broken drive belt this morning. doh!
eotsis1
Posted 2017-06-01 4:56 PM (#191929)
Subject: broken drive belt this morning. doh!
, IL United States
What parts will I need? 77k on bike
My list is exhaust flange gaskets, belt, rear (ct) tire has 22k, so maybe that too.
Anything else that should be mandatory?
Posted 2017-06-01 6:34 PM (#191930 - in reply to #191929)
Subject: Re: broken drive belt this morning. doh!
try to get good answer from dealer when you might see the belt.
I read where polaris/vic is cutting on parts left and right.
make sure you did out the old exhaust gasket to get a good seal.
eotsis1
Posted 2017-06-01 8:27 PM (#191934 - in reply to #191929)
Subject: RE: broken drive belt this morning. doh!
, IL United States
Some notables,,,
Did not need to loosen header pipes to remove muffler, tipover, sprocket cover, or wheel.
The removal of the belt, while done by time, nature, belt tension, or miles, took out the inner saddle bag, which is now in many pieces.
Note to self. Changing belt before it self destructs is a good plan and much cheaper.
Posted 2017-06-02 6:30 AM (#191936 - in reply to #191929)
Why would you need exhaust gaskets to replace your belt?
eotsis1
Posted 2017-06-02 9:18 PM (#191950 - in reply to #191936)
, IL United States
In my search to find steps for belt replacement, some had indicated swinging the head pipes out of the way, presumably to remove sprocket cover. I didn't need to however.
Posted 2017-06-03 6:09 PM (#191952 - in reply to #191929)
If the headers ever come off you should replace the gaskets. When you put pipes back on they don't always fit the same. Kinda like a used sock
auto parts store sell the gaskets
SteveS
Posted 2017-06-03 8:31 PM (#191953 - in reply to #191929)
Danbury, Connecticut
Sorry to hear about the damage you received from the belt. Do you visually inspect the belt on a regular basis? If so, did it show any warning signs?That's the earliest failure I've heard of for one of those belts except where a pulley was damaged. Based on the damage, I'm guessing it slowly came apart and whipped the plastic saddle bag to death.
eotsis1
Posted 2017-06-07 5:11 PM (#191966 - in reply to #191929)
, IL United States
repairs made with fiberglass matting.
Not much of a body guy, but I should've done the tire side first then it may have come out flatter. Behind the lid so not many will see it. Needed new meat on the back anyway, so mounted a sumitomo 195/55/16. Repainted the sprocket and brake rotor as they were showing their age.
Edited by eotsis1 2017-06-07 5:16 PM
(vision saddlebag repair 001.jpg)
(vision saddlebag repair 002.jpg)
(vision saddlebag repair 003.jpg)
Attachments vision saddlebag repair 001.jpg (85KB - 1 downloads)
Attachments vision saddlebag repair 002.jpg (97KB - 1 downloads)
Attachments vision saddlebag repair 003.jpg (86KB - 1 downloads)
Posted 2017-06-07 5:45 PM (#191967 - in reply to #191929)
eotsis1
more air in shock
