Really something that pisses me off about the Vision...
Posted 2012-12-20 6:54 PM (#128653)
Subject: Really something that pisses me off about the Vision...
I bought the Victory Vision for many reasons; one of them being a little less maintenance required as you amass mileage. I know all about having to attend to the normal fair, wear and tear as well as consumables that's indicative of motorcycle maintenance and operation. I've always done the maintenance myself. What I especially liked was the lack of valve adjustments.
What I DON'T LIKE is the frikken requirement to change the front fork fluid every frikken 15, 000 miles... WTF?
And the Vic's front shocks are a pain to deal with; needing to compress that spring and all. I can do it.. but I planned to ride this particular bike out of my other two a lot more, without having to fuck with the GAWD DAMNED fork tubes EVERY 15K... What the hell !!!
Thanks for letting me vent.
Edited by willtill 2012-12-20 6:55 PM
baadawg
Posted 2012-12-20 7:53 PM (#128654 - in reply to #128653)
Subject: Re: Really something that pisses me off about the Vision...
Chattanooga, TN
Don't sweat it. The world ends tomorrow, if you ain't done it yet, it don't matter! I have almost 40k on mine and haven't done it once.
victoryvisiontour
Posted 2012-12-20 9:16 PM (#128655 - in reply to #128653)
I prefer to ride it instead of work on it. If it required a lot maintenance I would have gotten rid of it a long time ago. I will rebuild the fork at some point in the future, but I'm not pulling them off every 15k. Remember back when some forks had a little drain screw at the bottom? Oil changes took about 10 minutes per side. Next up is pneumatic forks. You won't have to worry about messing with a spring when that technology finally becomes the common place. Might be a while before you see them on a Victory though.
Posted 2012-12-20 9:36 PM (#128657 - in reply to #128655)
victoryvisiontour - 2012-12-20 9:16 PM
My 1986 Kawasaki Voyager XII had pneumatic forks. They were a wonderful marvel until the fork seals wore out and the forks were permanently bottomed out with no spring action at all, until they were rebuilt. Be careful what you wish for.
Victory would do well to copy the 2 stage centerstand that Kawasaki came up with for the Voyager XII though.
victoryvisiontour
Posted 2012-12-20 10:34 PM (#128658 - in reply to #128657)
rdbudd - 2012-12-20 10:36 PM
Sounds like your Voyager only needed the fork seals cleaned or replaced, not rebuilt. Technology of modern pneumatic forks does not compare to anything of the past. The Showa units can be ran with no pressure and they still work well enough to ride.
Monkeyman
Posted 2012-12-21 12:56 AM (#128659 - in reply to #128653)
Peru, IN
You guys don't get it. This scheduled maintenance is just a good excuse to upgrade. When my forks need that 15k mile service (spring '14, God willing), it'll also be time for some of Witchdoctors powdercoated/milled fork tubes. Since the forks have to be disassembled for the new fork tubes, I win. I'll do an oil change in the spring (early but after sitting for the winter, I'll feel better). What better time for my new K&P filter assembly? I could go on. Just make the most of it.
PhantomX
Posted 2012-12-21 3:31 AM (#128662 - in reply to #128653)
Land O Lakes, FL
For those that let the dealer do a job like this (along with doing the headset bearing lube) what can I expect to pay? I've got about 150 miles and my 15k is due (not bad for less than year of riding!).
Posted 2012-12-21 5:54 AM (#128663 - in reply to #128653)
The dealer near me quoted $150.00 for a fluid change in my front shocks; if I just brought the shock tubes in. But he said he couldn't guarantee his work if I did so.
That's why I'm doing it myself. No way to verify if they actually changed the fluid. I can't ever recall having a good dealer experience regarding maintenance for a bike that I have brought in; in the past.
That's why I do everything myself.
sarvbill
Posted 2012-12-21 6:58 AM (#128664 - in reply to #128663)
Chesterfield, VA
I'm also coming up on my 15,000 mile service.? On my previous bike (2009 Vision) the dealer told me they didn't routinely change the fork oil at 15,000 miles if the seal wasn't leaking.? Not sure?if they really knew what they were talking about or not, but it makes me wonder if they really need a fluid change at 15,000.?
Has anyone seen the Witchdoctor (Jon) video on replacing the seals and changing the fork oil (on a Kingpin I believe)??? He removed the whole internal spring assembly replaced the seals and forkoil without disassembling the spring.? Can this also be done on the Vision??? I imagine the procedure would be similar.? It's a much simpler method and requires no special tools.
http://www.youtube.com/watch?v=J4EvgiA9-Rg&feature=channel&list=UL
Posted 2012-12-21 9:47 AM (#128665 - in reply to #128658)
victoryvisiontour - 2012-12-20 10:34 PM
Yes, new seals fixed them. The Voyager pneumatic forks still had conventional springs also, but when there was no air pressure to help them then the forks would bottom out on any bump. The bike was still rideable , but not very comfortable or confidence inspiring. Of course, when the seals blew out, a lot of fork oil was lost and the damping also went away. Technically, the bike was still rideable. Seems like they were Showa forks too.
I do miss the 2 stage centerstand on that bike though. I wish I had one on my Vision.
marcparnes
Posted 2012-12-21 10:22 AM (#128666 - in reply to #128664)
sarvbill - 2012-12-21 3:58 AM
I don't see how for a few reasons:
1. The damping cartridge has oil in it and really needs to be pumped to get it all out. You can't do that with the spring installed.
