recurve windshield for vision
Blue Sky Guy
Posted 2011-12-28 5:31 PM (#104260)
Subject: recurve windshield for vision
scotts valley, California
A search did not bring up any info on recurved windshields for the VV, so I'll ask:
Has any one tried one?  Did it deflect rain any better that the stock one or the Cee Bailey 21"?
Has anyone tried putting a recurve on a stock windshield by heating it or any other means?  (hot baseball bat, rolling pin?)  My original stock windshield is surplus at this point, and I'm game to experiment with it a little.  The top two inches or so of the factory windshield is already buggered up by distortion, so what do I have to lose?  Any suggestions from first hand experience will be appreciated.
cchristo
Posted 2011-12-28 7:03 PM (#104267 - in reply to #104260)
Subject: Re: recurve windshield for vision
san antonio, tx
Hmmmm. Cool experiment. I can't offer any help other than I've bent angles into some plexi. That was easy. Heat it kind of indirectly with a blow torch and bend it over.
Trying to get a uniform curve along the curved surface of the windshield will be awfully tricky. I don't know how you you would get a baseball bat hot enough and keep it hot enough to do it uniformly.
I have a feeling that when you're finished, you might be tempted to use the baseball bat in another capacity!
Blue Sky Guy
Posted 2011-12-28 7:44 PM (#104271 - in reply to #104260)
Yah, roger, the recurve would be a compound curve to boot. The plex would have to stretch as well as bend.
Edited by Blue Sky Guy 2011-12-28 7:45 PM
Posted 2011-12-28 7:58 PM (#104273 - in reply to #104260)
I was at a plastic store back when and they had a cord that they use. I though it kinda look like a cord you would use for froze pipes.
You could look on line for it doughty you get frozen pipes in Ca.
cchristo
Posted 2011-12-28 10:32 PM (#104279 - in reply to #104260)
san antonio, tx
Well, this is getting kind of Rube Goldberg, but you could get a bunch of clay and make a reverse mold out of it. Then you would have to borrow your friends pizza oven and stick a sheet of lexan or plexi in it. Pull it out and lay it on the mold.
It's kind of how they actually make them, except they use vacuum to suck it down on to the mold.
I've been working out in my mind a plastic or plexi shield that will snap over the switches on the console so that when I get around to putting illuminated switches in, I won't have reflections from them in the window. The best plan I've come up with so far is heating plastic or plexi sheet and bending it to fit.
I'm interested in your results if you do it.
Blue Sky Guy
Posted 2011-12-28 11:39 PM (#104282 - in reply to #104260)
My friend's pizza oven would probably end up with a pile of plastic stuck to the bottom! The clay mold is an interesting idea, but a little involved. I'm picturing something like oven gloves and a blow torch.
How hot does that stuff have to get to be able to work it?
Shadow-Bear
Posted 2011-12-29 12:07 AM (#104286 - in reply to #104260)
South Central Pennsylvania
Don't use oven mitts, go with welding gloves. They are cheap enough, and O reach into the fireplace to reposition burning logs.
cchristo
Posted 2011-12-29 6:06 AM (#104289 - in reply to #104260)
san antonio, tx
It would be hard to use a blowtorch over that large of a surface without causing a lot of distortion.
I think you need to imbed resistance wire into the clay mold. It would take a bit of experimentation, but eventually you would get the heat output right and the panel would uniformly drape over the mold.
This would save your friendship with the pizza oven owner, but I hope your friend who owns the plexiglass supply store is very generous!
And everyone needs a good pair of welding gloves anyway. Much more manly than the baking mitts with the little kitties printed on them.
Never tried it, but I've heard that a heat gun will provide enough heat to bend, and it would probably allow more even heat than the blow torch. Not nearly as fun though.
Posted 2011-12-29 6:30 AM (#104293 - in reply to #104260)
First hand experience? I would be interested to hear someone pipe up on that. Unless you have the experience and equipment to specifically fabricate a windshield, I'm sure the results would be less than acceptable. Are you trying to fix it or use it on another application?
chesshiretuna
Posted 2011-12-29 8:38 AM (#104298 - in reply to #104260)
Lexan(polycarbonate) takes some experiance to heat and bend. On an earlier bike , I was trying to fab some lowers from lexan I had in my shop. It gets internal bubbles in it when heated to bend. This was confirmed by one of my plastic fabricators as the drawback to this material. I thiought I had heard Clock Werks was working on a new windshield????
Blue Sky Guy
Posted 2011-12-29 11:37 AM (#104305 - in reply to #104293)
Well, VA, Shortly after I bought the bike in '08, I replaced the factory windscreen with a CeeBailey to try to reduce the machine gun effect from heavy rain.  I was a little disappointed in the results and have been pondering ever since.  When I first posted this, I was willing to experiment with the original VV windshield, but after reading everyone's thoughts, I think I would be wasting my time, not to mention a perfectly good windshield.
Yes, there is a manufactured recurve available that Kevin Ness developed by attaching a recurve from another bike model to his existing windshield with C-clamps!  The new manufactured model is one piece lexan but has lost the class and character of the C clamps.  Someday, when my ship comes in, I may buy one, but funds are an issue.  Maybe I could follow Kevin's example and have the C clamps chromed....
Thanks to all for the feedback.  I'm over it.  The do it myself idea has been moved to trash.
Posted 2011-12-29 12:17 PM (#104309 - in reply to #104260)
Say why not look in the yellow pages and find a shop that does plastic work or sells plastic and ask them what they do. You would get first hand information and then go from there.
You could always look on craigslist for a cheap stove
Blue Sky Guy
Posted 2011-12-29 12:51 PM (#104311 - in reply to #104260)
Thanks for the thought, John. I just talked with a guy at Tap Plastics who said it would be cheaper to buy a new one. Maybe I should just avoid riding in the rain.
