited by MaddMAx2u 2013-01-05 12:54 PM
Posted 2013-01-05 6:15 PM (#129210 - in reply to #129168)
hawkeye2633 - 2013-01-04 8:11 PM I live in Tampa, FL if someone knows other mechanics in the area that can install cams. Thanks
If you can get two or three more guys Kevin will come to you.
kevinx
Posted 2013-01-08 12:26 PM (#129318 - in reply to #129168)
hawkeye2633 - 2013-01-04 9:11 PM
Thanks
Lots of people from Tampa come here for performance work. It's only a couple hours ride, and you can be at the house for breakfast, and dinner in the same day
cw1115
Posted 2013-01-08 3:05 PM (#129319 - in reply to #129140)
Ruskin, Fl
Hawkeye, I live about 15 miles south of Tampa and went to Kevin's shop to buy my new bike I will be going back REAL soon for the cams. I'll let you know when if you want to ride up.
Edited by cw1115 2013-01-08 3:05 PM
Turk
Posted 2013-01-09 8:26 AM (#129328 - in reply to #129181)
RhodeTrip - 2013-01-05 5:03 AM
I second these thoughts. Adding cams will shift your TQ curve higher in the RPM band, pretty much necessitating a rev limit increase (either with Lloydz reprogrammed ECU, or a PC-V ). With the loss of low end TQ, your KP will walk away from your Vision much more noticeably until you get your RPMs up. There are a couple of things you can do to reclaim most of the low end TQ with the cams, such as adding the Lloydz timing wheel and applying 2-4 degrees of advance, along with Lloydz' "adjustable intake" (essentially, a velocity stack for the Vision's throttle body). You can get back most, but not all of your low end TQ with these two additional items.
The setup you have now, with the top filter and big honkers is about as good as it gets for making great low end TQ on a Vision without motor upgrades. Every dyno chart I have seen shows the Honkers with the best looking TQ curve around. It comes up sooner, and has a great looking shape (lots of area under the curve). Other exhaust may peak slightly higher, but none yield more TQ where you need it. I would definitely consider how you ride before making any leap.
Edited by Turk 2013-01-09 8:32 AM
hawkeye2633
Posted 2013-02-10 8:07 PM (#130692 - in reply to #129319)
Thanks everybody and particularly Turk. I ran into some unexpected expenses and the cams wasn't on the front of my mind anymore. I think I need to have more conversation with Kevinx before I leap which would be late Spring now.
donetracey
Posted 2013-02-11 12:52 AM (#130698 - in reply to #129140)
Pitt Meadows, BC Canada
KevinX - not to mention .... he's a nice guy you would invite into your house ... once you hide your daughter ....
JUST KIDDING - Kevin - I LOVE my KevinXinated VV ! Thank you !
biermark
Posted 2013-02-15 9:37 AM (#130842 - in reply to #129140)
South Carolina
Sorry for a hihack or redirect -
For 106's, are there grinds for increased bottom end? I'm ok with the top end but would like more grunt starting off.
Posted 2013-02-15 10:20 AM (#130844 - in reply to #130842)
biermark - 2013-02-15 9:37 AM
Take a look at these parts for adding low end.
http://www.lloydz.com/store/item_view.asp?estore_itemid=1000113
http://www.lloydz.com/store/item_view.asp?estore_itemid=1000125
RhodeTrip
Posted 2013-02-15 3:33 PM (#130860 - in reply to #130842)
Rhode Island
Yes, call or email Lloyd; he sent KMC Powersports a set for my bike that does just that.
Jim
Turk
Posted 2013-02-16 12:33 PM (#130893 - in reply to #130842)
Lloydz adjustable intake along with his timing gear (wheel) will give you more low end TQ. If I had to do one OR the other, I would go with the intake first!
biermark
Posted 2013-02-19 11:23 AM (#131043 - in reply to #129140)
South Carolina
Has anyone measure the overall length of the adjustable intake? I originally thought the "adjustment" part was on the length but I think it refers to swapping out sleeves to get the smaller runner ID.
On the VT gear, what setting for low end?
Turk
Posted 2013-02-19 11:26 AM (#131044 - in reply to #131043)
biermark - 2013-02-19 11:23 AM
I haven't measured, but it seems like it was around 2" tall. Yes, the "adjustable" part is in the swappable sleeves. I think it's a 42-43mm insert for most applications to increase velocity, and the 46mm sleeve insert is for larger bore/compression motors.
I went with the smaller sleeve, and it noticeably gave back a lot of the low end TQ I lost with the VM-1 cams.