2. The oil level is set with the cartridge installed and pumped but not the spring. The idea is to set the amount of oil based on its level rather than its volume.
3. The cartridge has to be pumped by hand to fill it up previous to setting the level. Can't do that with the spring installed.
BTW, if you have an 8-Ball its a snap since the spring isn't preloaded. Traxxion makes an inexpensive spring compressor as well as a more sophisticated one. The cheap one is usable if you have someone to help. I did it alone and it was a pain. I'll buy their better one next time. I did mine at 30K and it definitely needed new bushings and the action was getting pretty sticky by then. The parts are pretty cheap. I got them from Traxxion. I bought a level setting tool from the local bike supply. I think it was like $20 or so.
It is a messy job for sure but pretty simple :-) I also lubed the triple tree bearings at the same time. That is something I wouldn't do again only because I'm not flexible enough anymore otherwise its no big deal.
Marc
jimtom
Posted 2012-12-21 12:37 PM (#128669 - in reply to #128666)
Sand Rock, AL United States
I don't worry about fork maint. Got over 40k and I haven't even thought about it in the 20K I put on the Visionquest. I'm terrible about maint. I haven't done anything but change the oil and filter. I haven't even cracked my owners manual open to look at a maint. schedule. As long as the bike is running good, I just ride it.
opas ride
Posted 2012-12-21 2:28 PM (#128670 - in reply to #128653)
Too each his own as they say......I agree some of us spend way to much time doing what we think is necessary maintenance on our bikes...I want my bike to run as best it can so I follow the owners manual as much as possible as I have never had any real serious issues by doing so......A lot of maint. requirements depend on how hard/easy we ride.....Whatever makes one happy with his ride is all that really matters in the long run.......JMHO
bigdogtx
Posted 2012-12-21 3:24 PM (#128671 - in reply to #128653)
Can a traxxion replacement/upgrade be done at longer intervals than 15,000?
Monkeyman
Posted 2012-12-21 3:45 PM (#128672 - in reply to #128653)
Peru, IN
I agree with doing all NECESSARY maintenance for a long life but some maintenance items aren't always necessary as the book says, like the belt change. I'll probably have the fork oil changed at the right time as I'll be getting Witchdoctor front end parts at the same time. One has to be done with the other but if I wasn't planning on getting bling....who knows.
Denny Pink
Posted 2012-12-21 5:02 PM (#128674 - in reply to #128653)
Subject: RE: Really something that pisses me off about the Vision...
Fork oil isn't subject to engine combustion heat or gear shear, so it stays relatively clean for a long time. Oils and seals have improved over the years. Victory mechanics have told me not to worry about it. The oil will be changed if and when new fork tube seals are needed. That's good advice!
Denny Pink
2008 Vision
2002 V92C
Cometman
Posted 2012-12-21 5:51 PM (#128675 - in reply to #128653)
Simi Valley, CA
My forks were rebuilt at 45k, under warranty when I had a small leak. Only cost me $50. I would not have done it unless it was leaking. The only regular maintenance I do is Oil changes (3k), and brakes when I change tires.
marcparnes
Posted 2012-12-21 6:44 PM (#128677 - in reply to #128674)
Denny Pink - 2012-12-21 2:02 PM
I'll tell ya, Denny, you might change your mind if you had seen the bushings that came out of mine at 30K. All the bearing material was worn away on the thrust side leaving only the backing. All that crud gets in the oil which was completely black. I think there must be a lot of load on the Vision's forks to wear the bushings out like that.
Marc
marcparnes
Posted 2012-12-21 6:45 PM (#128678 - in reply to #128671)
bigdogtx - 2012-12-21 12:24 PM
I just emailed Martin at Traxxion to ask his opinion. I'll post his response.
Marc
Posted 2012-12-21 6:45 PM (#128679 - in reply to #128675)
Cometman - 2012-12-21 6:51 PM
Interesting. So the dealer took care of your leaking fork(s) even though you did not change the fork fluid at every 15K, per their maintenance schedule ???
SammyJ
Posted 2012-12-21 8:44 PM (#128688 - in reply to #128659)
Princeton, IL
Monkeyman - 2012-12-21 12:56 AM
I agree with this whole heartedly. I did mine at 60000 miles. They worked fine, I think, but I wanted them powdercoated so I did both, minimized the down time and killed 2 birds with one stone. I am as happy as a clam!
Edited by SammyJ 2012-12-21 8:51 PM
SammyJ
Posted 2012-12-21 8:48 PM (#128689 - in reply to #128659)
Princeton, IL
Double post - sorry!
Edited by SammyJ 2012-12-21 8:50 PM
sstommyg
Posted 2012-12-22 7:37 AM (#128694 - in reply to #128653)
Oil IS OIL it breaks down.I change mine every fall,It is not that hard to do.You do not have to take the forks apart change the oil.
ByteN2it
Posted 2012-12-22 7:49 AM (#128696 - in reply to #128653)
I posted pics of what the stock fluid looked like when I changed my '09's fork fluid at 23,000 miles while replacing a front tire. It was doing its job & had a lot of suspended solids in it-could not see any sunlight through it. I got no problem performing scheduled maintenance and take great peace of mind knowing that it was done by someone I trust my life with, who was not in a hurry & always uses the best fluids available -me.
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=6457&pos...
Posted 2012-12-22 8:31 AM (#128699 - in reply to #128696)
ByteN2it - 2012-12-22 8:49 AM
Thanks for your post and link. Great homemade fork spring compression tool!