ByteN2it
Posted 2011-12-30 8:37 AM (#104359 - in reply to #104260)
I have a few years experience of fabrication work in acrylic & polycarbonate. Polycarbonate, AKA Lexan, does not require heat to bend it. You can but sheets in a metal brake and bend angles cold just like sheet metal. The issue with putting a flip edge on an existing shield is once you heated the edge with a heat gun and got it soft enough to manipulate your going to make a mess of the surface plus most shields made from Lexan are MR5 type that have scratch resistant coatings that do funny things when they get hot. There's a very thin line of workability temperature, a bit to hot & you get bubbles/blisters and any bend will have optical distortion, If it was a shorty shield you could sand it smooth and paint it but anything that your thinking of keeping clear will not be something you'll want to look at for long.
Edited by ByteN2it 2011-12-30 8:42 AM
Posted 2011-12-30 9:01 AM (#104363 - in reply to #104311)
Blue Sky Guy - 2011-12-29 1:51 PM
? Why should that keep you from riding in the rain? Adapt and overcome.
ibking
Posted 2011-12-30 1:15 PM (#104389 - in reply to #104260)
I have a laminar lip ( laminarlip.com ) on my windsheild and it works great. If your local, ask to try it before you buy it.
MaddMAx2u
Posted 2011-12-30 3:13 PM (#104392 - in reply to #104260)
Orlando, FL
I think the original message on this thread was about "flip" winshields. There is the Laminar Lip, the Gustaffson Flip and the Ness Flip. I have the Gustaffson and like it. But I cannot compare to a non-flipped as my regular shield is a different height. It would be like trying to compare apples and oranges.
Blue Sky Guy
Posted 2011-12-30 5:36 PM (#104408 - in reply to #104260)
Yah, I was calling the flip a recurve; we're talking about the top of the windshield curving out toward the front of the bike to deflect air up and over. Without comparing apples to oranges, riding in heavy rain without a full face helmet, does the rain pelt pretty hard on your forehead?
MaddMAx2u
Posted 2011-12-31 8:24 AM (#104435 - in reply to #104408)
Orlando, FL
Blue Sky Guy - 2011-12-30 6:36 PM
Been riding a long time. Never found a way to keep the heavy rain from NOT pelting your head unless the windshield is ABOVE your line of sight. A flip shield is no more effective in rain than a regular shield. I usually wear a neoprene mask that solves the problem as I don't like a windshield above my line of sight. Mask, goggle and do-rag. Personally I believe the old doctrine that a plastic shield should never be above your line of sight on a motorcycle, but that would take an entirely new thread to discuss!!
I think the best solution is to stop, enjoy the moment and wait for the hard rain to pass. I would have missed some incredible experiences had I not stopped for heavy rain, including a threesome with two very hot women! Yup. A Ripley's Believe it or not moment!! You only go thru life once..... what's the rush?
Mask Example
http://compare.ebay.com/like/120831374469?var=lv
Edited by MaddMAx2u 2011-12-31 8:31 AM
sfalexi
Posted 2011-12-31 10:52 AM (#104441 - in reply to #104408)
Columbia, SC
How about buying a rain helmet? A cheap FF or 3/4 helmet that you only wear when it's raining?
Alexi
Travelin Man
Posted 2011-12-31 11:21 AM (#104443 - in reply to #104260)
Subject: RE: recurve windshield for vision
I have always been keen on taking something that is already made for one thing and modifying it to work for something else.  Case in point being the limited choices of windshields on the market for the Vision when compared to the Honda GL1800 Goldwing.  Since I had one of my old GL1800 windshields in the garage I laid it over my take off stock height Vision windshield and low and behold the curvature is nearly identical!  So, now knowing that the curvature is close enough (natural flex ability should take care of the small difference) all it comes down to is mounting hole location that needs to be modified.  Luckily for us Vision riders the Goldwing uses only four  mounting slots near the bottom of the windshield for mounting so we will have plenty of room to drill the holes we need for the mounting of a Goldwing windshield on a Vision, and then the excess material at the bottom can be trimmed off using a dremel tool.  Here is a picture from National Cycle of the windshield I plan on modifying:
cchristo
Posted 2011-12-31 11:30 AM (#104444 - in reply to #104260)
san antonio, tx
Thats a nice windscreen. I like the little flaps on the side of it. I think that particular feature might make a big change in the "bubble".
Very interested to hear how it works out if you follow through with it.
sfalexi
Posted 2011-12-31 1:23 PM (#104448 - in reply to #104260)
Columbia, SC
And instead of torquing it and flexing it, you can put washers to space it and account for any SLIGHT difference in curvature. I had an FJR, and one suggested mod was to put small rubber washers in two of the bolts as spacers to make the windshield a little more vertical. This made it SLIGHTLY taller and block a little more wind. I see no reason a rubber spacer couldn't account for a slightly different curvature. The only thing you need to make sure is that it doesn't hit anything or hurt anything when you are raising/lowering the windshield.
Alexi
cchristo
Posted 2011-12-31 2:22 PM (#104450 - in reply to #104448)
san antonio, tx
sfalexi - 2011-12-31 1:23 PM
And instead of torquing it and flexing it, you can put washers to space it and account for any SLIGHT difference in curvature. Alexi
That's a good idea, but I would be concerned about the amount of stress placed on the plastic due to the lack of surface area the washer would provide.
Maybe cut a thin plastic or aluminum shim to size and place it between the shield and metal bracket to increase the surface contact area?
bruzer
Posted 2012-01-02 12:54 PM (#104598 - in reply to #104260)
Aberdeen SD
check out klock works as brian is working on a sheild for the vision
